Old 02-03-2007, 02:54 PM   #1 (permalink)
Default Bright for Nokia 5300
Hello to All,
Pls comment about Nokia 5300, which I purchased 3 days back. It fine set. Pls suggest any tips.
Also Help to reduce the brightness
gcbeldar is offline
Old 02-03-2007, 03:19 PM   #2 (permalink)
piyush gupta's Avatar
Default Re: Bright for Nokia 5300
Rread Manual to reduce brightness
More reviews here
http://www.gsmarena.com/index.php3%3...ews-1718p2.php
piyush gupta is offline
Old 02-03-2007, 03:20 PM   #3 (permalink)
Google Bot
Pathik's Avatar
u can reduce brightness 4m display settings
Pathik is offline
Old 05-03-2007, 09:14 AM   #4 (permalink)
Default Re:Nokia 5300, Battary Life in Music Mode
I am using Nokia 5300, very good phone. But, I can play music only for 1 to 2 hours, even if i charged fully. As per Nokia specification it is more than 10 hours. What is wrong in my use. Can any one suggest ?
gcbeldar is offline
Old 05-03-2007, 10:26 AM   #5 (permalink)
assasin's Avatar
it will take sometime (recharge discharge cycle) before the fone battery can be fully utilized.dont worry nothings wrong wit ur fone.
assasin is offline
Old 05-03-2007, 10:32 AM   #6 (permalink)
With any New mobile before initial use you need to charge it full and than use it till phone went Off it self, do it 3-4 times and than your Battery give you Great Performance as per specs.
Stick is offline
