Old 15-02-2007, 08:11 PM   #1 (permalink)
Unhappy help me in phone recording
hi I m using dataone broadband connection at home with adsl modem. can i record my phone calls with adsl modem or not? if yes then plz tell me name of the software for recording and configration too.
thx
sushantsaurabh is offline
Old 15-02-2007, 09:00 PM   #2 (permalink)
Arsenal_Gunners's Avatar
Default Re: help me in phone recording
^^No dude,you can do it with a dialup modem only.Use trx phone recorder software for dialup modems.(Also you cannot send fax with ADSL modem)
Arsenal_Gunners is offline
Old 16-02-2007, 10:41 PM   #3 (permalink)
Super Hero - Super Powers
n2casey's Avatar
Question Re: help me in phone recording
Hey Vimal, I m using a dialup modem but TRx doesn't support it. TRx always gives an error for hardware support.
I have tried Veritape & it works fine in Win 98 but not working properly in Win XP.
Is there any other good s/w for purpose??
Minds are like Parachutes :arrow: They work best when open
n2casey is offline
Old 16-02-2007, 10:44 PM   #4 (permalink)
Dude trx will work with all voice modems.Is your modem a "voice modem"
Old 16-02-2007, 10:46 PM   #5 (permalink)
n2casey's Avatar
Smile Re: help me in phone recording
Yes my modem is Voice-Data-Fax modem & is working fine with Veritape under Win 98 & with a little prob under Win XP coz Veritape is an old s/w & is not compatible with Win XP.
n2casey is offline
Old 16-02-2007, 10:50 PM   #6 (permalink)
^^Try compatibility mode
Ok i will find something.
__________
dude try this
http://www.nch.com.au/vrs/vrssetup.exe
Last edited by Arsenal_Gunners; 16-02-2007 at 10:55 PM. Reason: Automerged Doublepost
Old 16-02-2007, 11:16 PM   #7 (permalink)
The Thread Killer >:)
phreak0ut's Avatar
I use TRx and I find that as the best. You can even try Phone Recorder Plus. Its got LOADS of features compared to TRx, but I somehow still prefer TRx because its very light on the system. Try the link given by Vimal and let us know if there are any more queries.
Want to make this world a better place? Then, start seeding and don't be just a leecher :)
phreak0ut is offline
