Old 18-02-2007, 10:56 AM   #1 (permalink)
gmanog's Avatar
Default Nokia 6233
Hi guys
I have seen a Nokia 6233 few days back in Nokia Show Room, the sales guys told that its a good phone. I like it also. Is it a real good phone?
gmanog is offline
Old 18-02-2007, 11:58 AM   #2 (permalink)
Default Re: Nokia 6233
yes my sister in law also has the same phone but what i dont like about this phone is camera its not that effective like 6280,sony w810i but the sound effect is too good. but i prefer w810i over 6233 coz of its good camera and walkie phone. but its a good worth buying 6233 if ur priority is not camera and look wise 6233 is good
kunaltech is offline
Old 18-02-2007, 12:12 PM   #3 (permalink)
Google Bot
Pathik's Avatar
i like the 6233 too.. But now nokia has launched 6300 n u shd go 4 it.. Ther s not much diff in the prices too
Pathik is offline
Old 18-02-2007, 01:46 PM   #4 (permalink)
gmanog's Avatar
Thanks for replying.
Camera in not my priority. Is the sound quality better than SE w810i ?
what is the major difference between 6233 and 6300?
gmanog is offline
Old 18-02-2007, 03:06 PM   #5 (permalink)
Google Bot
Pathik's Avatar
well the sound quality isnt better thatn w810i but its good enough... its stereo speakers rock....
well the main diff btw 6233 n 6300 is that 6300 doesnt hav 3G....
nd 6233 has vga video recording while 6300 has qcif video rec.
Pathik is offline
Old 18-02-2007, 05:08 PM   #6 (permalink)
gmanog's Avatar
then 6233 is better in technology wise? as its a 3G mobile ?
What is the difference between vga and qcif video recording ?
gmanog is offline
Old 18-02-2007, 06:12 PM   #7 (permalink)
assasin's Avatar
VGA vdo recording supports resolution of 640x480
Resolution for qcif is 176x144.
assasin is offline
Old 18-02-2007, 06:52 PM   #8 (permalink)
Google Bot
Pathik's Avatar
hmmm i think u shd get a 6233 only... cos both prices r almost same...
in fact 6300 is costlier..
Pathik is offline
Old 18-02-2007, 09:30 PM   #9 (permalink)
gmanog's Avatar
Thanks guys.
One Final question, is there any other good phone available in the same budget?
gmanog is offline
Old 18-02-2007, 09:34 PM   #10 (permalink)
n72 rocks man
hackers2005.3721 is offline
Old 18-02-2007, 09:38 PM   #11 (permalink)
gmanog's Avatar
Originally Posted by hackers2005.3721
n72 rocks man
is it not big in size? N72 - what is better in it than 6233? can you explain
gmanog is offline
Old 18-02-2007, 09:43 PM   #12 (permalink)
Google Bot
Pathik's Avatar
yea ...IMHO n72 is better than both of them...
__________
n72 is a s60 fone... os8.1... so u get manyyyy apps 4 it... multitasking is a plus too.... 6233 is a s40v2... so not many apps except the java ones...
however the cam n sound of 6233 is better
Pathik is offline
Old 18-02-2007, 09:50 PM   #13 (permalink)
gmanog's Avatar
__________
Sorry, didnt notice your edit post.
Thanks
__________
Do you know the street price of N72?
__________
see this
http://www.univercell.in/compare1.asp?mno=263&mmno=258
I feel in some areas 6233 is better than N72
gmanog is offline
Old 18-02-2007, 09:53 PM   #14 (permalink)
Google Bot
Pathik's Avatar
arey bola na...
__________
yup... if u don want 3rd party app support then 6233 is the fone 4 u....
however i wd go 4 the n72....
well n72 was availkable 4 10.6k sometime back... now both 6233 n n72 hav more or less the same price... ie arnd 11.5k
Pathik is offline
Old 18-02-2007, 10:12 PM   #15 (permalink)
gmanog's Avatar
arey bola na...
__________
Thanks. I decide for N72. Thanks for your help.
__________
Added reps to you
gmanog is offline
Old 18-02-2007, 11:39 PM   #16 (permalink)
if u can manage more 2k then W810i is too good
its around 14k
Old 18-02-2007, 11:45 PM   #17 (permalink)
Google Bot
Pathik's Avatar
thx 4 the reps.. But again if u prefer better music then go 4 the 6233.. If u cant do witout symbian apps then go 4 n72.. Cos u may not like the sound quality in n72.. Compare both fones @ nokia gallery n decide
Pathik is offline
Old 19-02-2007, 12:58 AM   #18 (permalink)
Tech.Masti's Avatar
Nokia 5300 is also a option......what you say guys??? S40v3.... camera is not so much good....but it's a slider phone.... check reviews here......
http://www.gsmarena.com/nokia_5300-review-117.php
Tech.Masti is offline
Old 19-02-2007, 01:00 AM   #19 (permalink)
Google Bot
Pathik's Avatar
its also s40v2 only
Pathik is offline
Old 19-02-2007, 01:15 AM   #20 (permalink)
Tech.Masti's Avatar
Pathinks..... check here........
http://www.forum.nokia.com/devices/5300
http://www.mobile-review.com/review/nokia-5300-en.shtml
Old 19-02-2007, 07:00 AM   #21 (permalink)
gmanog's Avatar
Can I use applications like Voip in S40v2 or its only possible in s60?
gmanog is offline
Old 19-02-2007, 09:52 AM   #22 (permalink)
Google Bot
Pathik's Avatar
afaik there r many voip applications in s60.. Dunno much abt s40.. Jus search "voip" on getjar.com .. Also the java apps in s40 may not be as good as the sis apps..
Pathik is offline
Old 19-02-2007, 09:58 AM   #23 (permalink)
Read here more about S60 applications and what you can do with.
Stick is offline
Old 19-02-2007, 12:02 PM   #24 (permalink)
gmanog's Avatar
Let me make it clear, I am not particular about the music in mobile or camera in mobile (for those purposes I got ipod and good camera), what i need is a good phone with good features such as gprs, edge, blue tooth and should be able to run some usefull applications, if music and camera comes as an addon thats ok with me. You guys please suggest me a good phone. I am not particular about the budget, as the mobiles will be outdated or not usable over a period of 16 moths to 24 months, I do not want to spend more on that, so for more featuers for less money and relaible phone is what I am looking for.
Please help guys.
gmanog is offline
Old 19-02-2007, 12:46 PM   #25 (permalink)
Google Bot
Pathik's Avatar
then n72
Pathik is offline
Old 19-02-2007, 02:10 PM   #26 (permalink)
Tech.Masti's Avatar
^^^ yes.... Then n72
Old 19-02-2007, 03:19 PM   #27 (permalink)
gmanog's Avatar
Thanks guys
__________
I came across one more phone guys E62 somewhere in the same budget, How about it?
gmanog is offline
Old 20-02-2007, 01:07 AM   #28 (permalink)
assasin's Avatar
Dont go 4 E-series.
U may also consider Nokia 5500 and 3250.they r pretty good fones.
assasin is offline
Old 20-02-2007, 12:56 PM   #29 (permalink)
krazyfrog
Posts: n/a
Go for Nokia N72 only.
Old 20-02-2007, 03:27 PM   #30 (permalink)
assasin's Avatar
^^^But audio quality of Nokia 3250 Xpress Music is better dan N72.Loudspeaker of both 5500 & 3250 far better than N72.So why suggest N72?
assasin is offline
