| Forum |
| Mobiles and Tablets Topics related to mobile phones, tablets and various operating systems. News should also be posted here. Note: This NOT the place for BUYING ADVICE queries. |
LinkBack (2) | Thread Tools | Display Modes |
#31 (permalink) |
I did the conversion. everything went well as u said above. but now, I got some issues to discuss. > The 4x zoom in full res works fine. but when I take a picture zoomed, it just saves the picture with no zoom. why is it so? ? Now, I find no use for the zoom in full res. > The media player is turned to walkman. but when I set equalizer to megabass, I feel that the sound is not clear. I mean, when I had the media player, I used to feel a bliss to hear in megabass setting. But now, for a couple of secs, the music goes fine. but when the sound goes complex(i.e., more no of beats and drums), the sound level falls off and I feel some kind of oscillations in sound level. > when I turn the phone speaker on with walkman, I find it very low. I used to have it higher before. I used to increase all the levels of the equalizer earlier to get a higher level of sound from the speaker. Now too, I need to do that in order to get a higher level. surely the sound compared to earlier setting is high. but if I keep a preset or megabass, I feel the sound output is lowered. > The main disappointment is that I feel I lost the megabass feature. everything else is ok for headphones. > I am not satisfied with the output of the speaker. > The joystick up is serving me as the utility key. But now, I lack the property of moving the shortcuts according to preferrence. > Everything went as u said. I got the startup menu for music mode, walkman key etc.. > One more thing.. for how much time should I hold the 'c' key? should I have to hold it till the end of the process or could I release the key after the phone is recognized and the process is started? I am not blaming u for anything of this. Just I am sure that u might show me a way out of this. sorry if I am bothering u so much. Thanks a lot.. |
#32 (permalink) | |
IM AS MAD AS HELL!!
2.)megabass is different i think , u can try manual equilizer setting , make the 1st and 2nd equilizer setting full and rest in the middle. 3.)it is higher than my previous volume , is u r CDA was same as mine ? be4 conversion? 4.)output of the speaker is louder than previous. 5.)u can move the shortcut acc. to u r preferance , check settings. ________ anyone here knows how to use Gslide , PhoneXS and FAR software help me to put hybrid cam software
When someone dies in the grip of a powerful rage... a curse is born. Kayako Saeki: Croakkkkkkkkkkkkkkkkkkkkk! |
#33 (permalink) |
hi,.
I checked the CDA. It was the same. > Is there any way that helps me with megabass? I really loved this feature. > If possible, please post the link to the k750i firmware, just in case I change my mind to revert it back to k750i. Not the latest crampy one but the previous one. I believe it also needs the same proceedure. > If I use SEUS, do I have a choice to select which firmware I want to install? > My phone model still shows as k750i.. Is it ok?? > I too agree the output of the speaker is louder than before. but that only happens when I set all the equalizer levels to max. but in preset modes, they feel a bit low for me. Do you feel any change for the earphones' volume? > I found a link from this thread referring to orkut. It flashes the phone totally. what do I get by following the proceedure? did u go through it? any feedback is helpful. > Could u tell me what are the default games and softwares installed with the w800i phone..(if u know) > I've checked settings> General > Shortcuts> Navigation Key Up. All I found is edit and delete for soft keys. when I click edit, it takes me to select another shortcut to be replaced. no setting for moving the shortcut up/down. I used to have 'more' previously and had 'move','delete' in that. If u have the option to move them, please be clear.. > The last message in phone XS was a 'failed to send data chunk' or something. what does that mean? I felt that the process was failed. Kindly explain.. > Now, All I need is the megabass feature.. Please post the link for the previous version of k750i firmware.. Thanks a lot... |
#34 (permalink) | |
IM AS MAD AS HELL!!
5.)hey!!, u were having the latest firmware before , if u want to update try using SEUS it is the easiest . if u want any more assistance go here
#35 (permalink) |
Hi Max..
at last, I followed orkut and flashed the entire phone. Now, I have my w800i. Thanks a lot for all the info u gave. and thanks to romil who gave the info and files in orkut. Do U have the aero3d and super real tennis games of k750i? If u could extract them through far or xs, please upload them. One more thing.. I have already posted in the forum. could u help me with upgrading the camera software and lcd driver? Thanks in advance |
#36 (permalink) | |
IM AS MAD AS HELL!!
When someone dies in the grip of a powerful rage... a curse is born. Kayako Saeki: Croakkkkkkkkkkkkkkkkkkkkk! Last edited by max_demon; 16-05-2007 at 06:51 PM. |
#37 (permalink) |
Hi Max..
just follow the steps given by Mr Romil in orkut which is given in this thread. he gave a step by step and most informative approach and everything is explained in the process. he also packed all the necessary tools just like what u did before. The process is for flashing the file system, customizing it for 800i(region and others) and then the main firmware. he's got all u need. Mark my words.. I found a lottttt of difference in the quality of sound in what I did before and what I did now. the phone model shows up as w800i now. Megabass rocks in my phone now. Only thing was the camera software. I think there is always a way in and and a way out. Just be careful while customising the file system. I got sweated while doing that. while doing that, dont keep the batt cover. 'cause, u would have to remove the batt a couple of times and u have got 30 secs for the process. the rest is the same.. the 4x zoom issue I told u before didnt solve in this either best of luck.. |
#38 (permalink) |
IM AS MAD AS HELL!!
Regarding Camera Driver Here are some driver
#39 (permalink) |
Thanks a lot max..
But could u tell me how to install any of these drivers? I have to use Phone XS. I cant use FAR. as mine is CID49. If I could use FAR, please tell me abt that. I also have XS++ with me if that could help |
#40 (permalink) | |
IM AS MAD AS HELL!!
to install Hybrid Camera Driver follow the steps >Create a Directory named "files_to_upload" in the Phone XS++ root folder >Create a subdirectory in the "files_to_upload" directory named "ifs" >inside "ifs" create "settings" >put the folders camera and acoustic(if u want "louder" music[yeah, louder than w810i] ) in the settings folder. download from here >Start Phone XS++ >Choose USB and click start , follow the instruction on the left . >choose FSX from bottom >Click "start FSX" >When it ask for Brekin or Bruteforcing , Click "Yes" For Brekin >Follow the instruction on the left , Don't panic at any time >when it says Disconnect the phone , Disconnect and Replace the battery for a refresh >Start the phone >Wow New Cam driver and acoustic are ready, Really kool Check using >*<<*<* look for Camera SW version .
#41 (permalink) | |
also, after updating the camera driver, is the 4x digital zoom at 2mp mode work? and what abt the sound drivers .. have the quality and loudness improved ..? could the post the whole process .. pls .. |
#42 (permalink) | |
IM AS MAD AS HELL!!
after updating the driver u can do 16X zoom Yippie at 2 MP and Sound drivers r louder than w810i(Quality is the same as normal mode) and look what i have done to my phone ![]() ![]() ![]() ![]() ![]() ![]()
#43 (permalink) |
ok .. great .
i have applied the process u told in this thread . .that is, use of w800 firmware only .. not the main file system and customisation .. also how is the quality of 16x zoom at 2mp mode so can i proceed with the process kalyan applied to his phone ? if yes then pls tell the whole process .. |
#44 (permalink) | ||
IM AS MAD AS HELL!!
This process
Second Tute increase the volume with Quality and Camera First tut is for main firmware
#45 (permalink) |
Thanks max..
Could u tell me how to backup my phone files through XS++ or Phone XS? If u have the aero mission 3d game and super real tennis game which come default with k750i? I have seen somewhere that these files can be backed up too though protected. If u could please upload them.. Also please tell me how to backup my files if u know. |
#46 (permalink) | |
#47 (permalink) | |
IM AS MAD AS HELL!!
![]() ![]() ![]() ![]() ![]() ![]() anyone reply about this?
When someone dies in the grip of a powerful rage... a curse is born. Kayako Saeki: Croakkkkkkkkkkkkkkkkkkkkk! Last edited by max_demon; 26-03-2007 at 08:54 PM. Reason: Automerged Doublepost |
#48 (permalink) | |
of course .. they are cool.. I asked abt backup for that only. I just wanted to backup my old menu files and other stuff. If u have any nice custom menus, could u please upload them? |
#49 (permalink) | |
I am not sure if this is illegal. but could u upload any nice mobile java games like prince of persia, tomb raider etc.. if that's not illegal? of course .. they are cool.. I asked abt backup for that only. I just wanted to backup my old menu files and other stuff. If u have any nice custom menus, could u please upload them? |
#50 (permalink) |
hey guys .. i think i screwed up my phone .. due to electicity problem . the process hanged .. now the phone is not starting up
any way to resurrect it other than taking it to service centre .. pls suggest a way .. |
#51 (permalink) |
Remove the battery and wait for some time and then replace it. Now, try flashing the phone again. ie., connect with XS++ or Phone XS etc. Repeat the process and there may be any luck. I think the warranty is lost but I dont know what they say if u go to the service centre. My phone disconnected too while I was customizing the file system in the process of flashing. I just repeated the process and the phone got recognized again.
Best of luck |
#52 (permalink) |
actually it got recognized the second time .. and i flashed it to newer camera and sound drivers .. but its not starting up now
anyways i will take it to service station tommorrow and see .. obviously not going to tell them what i tried . and i have n73me as backup so no worries .. but k750i is very good too .. |
#54 (permalink) | |
IM AS MAD AS HELL!!
#55 (permalink) | |
IM AS MAD AS HELL!!
happened to me 2 times , that the phone does not start at all . Replaced the battery and reinstalled the phone ( i was doing ascuotic upgrade , the files on the phone got corrupt ) then . u know
#56 (permalink) | |
this k750i is nice toy .. now proceeding towards camera and sound drivers .. |
#57 (permalink) |
What do flashing have effect on phone (many says it can damage the phone)
Does flashing void the waranty (also i have downloaded K750i update software from Sony Ericsson site) Is that software firmware or just the update to software install on the pc , i meant pc Sony Ericsson suite or it is firware I have model K750i I want to make click pics fast and not waiting 1-2 secs to click next pics. That the only thing i want (clicking pics faster) . Mine version is R1CA021 prgCXC 125952_EU_1_CL Camera 5.3
AMIT AGARWAL Last edited by AMITAGARWAL02; 28-03-2007 at 07:23 AM. |
#58 (permalink) |
ur firmware is very good ..
flashing the software means changing the whole software including firmware if ur hardware supports it .. and i dont think there is a way for clicking faster pictures because of autofocus lag .. you cant switch auto focus off as in k790i .. the thing i missed in k750i [QUOTE=max_demon]yes, i have applied both the process for flashing w800i after updating the driver u can do 16X zoom Yippie at 2 MP and Sound drivers r louder than w810i(Quality is the same as normal mode) and look what i have done to my phone ![]() ![]() ![]() ![]() ![]() ![]() hey max .. i have updated my camera and sound drivers with the one u provided ... sound drivers are cool .. but camera .. now i cant even zoom to 4x let alone 16x at 2 mp mode .. max i can zoom is 2.5x .. after that the image remains constant though the settings goes upto 4x .. now my camera soft ver is 8.3 ..what is urs ..? also do u find any quality wise difference in camera performance .. i am thinking that older driver was better .. but not sure abt this .. also it saves the whole pict instead of zoomed part ..? also do u have any other link for camera drivers .. and xs++ is the method to update ur drivers right ? Last edited by yogi_7272; 28-03-2007 at 06:42 PM. Reason: Automerged Doublepost |
#59 (permalink) | ||
IM AS MAD AS HELL!!
[quote=yogi_7272]ur firmware is very good ..
flashing the software means changing the whole software including firmware if ur hardware supports it .. and i dont think there is a way for clicking faster pictures because of autofocus lag .. you cant switch auto focus off as in k790i .. the thing i missed in k750i Quote:
NEW I will try today "Manual focus" very cool feature Quote:
we can custmize the camera driver , it is easy just open notepad and edit camdriver0.dat , i tried improving jpeg quality to 100% , it worked but the filesize is big . Quote:
| Bookmarks |
| Thread Tools | |
| Display Modes | |
LinkBack to this Thread: http://www.thinkdigit.com/forum/mobiles-tablets/50954-how-convert-k750i-w800i.html
| Posted By | For | Type | Date | |
| Alternative MP3 player for SE k750 - Esato archive | This thread | Refback | 27-07-2010 05:19 PM | |
| how do i change my k750i into a w800i | This thread | Refback | 20-06-2010 01:26 PM | |
