Old 28-02-2007, 06:43 PM   #1 (permalink)
pushkaraj's Avatar
Lightbulb Connecting n6600 to pc
I hav activated mobile office service on my n6600. I surf the net on my pc by connectin my cell to it via bluetooth. But the download speed is as low as 3-4kbps I tried connectin my friend's n6630 to my pc and access the net and it gave me download speeds in the range of 8-9 kbps Could it be bcoz i had connected the cell via the usb cable. If yes, then i hav heard that there is usb cable available for n6600 also. IS it gonna help in increasing the download or surfing speed?
The statistics on sanity are that 1 out of every 4 humans is suffering from some form of mental illness:shock:
Think of your 3 best friends. If they are OK, then it's YOU:grin::grin::grin:
pushkaraj is offline   Reply With Quote
Old 28-02-2007, 06:50 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: Connecting n6600 to pc
6630 is a edge nd 3g fone... Thats the reason 4 the better speed.. Also the data cable provides better speeds than bt
Pathik is offline   Reply With Quote
Old 28-02-2007, 08:51 PM   #3 (permalink)
pushkaraj's Avatar
Ne idea bout the usb cable available for n6600.
I mean will it work with nokia pc suite??????
Old 28-02-2007, 09:04 PM   #4 (permalink)
Google Bot
Pathik's Avatar
it ll work... but the usb data cable was available only wit the extremely old version of the 6600 ... after the revised hardware the data cable support was discontinued... i doubt ur 6600 has it..
Old 28-02-2007, 09:40 PM   #5 (permalink)
pushkaraj's Avatar
Thanks I will check out if the vendor demonstrates the use of the cable by connecting my cell via nokia pc suite.
Old 01-03-2007, 05:11 PM   #6 (permalink)
cooldip10's Avatar
EDGE has more speed than GPRS.. as my frnd has already said..
U can try the cable for satisfactory results..
Everything is Possible
cooldip10 is offline   Reply With Quote
Old 04-03-2007, 02:54 PM   #7 (permalink)
Crazy Kidd's Avatar
Bluetooth is faster than Data Cable. And the reason for your slow speed is your mob. It lacks EDGE. And the draw back of Nokia data cable is it doesn't charge your mob like the SE or Motorola one. So data cable is a bad option. It won't help you with net speed.
And where are you from?? I'm using Mobile Office too. But I'm getting 8-10 KBps download speed on my Motorola L7. It doesn't have EDGE.
Crazy is what crazy does. So lets get crazy like hell.
Crazy Kidd is offline   Reply With Quote
Old 04-03-2007, 03:16 PM   #8 (permalink)
Google Bot
Pathik's Avatar
@ crazy.. data cable is nyday faster than BT...
Old 04-03-2007, 03:28 PM   #9 (permalink)
Crazy Kidd's Avatar
Well not always. And my point was it won't help him to increase the net or download speed.
Old 04-03-2007, 04:10 PM   #10 (permalink)
Hell Sucks!!!
Can u tell whn is bltth faster ?
ashu_dps is offline   Reply With Quote
Old 02-06-2010, 05:13 PM   #11 (permalink)
First, I recommend a cable over bluetooth. Second, the connection depends on your network signal. Third, don't expect too much, you might just receiving a GPRS connection & not 3G.
____________
My SEMO Blog
Sage48 is offline   Reply With Quote
