Old 20-02-2007, 03:42 PM   #1 (permalink)
Default help me to make a choice
dear friends
I want to buy a cell phone .My budget is arond 10to 12 k. I want a 2 megpixel camera and good quality audio video recording.I am not so keen on music or games.blue tooth usb should be there.can u compare n70 ,K750i and lg dynamite and help me to make a choice.I will be very thankful for your help
bkm
bkmishra1000 is offline
Old 20-02-2007, 04:40 PM   #2 (permalink)
Default Re: help me to make a choice
K750i, Go Get it! without 2nd Though!
See what you will get with K750i
Stick is offline
Old 20-02-2007, 04:56 PM   #3 (permalink)
bongourav's Avatar
Hi ... I too wanted to ask the same question. Thanx that you asked it.
Anyways, I believe you should go for N72. Unlike K750i, it can be used to download applications. It also has a big screen for good video playbacks.
bongourav is offline
Old 20-02-2007, 05:52 PM   #4 (permalink)
piyush gupta's Avatar
already a thread
Best phone for 10k?
piyush gupta is offline
Old 20-02-2007, 05:56 PM   #5 (permalink)
Tech Geek's Avatar
+1 for K750i
Tech Geek is offline
Old 20-02-2007, 06:02 PM   #6 (permalink)
Google Bot
Pathik's Avatar
+100 for n72..
Pathik is offline
Old 20-02-2007, 08:38 PM   #7 (permalink)
krazyfrog
Posts: n/a
+1000 for N72
Old 21-02-2007, 01:04 AM   #8 (permalink)
If you really like to play with and use mobile as PC go with N72, but if you are happy with Great Sound + CAM and Stable Handset go with K750i/W810i.
Stick is offline
