12-02-2007, 07:49 PM
How to format mini SD card
Hi guys, can any one tell me how to format a password protected mini SD card. Actually i have nokia 6270, i have given password to its memory card(512 MB mini SD Card) ; which now i have forgot.I try out with card reader but when i do this computer stops responding.
please help me........
Thanks in advanced.
12-02-2007, 08:01 PM
Re: How to format mini SD card
- Download & install free FExplorer
- Now browse through the file system > c:\system folder.
- Look for a file called "mmcstore"
- Rename the file to mmcstore.txt and then open it.
- Your password must be at end of the file.
Kiran Kumar R
12-02-2007, 08:07 PM
Nokia 6270 is S40 phone, FExplorer will not work on it. And password is in the memory card, bcoz i have fomatted the phone memory but it still prompt for password.
12-02-2007, 08:55 PM
Oops! I didn't checkout the model number properly...
Since you formatted the Phone memory, the password stored in phone memory is also lost now. It is not possible by any means to recover the password from phone. All you have to do is read from memory card reader. What is happening when u connect the card to PC?
Kiran Kumar R
12-02-2007, 10:51 PM
Google Bot
forget ur mini sd nw.. Thers no way in s40 to retrieve pwds.. U wont b able to access it even wit a card reader
13-02-2007, 12:01 PM
Pathik is right. But as a last resort try www.howardforums.com to see if there is any solution to this.
Crazy is what crazy does. So lets get crazy like hell.
13-02-2007, 04:16 PM
Ok Bad luck. Now tell me the cost of 512 MB as well as 1 GB mini SD Card in mumbai.
13-02-2007, 05:36 PM
Google Bot
512mb 500.. 1gb 940
14-02-2007, 02:23 PM
Hey pathik are the price original? With bill?
Go for a SanDisk or Kingston card.I'm not from Mumbai. So can't tell you the Mumbai price. But will post the price in Kolkata tonight.
14-02-2007, 08:18 PM
Google Bot
ncp prices... seems original to me..
__________
Reason: Automerged Doublepost
17-02-2007, 12:31 AM
Anyway thanks pathik. Will check and give feedback as soon as possible.
17-02-2007, 01:10 AM
Connect ur fone to pc thru data cable in "DATA TRANSFER' mode.After ur fone (mem crd) has been detected as a USB Mass Storage Device,try to format it.
17-02-2007, 01:14 AM
Possibility of that happening is 9:1. But give it a try. But believe me its gone.
17-02-2007, 01:18 AM
^^^ Its not gone.A device (MMC Unlocker) is available which does a hard format of any mem crd irrespective of whether its password protected or not.I've seen it here in a mobile repairing shop.
17-02-2007, 01:20 AM
Then supply more info on that.
17-02-2007, 01:23 AM
^^^ Wat infodo u want on MMC Unlocker.
17-02-2007, 01:26 AM
Where can he find one and some more light on the topic to help ritu get his card back. Thats all. Nothing personal
17-02-2007, 01:34 AM
Its nothing bout being personal dude.All i wanted toknow was wat sort of info do u want bout the MMC Unlocker,dats all.
I've seen the device at a local mobile repairing shop here in my home town (Durgapur).So i wont be able to tell ruturaj3 where he'll get it in Mumbai.I think he sud try the mobile repairing shops.
Also if his fones in warranty he cud give a visit to Nokia Care,maybe they can solve it.
17-02-2007, 01:43 AM
#19 (permalink)
OK.................Understood. Hey ritu, follow assasin and see if it works. Don't forget to post your feedback.
17-02-2007, 12:16 PM
#20 (permalink)
Hey guys , u are right , i have search that on google .Called as MMC Unlock clip.
http://gsmserver.com/hardware/mmc_clip.php
try this link.
I also asked my friend about this , he told me it cost around 350 Rs. in bandra(some local shops). I will check this out.
__________
Here is the image
http://imshopping.rediff.com/shoppin...nlock-Clip.JPG
17-02-2007, 12:32 PM
#21 (permalink)
Google Bot
we r not talking abt hardware here...
i had a few softwares that formatted mmcs w/o passwd....
like mmc medic etc.. try this formatter batch file...
use it carefully n select ur mmc drive only... be CAREFUL...
17-02-2007, 05:46 PM
#22 (permalink)
I have done it. I formatted my mini SD card from nokia N73,Now it is working fine. Thanks to all of U...........
