LinkBack (2) Thread Tools Display Modes
Old 28-02-2007, 03:53 PM   2 links from elsewhere to this Post. Click to view. #1 (permalink)
IM AS MAD AS HELL!!
max_demon's Avatar
Arrow converting k750i to w800i
My CDA is CDA 102338/154
and i finished conversion . the phone is working good
thanx to salilrane
see below for the process
When someone dies in the grip of a powerful rage... a curse is born.
Kayako Saeki: Croakkkkkkkkkkkkkkkkkkkkk!
max_demon is offline   Reply With Quote
Old 28-02-2007, 09:54 PM   #2 (permalink)
.........Access Denied!!!
salilrane's Avatar
Default Re: How to convert k750i to w800i?
http://forums.se-nse.net/index.php?showforum=18
chk out ..
register fst
salilrane is offline   Reply With Quote
Old 28-02-2007, 10:49 PM   #3 (permalink)
IM AS MAD AS HELL!!
max_demon's Avatar
thnx , But will it work on CID 49?
__________
what r the Disadvantages and Disadvantages?
Old 28-02-2007, 11:07 PM   #4 (permalink)
::cyborg::'s Avatar
max u will lose auto focus and activity button
plz be careful while doing this thats a risky job ok
- KEEP SMILING
::cyborg:: is offline   Reply With Quote
Old 01-03-2007, 12:11 AM   #5 (permalink)
IM AS MAD AS HELL!!
max_demon's Avatar
@cyborg , i didn't loose the autofocus . But WALKMAN key is better than Activity key.
Here is My W800i
Sorry but the picture Quality is not good.
(This Picture needs autofocus )
i will post the entire process tomorrow .
__________
Originally Posted by salilrane
thanx too much
Old 01-03-2007, 01:34 PM   #6 (permalink)
::cyborg::'s Avatar
yeah a full procedure would be a nice thing to have
and if possible include pictures too
u have a red phone max
- KEEP SMILING
Old 01-03-2007, 04:09 PM   #7 (permalink)
IM AS MAD AS HELL!!
max_demon's Avatar
^^Yes , i have Red Phone..
Old 01-03-2007, 04:59 PM   #8 (permalink)
IM AS MAD AS HELL!!
max_demon's Avatar
Arrow Converting k750i to w800i
Required things :
Phone XS
w800i firmware (Rapidshare Link , can anyone upload this on some server?)
USB Drivers (attached with this topic)This is very important
Black k750i Phone (CID 49 New modles)
Things to remember -
[IMP]Charge your phone 80% is enough
[IMP]Make sure that you have the Datacable (that one comes with your phone)
Close all application that can hang your computer
Remove your Memory card
Warrenty is void if you flash your phone
Install USB drivers
If your phone is startes when u press 'C' key and plug datacable
Download USBFlash DriversOpen the arhive.Start PhoneXS, enter settings, start Device Manager(inKey+Pause-Break or Control Panel=>System=>Hardware=>Device Manager). Press Flash button. Hold C, Plug in the cable. Unrecognised device should appear in Device Manager. Right Click on it with the mouse and select Update Driver. Point to the directory where you extracted USBFlash Driver. Now close and open again PhoneXS. Switch off the phone
What it changes -
It just changes the media player , menu structure , camera zooming levels and sound level
Advantages -
the 'W' icon for media colour
the Music only mode in startup
Activities menu replaced with Walkman
Radio in loudspeaker
the 'Play' button playes music , without having to insert handsfree
loud music
Walkman media player Organises the music better than old media player
4X Zoom at 2 Megapix
w800i is costly as compared to k750i
Noone likes w800i colour sceme (except some who like orange , btw i like black)
Disadvantages -
*WARNING!!when i tried deleting some games , the phone restarts automatically ,& hangs up in the starting ne1 else facing this problem please let me know.
*the warrenty is void ofcourse
Process -
1.Extract all files
2. Run Phone XS beta
3.Click File > Start
4.Enter this setting
Communication Device => USB
Baund rate (speed) => 921600
Phone model =>K750/D750/W800 (CID49)
5.Goto Flash.(below there is an option in configuration)
6.Enter
Main firmware=>Path of w800i firmware Extracted file.
Tick - Flash main firmware
7.Turn off your phone Remove the Battery . Replace battery. do not turn on the Phone
8.Click Flash
9.Hold 'C' and Plug in the Datacable.
10. the process will start automatically
11.If everything is fine the phone will remain switched off and you will see this
12. If everything goes OK this should appear
13.Now unplug the phone and start .
Now you have w800i in k750i case.
If after the process the phone doesn't switch on remove the battery and put it back in. Now it WILL work.
Update : New w550i default theme
Update : New w800i default theme
Update : Convert your k750i look to w800i >>Download<< 37 MB 15 Min *.wmv (Explanation is done in Chinese So do at your own risk)
source
Old 01-03-2007, 09:06 PM   #9 (permalink)
salilrane's Avatar
so conversion is done .................
congratz ..
if any qstionz or probs leeme know ..
i always to R & D on my w800i...
Old 01-03-2007, 10:20 PM   #10 (permalink)
::cyborg::'s Avatar
@max i have to finalize the phone or just i flash the main file
- KEEP SMILING
Old 01-03-2007, 10:24 PM   #11 (permalink)
loud music .. that means through the internal speakers or through headset .. also radio will work without the handsfree ?
yogi_7272 is offline   Reply With Quote
Old 01-03-2007, 10:54 PM   #12 (permalink)
Knowledge Nomad
appu's Avatar
hey wann ask
can dis procedure be used for se z530i to w300i
appu is offline   Reply With Quote
Old 01-03-2007, 11:31 PM   #13 (permalink)
IM AS MAD AS HELL!!
max_demon's Avatar
Talking Re: How to convert k750i to w800i?
i flashed only main firmware
__________
Originally Posted by appu
hey wann ask
But you will need Firmware file for w300i and also , the hardware are different you may face problems
__________
Both!!
Old 02-03-2007, 08:53 AM   #14 (permalink)
There is some setting, you can hear radio through Phone Speaker but need to connect Headphone as it work as Antena for Radio.
Stick is offline   Reply With Quote
Old 02-03-2007, 05:37 PM   #15 (permalink)
IM AS MAD AS HELL!!
max_demon's Avatar
^^yes , click More =>loudspeaker
Old 03-03-2007, 02:24 PM   #16 (permalink)
Kalyan's Avatar
Hey Max..
Nice info man.. Just clarify my doubts..
> Does the flashing change auto focus or the modes, frames etc in the camera in 750i?
> How do I find out my CID number? (of course I bought it recently..)
> What is the worse that could happen if something goes wrong in the middle of the process? I mean u said about risk what is it? what would happen to the mobile?
> If something goes wrong, could we roll back or re-flash it (either with k750i or w800i)? If warranty is void, what should I do if something goes wrong? Do I have to dump my mobile?
> While flashing, Should I keep the sim card in the phone or should I remove it?
> Does everything else work fine? I mean what about the default games? do they change? I liked the 3d flight and tennis game.. and dont want to lose them.
Please let me know as I am interested to do this.
Kalyan is offline   Reply With Quote
Old 03-03-2007, 02:55 PM   #17 (permalink)
IM AS MAD AS HELL!!
max_demon's Avatar
Originally Posted by Kalyan
Hey Max..
1> No , it don't change camera software . But it degrades the the software from 5.6 to 5.3
But zooming at 4X in large picture mode is good
Autofocus is available.
2>...To find your CID number key in >*<<*<* here goto Service info=>Software info=>scroll to Customisation
Here is written your CID no.
3>you may not be able to start the phone till next flashing
4>since it dont change filesystem nothing is changed , if you want to roll-back juse run SESU
5>keep sim card , if removed it will prompt you to keep
6>you have all the games . it dont even delete the games which you installed before.
an of course
it dont even delete a single contact
it dont even delete a message and all
if you have any problems reply here , btw i have also bought the phone recently
[ander ki baat]the dealer was saying that w800i was Rs.12,000[/ander ki baat]
Old 03-03-2007, 03:27 PM   #18 (permalink)
Kalyan's Avatar
Thanks Max..
Thats a good info.. three more questions arised.. shooting 'em
> How much time would it take for the total process? I have an AMD 2400+ with 256 mb Ram and geforce 2mx(64 mb) pc.
> Is there a way to upgrade that camera software only?
> I think SEUS upgrades to the latest k750i firmware and I heard that it is cranky. Can I then upgrade to the former version?
Thanks a million for the info.
Old 03-03-2007, 03:39 PM   #19 (permalink)
IM AS MAD AS HELL!!
max_demon's Avatar
Thanks Max..
1> it usually takes 5-10 minutes
it take me only 2 minutes for me .( just to flash . preparation takes 5 minutes and charging needs 40 minutes (my bat was 30%) )
2>Sorry, but why u need that new crappy software which restrict zooming at 4X at 2 Megapix
3>Yes latest firmware is really crampy . that is y i have taken w800i firmware
i will post the link for firmware ASAP
__________
R1A044
- First release
- JBenchmark 1 - approx 3894
- JBenchmark 2 - approx 334
- JBenchmark 3D LQ - approx 131
- JBenchmark 3D HQ - approx 89
- Software versions:
LCD 0
Camera 3.8
ITP CXC 125 932 R1B
R1C004
- Vodafone specific
- Released around 3/6/05
- No reported changes from R1A044
- As is the case with the K700, Vodaphone's R1C004 supports DRMed MP3s only.
LCD 0
Camera 3.8
ITP CXC 125 932 R1B
R1J002
- Released on SEUS 13/6/05
- Standby crash fixed / improved.
- Increased call and Media Player volume.
- Games menu operates much more smoothly.
- Smoother video playback
- General UI performance improvements
- Improvements and bug fixes to Bluetooth headset support.
- The auto focus beep sound has been changed.
- Saving a photo to the Memory Stick is now quicker.
- New MP3 folder on Memory stick
- Fixed the month names in the calendar for various european languages.
- Camera sounds are muted when in silent mode in some firmware locales (EU_1 , but not EU_3).
- Minimised Media Player icon changed.
- SMS 'to' text now black (previously white).
- A "Fully Charged" message is now displayed on screen when the phone has finished charging.
* PROBLEM: GPRS comms has been broken on many O2 UK phones and some phones from other service providers.
* PROBLEM: Video recording quality (bitrate) has been reduced.
- JBenchmark 1 - approx 3908
- JBenchmark 2 - approx 344
- JBenchmark 3D LQ - approx 205
- JBenchmark 3D HQ - approx 114
LCD 0
Camera 4.4
ITP CXC 125 932 R1B
R1L002:
- Released by DaVinci on 22-6-05
- Released on SEUS 30-6-05
- Fixes the O2-UK GPRS issue introduced in R1J
- Video recording quality as R1J (i.e. inferior to firmwares previous to R1J)
- JBenchmark 1: 3880
- JBenchmark 2: 335
- JBenchmark 3D LQ - approx 201
- JBenchmark 3D HQ - approx 121
LCD 0
Camera 4.4
ITP CXC 125 932 R1B
R1N005
- Released by SETool on 30-6-05
- Test firmware
- Known bugs with this firmware
Old 03-03-2007, 03:41 PM   #20 (permalink)
Kalyan's Avatar
Thanks a lot Max,,
I shall get to you after I flash my fone.
Old 04-03-2007, 07:20 PM   #21 (permalink)
Default Re: converting k750i to w800i
thanx to salilrane
hey thanks .. now me too have my W750i ...
__________
abt camera .. after flashing the firmware .. the autofocus lag is less .. takes less time to focus . also although 4x digital zoom is available in 2mp mode ..it takes the whole photos of objects not the zoomed part ..
sound quality is improves and also sound level is gone up too ..
Old 04-03-2007, 08:36 PM   #22 (permalink)
IM AS MAD AS HELL!!
max_demon's Avatar
__________
it is w800i
we can zoom after we have taken the image .
__________
can someone Rename this thread to "Converting k750i to w800i"
Is there any Moderator who has k750i?
Old 04-03-2007, 09:59 PM   #23 (permalink)
B/W any idea on how to display the Cell-Id/Location Id in W800/W810 ? It should be ideally under some N/W settings , but I coudn't find it.
aceman is offline   Reply With Quote
Old 08-03-2007, 06:37 PM   #24 (permalink)
::cyborg::'s Avatar
now if i want my k750i back what i have to max dude
- KEEP SMILING
Old 08-03-2007, 07:34 PM   #25 (permalink)
IM AS MAD AS HELL!!
max_demon's Avatar
i think SEUS will be right , i have not tried that till now . else u can go to http://forums.se-nse.net/index.php?act=idx and download your software version
Old 09-03-2007, 04:37 PM   #26 (permalink)
I Just Flashed Today "WORKS FINE"
I followed orkut
http://www.orkut.com/CommMsgs.aspx?c...24677429075272
Easiest Procedure Compared To Others...
radibioinfo is offline   Reply With Quote
Old 09-03-2007, 05:29 PM   #27 (permalink)
IM AS MAD AS HELL!!
max_demon's Avatar
I followed orkut
Duh... this is to completly convert it to w800i . in my tut it is just main Firmware.no need to worry about contacts data and all
Old 09-03-2007, 06:39 PM   #28 (permalink)
salilrane's Avatar
Here is My W800i
__________
thanx too much
ur phone looks awesome confgratzzzzzzz man ...........
Old 13-03-2007, 06:07 PM   #29 (permalink)
Kalyan's Avatar
Hey max..
I read ur replies.. thanks for all that info. But I didnt flash my fone due to some personal reasons. I shall do it anyway.. I just got this doubt.. does presence of earthing of power have any effect on the flashing? we donot have earthing of power in our room. do I have to earth my computer properly before flashing of the mobile?
thanks in advance..
Old 13-03-2007, 10:39 PM   #30 (permalink)
IM AS MAD AS HELL!!
max_demon's Avatar
Hey max..
thanks in advance..
no man just make sure u have inverter or UPS in u r home coz if the power is off during flashing . your phone might be at risk.
btw i also do not have UPS
LinkBack to this Thread: http://www.thinkdigit.com/forum/mobiles-tablets/50954-how-convert-k750i-w800i.html
Alternative MP3 player for SE k750 - Esato archive This thread Refback 27-07-2010 05:19 PM
how do i change my k750i into a w800i This thread Refback 20-06-2010 01:26 PM
