Old 03-03-2007, 10:26 AM   #1 (permalink)
Resident Fanatic
Manshahia's Avatar
Default Battery time Low??
my phone's battery is not giving optimum performance...
Sud i buy a new one??
Also wat wud b the price and from where to purchase.
I m using N-6630
Thnx
Manshahia is offline
Old 03-03-2007, 10:56 AM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: Battery time Low??
wat time does ur battery last???
Pathik is offline
Old 03-03-2007, 11:05 AM   #3 (permalink)
Approx 3 yrs is Max for any Original Battery to work perfect or at Optimal.
Stick is offline
Old 03-03-2007, 11:13 AM   #4 (permalink)
Resident Fanatic
Manshahia's Avatar
i was using charging evrytime i use internet as power goes low..
The indicators get down to 3 or 4 at once..
and after restart they again goto 7 pointss....
i think the battery is weak...
Old 03-03-2007, 11:23 AM   #5 (permalink)
Google Bot
Pathik's Avatar
well wen using net via fone its bound to happen....
just restart ur fone after disconnecting to know the correct battery status... and keep charging the fone wen using net..
Pathik is offline
Old 03-03-2007, 06:38 PM   #6 (permalink)
I was using Moto 350C for GPRS via PC and I always keep it charging when Accessing Net and the result - battery hardly works for 3-4 hrs a day.
I think Keep charging is Early Death for Batteries.
Stick is offline
Old 03-03-2007, 07:48 PM   #7 (permalink)
Google Bot
Pathik's Avatar
i hav been keeping my battery for charging atleast 8 hrs a day...
still my battery lasts abt 2 days if normally used...
Pathik is offline
Old 03-03-2007, 08:45 PM   #8 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Hmm.. You should never put batteries on continuous charge.. One should charge the battery only when it drains completely.. That extends the life of the battery..
kalpik is offline
Old 03-03-2007, 09:22 PM   #9 (permalink)
By "drains completely" do you mean After shut off or till Warning Ring?
Stick is offline
Old 03-03-2007, 09:56 PM   #10 (permalink)
Cool G5's Avatar
Post Re: Battery time Low??
kalpik:- The battery should be completely discharged only in old phones.Most new phones today use Lithium ion battery & it doen't need full discharge.
Cool G5 is offline
Old 03-03-2007, 10:13 PM   #11 (permalink)
kalpik's Avatar
By drain completely i mean when the phone shows low battery..
@Cool_G5: then why do manufacturers recommend that in the users manual even in the newest phones?
kalpik is offline
Old 03-03-2007, 10:24 PM   #12 (permalink)
Cool G5's Avatar
@Kalpik have you not read about it in Digit previous issues.
Cool G5 is offline
Old 03-03-2007, 10:26 PM   #13 (permalink)
Google Bot
Pathik's Avatar
well i dunno that but u shd do that only the 1st few times in li-ion or li-polymer batteries... After that the memory effect doesnt kick in
Pathik is offline
Old 03-03-2007, 10:26 PM   #14 (permalink)
Cool G5's Avatar
@Kalpik have you not read about it in Digit previous issues.I read it in digit only.
Cool G5 is offline
Old 04-03-2007, 02:29 AM   #15 (permalink)
Tech.Masti's Avatar
but on new LG low end models it works man
Tech.Masti is offline
Old 04-03-2007, 06:25 AM   #16 (permalink)
Resident Fanatic
Manshahia's Avatar
continuos charge doesnt hav an effect but we are charging it for 8 hours or may b more(in my case)...
General wear and tear increases..
we are charging it 4 times a day, when in general we charge one time in two days....
Old 04-03-2007, 11:47 AM   #17 (permalink)
Google Bot
Pathik's Avatar
that cant be the reason man... my battery is literally on charging full day we i m home... yet it performs better than ny other... i hv a bl-6c... urs??
Pathik is offline
Old 05-03-2007, 11:31 AM   #18 (permalink)
Resident Fanatic
Manshahia's Avatar
Bl-5c
Old 05-03-2007, 05:16 PM   #19 (permalink)
cooldip10's Avatar
Doing a lot of internet work and talkin uses up battery fast
No need to worry.. Just cut down the internet usage:
Everything is Possible
cooldip10 is offline
Old 05-03-2007, 05:18 PM   #20 (permalink)
Google Bot
Pathik's Avatar
my gprs is on 24/7 wit atleast 3 apps using it... still my battery rox...
ther s definitely some other reason...
Pathik is offline
Old 06-03-2007, 02:26 AM   #21 (permalink)
Tech.Masti's Avatar
^^ yes i am using 3220 around 1 year and it connected to net around 4 hours a day..... no problem yet....
