Old 13-02-2007, 11:34 AM   #1 (permalink)
Default Connect me to net
Hey anyone can help me?????
I want to connect my lg c2500 for internet browing i have installed COM port drivers what next?? I have BSNL GPRS active on my cell
kapsp5001 is offline
Old 13-02-2007, 11:47 AM   #2 (permalink)
Crazy Kidd's Avatar
Default Re: Connect me to net
Where are you from??? Do you know the details about the charges of surfing net through BSNL. In Kolkata, West Bengal it is 10 paisa/KB. Its way too costly. And Do you have the software for LG. It would make the process of connecting to net easy. Inform.
And about BSNL GPRS, do you have the paid GPRS active on your cell or are you using CellOne Portal. Because if you are using CellOne Portal then you can't surf net on your PC with that. And LG gives slow speed (Samsung slowest though). So I'll ask you to reconsider. And if you are desperate then move to Airtel Mobile office @ Rs.249/month.
Crazy is what crazy does. So lets get crazy like hell.
Crazy Kidd is offline
Old 13-02-2007, 11:49 AM   #3 (permalink)
Google Bot
Pathik's Avatar
search the forum
Pathik is offline
