Old 16-02-2007, 08:42 PM   #1 (permalink)
amit2005's Avatar
Default Putting PDF into mobile?????????/
hi everyone...cud any tell me how to upload my .pdf file to my mobile 6670/n72...i mean it's size is around 47 mb..my fren have same book whose size is 5.4 mb...he didn't know how it was done...though my file is of pc...his of cell so cud anyone tell me how cud this be possible..pulllleeeezzzzzzzz help
ROCK IS HERE
amit2005 is offline
Old 16-02-2007, 09:13 PM   #2 (permalink)
Security Exp
47shailesh's Avatar
Default Re: Putting PDF into mobile?????????/
no difference in case of PC or mobile... get that file from ur friend simply copy that file using data cable or transfer that file directly from ur friend's mobile on to ur mobile via bluetooth or IrdA
We Love Once, And When We do We do it Well
47shailesh is offline
Old 16-02-2007, 09:20 PM   #3 (permalink)
Google Bot
Pathik's Avatar
pdf files hav the same size be it cell or pc....
it mite be that his pdf has a lower quality than urs...
u can also reduce the quality of ur pdf wit some pdf creator ..
Pathik is offline
Old 22-02-2007, 09:01 PM   #4 (permalink)
amit2005's Avatar
like can it be done with adobe
ROCK IS HERE
amit2005 is offline
Old 22-02-2007, 09:09 PM   #5 (permalink)
Google Bot
Pathik's Avatar
do u hav the adobe pdf editor..??? not reader...??
n yup i think it can be done wit adobe too...
Pathik is offline
Old 22-02-2007, 09:35 PM   #6 (permalink)
Security Exp
47shailesh's Avatar
Dude not possible via Adobe reader.. Adobe reader can only be used for viewing of Acrobat data>....
Old 22-02-2007, 11:02 PM   #7 (permalink)
Google Bot
Pathik's Avatar
i said adobe pdf editor.. N not reader.. Read carefully
Pathik is offline
Old 22-02-2007, 11:31 PM   #8 (permalink)
just use adobe reader for nokia
u can get its sis file i.e. setup file by googling
it is free, just download it and install it on ur handset
after that transfer any pdf file from ur pc to ur cell
if u not get this software just tell me
:P If U lIkE mY SUggeStIon Plz ADd SOmeThing tO mY RePUtaIon :)
buntythecool is offline
Old 22-02-2007, 11:36 PM   #9 (permalink)
Google Bot
Pathik's Avatar
we r not discussing abt that dude... Btw pdfplus is the best pdf reader 4 fones
Pathik is offline
Old 23-02-2007, 12:10 AM   #10 (permalink)
ooopssss sorry
Old 23-02-2007, 12:15 PM   #11 (permalink)
amit2005's Avatar
i guess u've not read my question..my pal has 5.4mb material n i have 47mb of that same material..i want to know can compress it to tht size
ROCK IS HERE
amit2005 is offline
Old 24-02-2007, 09:29 AM   #12 (permalink)
Hells_Fury's Avatar
You can try something called PDF Compress. Get it HERE
Q6600 G0 (TR Ultra-120), ASUS P5N32-E SLI, eVGA 8800GTX Superclocked (TR HR-03 Plus), Samsung 940BW, Corsair Dominator PC2-8500, CM Stacker 830, 700GB Storage, Corsair HX620W, APC Smart 750VA
Hells_Fury is offline
Old 24-02-2007, 09:56 AM   #13 (permalink)
caleb's Avatar
^^nice suggestion
caleb is offline
Old 24-02-2007, 07:04 PM   #14 (permalink)
Resident Fanatic
Manshahia's Avatar
series 60 fones doesnt provide good quality when it comes to reading on fone.
Manshahia is offline
Old 24-02-2007, 08:06 PM   #15 (permalink)
18 Till I Die............
47 MB! what's in there man?
http://www.bash.org/?258908
mehulved is offline
Old 24-02-2007, 09:22 PM   #16 (permalink)
Resident Fanatic
Manshahia's Avatar
Encyclopedia
Old 24-02-2007, 10:37 PM   #17 (permalink)
amit2005's Avatar
textbook of surgery
ROCK IS HERE
amit2005 is offline
