Old 22-02-2007, 06:38 PM   #1 (permalink)
Cool Why E50 is Cheaper than 6681/6630/6680?
Nokia E50 is supposed to be a equipped with
OS v9.1,
256K cols,
70MB internal memory,
better browser,
1.3MP cam,
Push email,
QVGA display,
Better Office apps,
Bluetooth v2.0,
But...cost is 10.3K.
My doubt is why is it cheaper than older models like 6681/6630/6680?
Any valid reason?
kindly analyze and share!
oval_man is offline
Old 22-02-2007, 06:52 PM   #2 (permalink)
krazyfrog
Posts: n/a
Default Re: Why E50 is Cheaper than 6681/6630/6680?
^^ Because it comes without a memory card. 6630 is 3G enabled. 6680 has 3G as well as front video camera. Whereas 6681 comes with 128 mb card. The advantages E50 has over these phones basically involves better OS and software. Others come with better hardware (3G, video camera, memory card) which costs the manufacturer more to implement/provide than software. If the E50 would have come with a memory card, it would have definitely cost more. Thats why the others are comparatively more expensive.
Old 22-02-2007, 07:54 PM   #3 (permalink)
Google Bot
Pathik's Avatar
well i dont know the reason...
but surely the e50 is a good deal for 10.3k
Pathik is offline
Old 22-02-2007, 11:34 PM   #4 (permalink)
dhan_shh's Avatar
@krazyfrog is absolutely correct,6630/80/81 are equipped with 220MHZ processors while E50 has 208MHz.Oldies are probably powerful but underutilized.
dhan_shh is offline
Old 24-02-2007, 09:27 PM   #5 (permalink)
Resident Fanatic
Manshahia's Avatar
one can easily mail, browse using these oldies.
but the web browser they provide is not sufficient.
One can use Mini-Opera to browse internet on these oldies
Manshahia is offline
Old 24-02-2007, 10:36 PM   #6 (permalink)
Google Bot
Pathik's Avatar
opera mini is also available on e50....
Pathik is offline
Old 24-02-2007, 10:48 PM   #7 (permalink)
kumarmohit's Avatar
Nokia,
India is a developing country with Mobile Phones leading the IT and communication, revolution.
Please make the E90 communicator available @ this price.
kumarmohit is offline
Old 24-02-2007, 10:55 PM   #8 (permalink)
Google Bot
Pathik's Avatar
add Dear to nokia.. They might take notice..
Pathik is offline
Old 24-02-2007, 11:19 PM   #9 (permalink)
assasin's Avatar
Doesnt E50 come bundled witha 64MB microSD card?
assasin is offline
Old 25-02-2007, 11:27 AM   #10 (permalink)
t3h g04t
teknoPhobia's Avatar
No
technologically challenged.
teknoPhobia is offline
Old 25-02-2007, 12:25 PM   #11 (permalink)
Google Bot
Pathik's Avatar
but mmcs r so cheap man... does it matter??
Pathik is offline
Old 25-02-2007, 06:14 PM   #12 (permalink)
kumarmohit's Avatar
Well, the ones sold by Nokia are not cheap, I got 512 MB for 6630@ 550 from Gaffar Mkt, (Non Delhiites - Read this as a flea mkt for cellphones in Delhi) While Nokia sells the same for around 2000-3000.
Old 25-02-2007, 07:19 PM   #13 (permalink)
Google Bot
Pathik's Avatar
in mumbai u ll get 1GB for 900 n 512MB for 450
Pathik is offline
Old 26-02-2007, 01:36 AM   #14 (permalink)
assasin's Avatar
^^^ For the cheap local ones,and not the ones made by Nokia right?
assasin is offline
Old 12-03-2007, 09:58 PM   #15 (permalink)
varkey's Avatar
since its s60, the opera mobile will also work....
Intel Core 2 Duo E6300 @ 1.86 GHz | Intel DG965WH | 2x1GB DDR2 667 MHz Transcend | Seagate 320 GB SATA II | Sony DW-Q120A | Samsung 940bw 19" LCD
varkey is offline
Old 12-03-2007, 10:07 PM   #16 (permalink)
Google Bot
Pathik's Avatar
did i say that it isnt available???? check the post above mine..
Pathik is offline
