Old 08-03-2007, 09:02 AM   #1 (permalink)
gmanog's Avatar
Default Bsnl Gprs
Hi
I have seen in BSNL site that they are giving gprs for rs 199 per month, unlimited usage. is their gprs any good? I am looking it only for browsing in mobile and checking mail in mobile.
please post your feed backs here. Your feed backs are appriciated.
gmanog is offline
Old 08-03-2007, 10:55 AM   #2 (permalink)
CBZ is better than Pulsar
panacea_amc's Avatar
Default Re: Bsnl Gprs
ya...i have sen one of my frens use it...
First he used GPRS Rs 37 scheme where he could use it only on fone....but it had the serious disadvantage tht BSNL charged him for per KB download....
then he shifted to Rs 199 scheme which restricts data tranfer to 4GB per month...for any additional data downloads, he had to pay....
so, its upto u...to choose ur scheme...
the only competitor BSNL GPRS has is with AIRTEl.....airtel has the advantage that the Customer care service is far superior than BSNL....i m using Airtel Mobile Office and have speeds around 7KBps..here in Gauhati ...
all the best!
panacea_amc is offline
Old 08-03-2007, 10:59 AM   #3 (permalink)
gmanog's Avatar
i am not planning to use it for browsing in PC, I am just going to use it with my mobile.
BTW what is the AIRTEL's charges?
gmanog is offline
Old 08-03-2007, 11:18 AM   #4 (permalink)
Resident Fanatic
Manshahia's Avatar
airtel charges vary from state to state..
in punjab its 19 rs per day...
Manshahia is offline
Old 08-03-2007, 11:22 AM   #5 (permalink)
Gangsta
Josan's Avatar
Location: I come from the land of WARRIORS, land of 5 rivers, where the alcohol will make your liver quiver!!
@gmanog -airtel hav to plans
1]. One day plan @Rs19per day(u can use it on pc ,unlimited use )
2]. Full month Plan @Rs375per month (u hav to maintain Rs 400 ballance to make a request to activate but they will charge only Rs 375 for unlimited use)
##########only for mobile
1].one day plan @Rs 5per day (u cant download a file more than 2mb (Aprox),but for unlimited time
2].full month plan@Rs 99per month(same u cant download a file than 2mb(Aprox),but........
Josan is offline
Old 08-03-2007, 11:48 AM   #6 (permalink)
hey Josan...what plans r u talking of...??? what is ur location,,,??
in my place we have two plans:-
1. NOP = Rs 99 per month....for mobile use...no charge for per KB downloads..
2. Mobile office = Rs 249 per month...for pc use...no charge for per KB d/l..
all these plans are on per day basis...like if u activate for 1week, they will charge u only for 1 week...
Old 08-03-2007, 12:13 PM   #7 (permalink)
You gave been GXified
gxsaurav's Avatar
GPRS gives a maximum speed of 8 KBps only, so it's not worthwhile for a computer. if you are going for Airtel NOP plan remember one thing it doesn't support POP3 in Mobile phone.
The BSNL GPRS plan is good, but then again better use broadband. However if u can live with 8KBps then Rs 200 for unlimited is not a bad deal
about.me/gxsaurav
gxsaurav is offline
Old 08-03-2007, 12:40 PM   #8 (permalink)
GPRS with EDGE technology gives around 14-16 KBps speeds(maximum)....AFAIK it is available in pune.......otherwise it gives 8KBps without EDGE as u said..
Old 08-03-2007, 12:44 PM   #9 (permalink)
kool's Avatar
Wink Re: Bsnl Gprs
all the best!
r u sure its 4 GB? is it for prepiad or for postpaid?
►► ◄◄ :smile::smile:
kool is offline
Old 08-03-2007, 03:33 PM   #10 (permalink)
ya its 4GB limitation...n is available on BSNL postpaid//
Old 08-03-2007, 10:36 PM   #11 (permalink)
gmanog's Avatar
Hi guys
Thanks for your responce. I am only looking to use in mobile phone. so which is cheap and best?
For my PC usage I got broadband connection.
I already got a hutch line, what do they charge for GPRS?
gmanog is offline
Old 08-03-2007, 11:32 PM   #12 (permalink)
gxsaurav's Avatar
Since you arleady got a Computer with broadband, go for Airtel Prepaid with NOP plan.
about.me/gxsaurav
gxsaurav is offline
Old 09-03-2007, 06:46 AM   #13 (permalink)
Tech.Masti's Avatar
@panacea....... BSNL unlimited gprs plan have no limit.... What you said that it has a 4gb limit is totally not right.... Check their website.... Its totally UNLIMITED....but only for post paid customers....
Tech.Masti is offline
Old 09-03-2007, 06:48 AM   #14 (permalink)
gmanog's Avatar
then BSNL cheap and best?
gmanog is offline
Old 09-03-2007, 07:07 AM   #15 (permalink)
Tech.Masti's Avatar
Ya cheap but dont know its best or not.....
Old 11-03-2007, 07:30 AM   #16 (permalink)
gmanog's Avatar
I am using HUTCH GPRS now as I had hutch connection already. 49 rs monthly rental plus 10 paise for 10 kb traffic.
gmanog is offline
Old 11-03-2007, 09:59 AM   #17 (permalink)
Tech.Masti's Avatar
^^ ya HUTCH GPRS is too expensive, they should make some unlimited plan like AIRTEL, BSNL .......
Old 11-03-2007, 10:00 AM   #18 (permalink)
gmanog's Avatar
You are correct. May be Vodofone will do it. Lets see
gmanog is offline
