Old 20-02-2007, 01:30 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
God of Mistakes...
Garbage's Avatar
Default Formatting Nokia 7610
Hello!
I'm having Nokia 7610.
Is it possible to FORMAT phone and re-install the software again (i mean Symbian OS) or newer version of OS ??
I found one site which gives the code for FORMATTING Nokia 60 series.
Is it real ??
Please reply...
http://www.imserba.com/articles/9/1/...-60/Page1.html
Registered Linux User #468778
http://twitter.com/_Garbage_
Garbage is offline
Old 20-02-2007, 02:31 PM   #2 (permalink)
krazyfrog
Posts: n/a
Default Re: Formatting Nokia 7610
Yes the codes provided on the article are genuine. You can follow them if you want to format your phone.
Old 20-02-2007, 03:24 PM   #3 (permalink)
assasin's Avatar
To install a newer version of OS u need to update ur fone using NSU or from any Nokia Care.Formatting simply deletes the C prompt and writes all OS files to it from Z prompt.the main OS itself is stored in Z.U cannot format it cuz its ROM.
assasin is offline
Old 20-02-2007, 06:45 PM   #4 (permalink)
Google Bot
Pathik's Avatar
yea they r all rite...
use the 3 key format..
Pathik is offline
LinkBack to this Thread: http://www.thinkdigit.com/forum/mobiles-tablets/50075-formatting-nokia-7610-a.html
Bbm nukia 7610 | belibis A-17 This thread Refback 27-02-2012 11:52 AM
