Old 19-02-2007, 06:39 PM   #1 (permalink)
tanush_89's Avatar
Default nokia 6610i
Hi I have transferred images from many phones but not as old as this one.
How can I transfer from this phone??
tanush_89 is offline
Old 19-02-2007, 06:54 PM   #2 (permalink)
Cool G5's Avatar
Question Re: nokia 6610i
Transfer where?
Cool G5 is offline
Old 19-02-2007, 07:15 PM   #3 (permalink)
Google Bot
Pathik's Avatar
Default Re: nokia 6610i
only way is mms... i dont think u can do that thru IR or the data cable...
Pathik is offline
Old 19-02-2007, 07:18 PM   #4 (permalink)
tanush_89's Avatar
there is aport for data cable.
My cable of 6280 got fixed but the cell was unrecognized. BTW i wanna transfer in my PC
Old 19-02-2007, 07:21 PM   #5 (permalink)
Cool G5's Avatar
Post Re: nokia 6610i
You need DKU-5 cable to transfer them to pc.Download the nokia pc suite from nokia's site if you do not get it with the cable.
Cool G5 is offline
Old 19-02-2007, 08:20 PM   #6 (permalink)
Wandering in time...
Ankur Gupta's Avatar
Yes transfer through IR is not allowed but data cable DKU-5 works perfectly well...
Integrate Yourself With The Latest Happenings.....
www.ankur-gupta.com/blog
Ankur Gupta is offline
Old 19-02-2007, 08:51 PM   #7 (permalink)
tanush_89's Avatar
whats the cost ???
Old 19-02-2007, 09:40 PM   #8 (permalink)
gmanog's Avatar
DKU 5 cables you can get around 100 rs (of course, chinise make). Original ones are very costly. but this 100 rs cable works fine.
gmanog is offline
Old 19-02-2007, 11:43 PM   #9 (permalink)
Tech.Masti's Avatar
yes, find DKU-5 or CA-42 cable.......notice that all such cables are not good .... when any cable you connected to the phone.... it gives a messages like that" Data Enhancement connected" or like that.... only those DKU-5 or CA-42 cable is compatible with ur phone.... i am taking about chinese data cables..... price will be rs.100-300 depends on shopkeeper....
Tech.Masti is offline
Old 20-02-2007, 06:43 AM   #10 (permalink)
tanush_89's Avatar
thanks man. i'll buy that today
Old 22-02-2007, 05:31 PM   #11 (permalink)
cooldip10's Avatar
I've the dku 5 cable with software.. If u want I can send them to you. Actually I lost that phone, so the accessories are no use to me any more..
Its some local made which cost me rs300.( 8 months back)
Everything is Possible
cooldip10 is offline
