Old 05-03-2007, 12:09 PM   #1 (permalink)
Default Nokia 6600 Fast Redial
With the automatic redial ON, the Ist redial goes fast, but after that the redail slows down & after Ist redial attempt the redailing takes too long. I want to configure the phone's redial, as fast as the Ist redial is. I am an adavanced user and can change the phones system files.
Please tell me if any file's needs to be altered and how to do that, so that my problem gets rectified.
knoppix is offline
Old 05-03-2007, 05:14 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: Nokia 6600 Fast Redial
try this for redial...
goto desktop and press the green ket twice...
Pathik is offline
Old 06-03-2007, 05:50 PM   #3 (permalink)
thanks pathiks for your reply, but this is not i am looking for? I want to configure my phone in the way, that whenever the network or number is busy, it should automatically keep redialing (making fast redial) till the call is connected. Currently if the number is busy, it makes the Ist redial fast, but if it is still busy the redial slows down and shows the progress bar (redialing) and takes long time to make redialing.
knoppix is offline
Old 06-03-2007, 07:30 PM   #4 (permalink)
Google Bot
Pathik's Avatar
well thats a software bug...
u can try using any call manager app..
Pathik is offline
Old 06-03-2007, 10:43 PM   #5 (permalink)
try this man..
use a software called FExplorer (ver 1.02 or above)
open drive C:
navigate to
system >> system.ini
copy the file "system.ini" to your pc using bluetooth or infrared
open the downloaded file in notepad
now navigate to 26th line of the code of the file
modify "redial-timeout=5,10,20,30,XXX" to redial-timeout=5, and substitute the corresponding fugures to ones you like in seconds but different from 5..
i think this will be helpful..
Cig... Nature... Opposite from each other..
paradise_guy is offline
Old 13-03-2007, 09:50 PM   #6 (permalink)
Thanks paradise_guy for your valuable avdice. This is the exact thing i was looking for. i tried the same but, when i open the system.ini in notepad it displays the contents in encoded language. The contents are as :
P ä   â{9fÐ  «›@  @ Áz¿@ @ì¯*¾1@ +      Ö_ Ü‹ Ô_
/€  " Q  „
§ “ 1 2 8 0 9 @ÿÿÿÿT  ÿÿÿÿ ƒ@ J[G[B[G[J[E[G[A[\[A[F[  8 4 5 6 2 E : \ S o u n d s \ M P 3 \ K y u A a j K a l . m p 3 Â 1 2 8 0 9 #€ €  a     @ #€ €  a  Q   @IÒz¿#€ €  a  Q  | @ #€ €  a  §  | @hÒz¿#€ €  a  §  Ò @zÒz¿#€ €  a  §  ý @ #€ €  a  (  ý @G {¿#€ €  a  (  S @{¿#€ €  a  (  ~ @ #€ €  a  ©  ~ @Ðb{¿#€ €  a  ©  Ô @âb{¿#€ €  a  ©  ÿ @ #€ €  a  *  ÿ @°d{¿#€ €  a  *  U @Ãd{¿#€ €  a  *  € @ #€ €  a  «  € @Þf{¿#€ €  a  «  Ö @ñf{¿#€ €  a  «
Waiting for reply.
knoppix is offline
Old 13-03-2007, 11:22 PM   #7 (permalink)
Google Bot
Pathik's Avatar
try opening it wit a hex editor...
Pathik is offline
Old 14-03-2007, 12:11 AM   #8 (permalink)
Tried opening it with different PC basesd hex editors and the hex view of fexplorer, but of no use. is thr any other way ?
knoppix is offline
Old 16-03-2007, 10:34 PM   #9 (permalink)
can anyboby help me out with this????????
knoppix is offline
Old 21-03-2007, 11:29 AM   #10 (permalink)
Try opng it on a linux OS
Old 22-03-2007, 12:16 AM   #11 (permalink)
Hi paradise_guy,
Can you please do me a favor, by sending me the edited copy of the same file. Due to restriction of uploading .ini files i have changed the extension of the same file as system.txt.
i know that i am demanding more but still i hope that you will do it.
Attached is the file.
knoppix is offline
Old 06-01-2009, 05:04 PM   #12 (permalink)
Has anyone solved this issue?
(How to automatically redial fast)
ZenObi is offline
Old 06-01-2009, 07:09 PM   #13 (permalink)
hi i m Ankush
my budget is Rs 15000 to RS 20000
i want to buy a cell.plz can anyone suggest me nice looking cell with good features
i prefer sony erricson
other suggestions are also welcome
aryankush is offline
Old 06-01-2009, 07:31 PM   #14 (permalink)
It was never solved for me.
knoppix is offline
Old 30-04-2010, 02:51 AM   #15 (permalink)
hi knoppix!
have you tried
Avis Quick Redial?
ZenObi is offline
