Old 12-02-2007, 02:06 AM   #1 (permalink)
mekalodu
iinfi's Avatar
Thumbs down Y! Messenger disconnects frequently on Reliance Netconnect
my Y! Messenger disconnects frequently on Reliance Netconnect ... every 3-4 mins....
n even whn its on for sometime i m unable to do a voice chat.
same is the case with eyeball chat n gtalk.
cud this be a server problem???
any other netconnect users facing the same problem??
plz help ...
mekalodu
iinfi is offline
Old 12-02-2007, 07:58 AM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: Y! Messenger disconnects frequently on Reliance Netconnect
does ur net conn itself drop or only the msgrs disconnect
Pathik is offline
Old 12-02-2007, 09:36 AM   #3 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
I'm too using RConnect (1500/- per month Unlimited plan) but I never faced such problem!
Are u using PING?
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 12-02-2007, 09:53 AM   #4 (permalink)
mekalodu
iinfi's Avatar
the net conn doesnt drop frequently ...
its messenger which disconnects.
if 2-3 messengers are on then all of them disconnect within seconds of each other though not always. (i.e if one goes the other stays on.)
as far as yahoo messenger is concern it simply logs me off and the other person gets a message that iinfi has logged off ...
@vishal: where r u based. i m frm navi mumbai !!
r u using ping means wat ?? wat to ping?? i m sry i didnt get u
mekalodu
iinfi is offline
Old 12-02-2007, 12:09 PM   #5 (permalink)
Microsoft MVP
I'm from U.P.
It seems that u arent using PING command, thats why u r having this problem.
Whenever u connect net, open RUN and type following command:
PING -t 202.138.96.2
It'll help u.
U can also make a shortcut on desktop for this command.
Old 12-02-2007, 01:43 PM   #6 (permalink)
Tech.Masti's Avatar
Are u using PING?
Rs.1500 pm unlimited plan they still running the old s*** plans ....why u don't take BSNL DataOne at Rs.900 unlimited??? BTW what the speeds???
and Vishal please tell me the cause of using ping command whenever someone connects net....
and is this also helps 4 Airtel MO???
Tech.Masti is offline
Old 12-02-2007, 05:28 PM   #7 (permalink)
Microsoft MVP
1.) This plan is no longer available for phones but its available for data cards. Existing customers having the unlimited plan (like me) are still enjoying it.
2.) BSNL service is not good here, frequently wire-cut problem and many other problems. So I'm happy with reliance.
3.) Speed is normal. I usually get 10 KBps download speed.
4.) Using PING prevents CDMA phones from going into "Dormancy Mode", whenever there is no data transfer, the phone automatically goes into Dormancy mode so that we can attend the phone calls while running net. But its quite annoying and thats why I use PING command.
Old 12-02-2007, 09:25 PM   #8 (permalink)
mekalodu
iinfi's Avatar
@Vishal Gupta:
i m using this pinging of the DNS Servers for a long time now. though it helps in not getting my connection into a dormancy mode, of late (past 2-3 weeks) it doesnt help my messengers from getting disconnected.
i wonder wat the problem is ... even whn i m typing this messenger has disconnected 2-3 times. the bigger trouble is its not jus yahoo which gets signed off ...all other messengers also have the same problem.
whn i signin using meebo.com everything works fine.... but i dont like meebo as i cannot do a voice chat with that or use a webcam.
there u go ... jus now gtalk n eyeball chat got disconnected ... (
mekalodu
iinfi is offline
Old 12-02-2007, 10:56 PM   #9 (permalink)
Google Bot
Pathik's Avatar
@techmasti no dude .. Its a r net connect cdma specific command.. Gsm fones hv a stable conn already
Pathik is offline
Old 12-02-2007, 11:12 PM   #10 (permalink)
Microsoft MVP
@iinfi
Thats strange that only ur IM get disconnected and not the whole internet.
Why not u scan ur computer, may be its a virus problem? Post ur HijackThis logfile and may be we'll get any suspected entry?
Old 12-02-2007, 11:30 PM   #11 (permalink)
Tech.Masti's Avatar
thanks Vishal & pathik....
Old 13-02-2007, 01:31 AM   #12 (permalink)
mekalodu
iinfi's Avatar
Unhappy Re: Y! Messenger disconnects frequently on Reliance Netconnect
here u go buddy ...
Logfile of HijackThis v1.99.1
Scan saved at 01:24:30 AM, on 13-02-2007
Platform: Windows XP SP2 (WinNT 5.01.2600)
MSIE: Internet Explorer v6.00 SP2 (6.00.2900.2180)
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\winlogon.exe
C:\WINDOWS\system32\services.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\system32\Ati2evxx.exe
C:\WINDOWS\system32\svchost.exe
C:\WINDOWS\System32\svchost.exe
C:\WINDOWS\system32\ZONELABS\vsmon.exe
C:\WINDOWS\Explorer.EXE
C:\WINDOWS\system32\spoolsv.exe
C:\Program Files\Alwil Software\Avast4\aswUpdSv.exe
C:\Program Files\Alwil Software\Avast4\ashServ.exe
C:\WINDOWS\system32\inetsrv\inetinfo.exe
C:\Program Files\Common Files\Microsoft Shared\VS7DEBUG\MDM.EXE
C:\Program Files\Alwil Software\Avast4\ashMaiSv.exe
C:\Program Files\Alwil Software\Avast4\ashWebSv.exe
C:\Program Files\ATI Technologies\ATI.ACE\cli.exe
C:\WINDOWS\RTHDCPL.EXE
C:\PROGRA~1\ALWILS~1\Avast4\ashDisp.exe
C:\Program Files\Java\jre1.5.0_06\bin\jusched.exe
C:\Program Files\DAEMON Tools\daemon.exe
C:\Program Files\QuickTime\qttask.exe
C:\Program Files\CyberLink\PowerDVD\PDVDServ.exe
C:\Program Files\Zone Labs\ZoneAlarm\zlclient.exe
C:\Program Files\DU Meter\DUMeter.exe
C:\Program Files\Common Files\Real\Update_OB\realsched.exe
C:\Program Files\TOPRO\TPPOLL.EXE
C:\WINDOWS\system32\ctfmon.exe
C:\Program Files\Spybot - Search & Destroy\TeaTimer.exe
C:\Program Files\Weather Watcher\ww.exe
C:\Program Files\WordWeb\wweb32.exe
C:\Program Files\YPOPs\YPOPs.exe
C:\Program Files\Qlock\qlock.exe
C:\WINDOWS\system32\WISPTIS.EXE
C:\Program Files\RConnect\RConnectDialer.exe
C:\Program Files\Mozilla Firefox\firefox.exe
C:\PROGRA~1\MICROS~2\OFFICE11\OUTLOOK.EXE
C:\Program Files\Microsoft Office\OFFICE11\WINWORD.EXE
C:\Program Files\Yahoo!\Messenger\YahooMessenger.exe
C:\hijackthis\HijackThis.exe
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Bar = http://us.rd.yahoo.com/customize/ie/...ch/search.html
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = http://us.rd.yahoo.com/customize/ie/.../www.yahoo.com
R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Int ernet Settings,ProxyOverride = local
R0 - HKCU\Software\Microsoft\Internet Explorer\Toolbar,LinksFolderName =
R3 - URLSearchHook: Yahoo! Toolbar - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - C:\Program Files\Yahoo!\Companion\Installs\cpn0\yt.dll
O2 - BHO: Yahoo! Toolbar Helper - {02478D38-C3F9-4EFB-9B51-7695ECA05670} - C:\Program Files\Yahoo!\Companion\Installs\cpn0\yt.dll
O2 - BHO: AcroIEHlprObj Class - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 7.0\ActiveX\AcroIEHelper.dll
O2 - BHO: (no name) - {37E1A9E5-00D4-4203-8E58-B91F383A3809} - (no file)
O2 - BHO: (no name) - {53707962-6F74-2D53-2644-206D7942484F} - C:\PROGRA~1\SPYBOT~1\SDHelper.dll
O2 - BHO: (no name) - {69A87B7D-DE56-4136-9655-716BA50C19C7} - (no file)
O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre1.5.0_06\bin\ssv.dll
O3 - Toolbar: (no name) - {BA52B914-B692-46c4-B683-905236F6F655} - (no file)
O3 - Toolbar: Yahoo! Toolbar - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - C:\Program Files\Yahoo!\Companion\Installs\cpn0\yt.dll
O4 - HKLM\..\Run: [ATICCC] "C:\Program Files\ATI Technologies\ATI.ACE\cli.exe" runtime -Delay
O4 - HKLM\..\Run: [RTHDCPL] RTHDCPL.EXE
O4 - HKLM\..\Run: [Alcmtr] ALCMTR.EXE
O4 - HKLM\..\Run: [avast!] C:\PROGRA~1\ALWILS~1\Avast4\ashDisp.exe
O4 - HKLM\..\Run: [NeroFilterCheck] C:\WINDOWS\system32\NeroCheck.exe
O4 - HKLM\..\Run: [SunJavaUpdateSched] C:\Program Files\Java\jre1.5.0_06\bin\jusched.exe
O4 - HKLM\..\Run: [DAEMON Tools] "C:\Program Files\DAEMON Tools\daemon.exe" -lang 1033
O4 - HKLM\..\Run: [KernelFaultCheck] %systemroot%\system32\dumprep 0 -k
O4 - HKLM\..\Run: [QuickTime Task] "C:\Program Files\QuickTime\qttask.exe" -atboottime
O4 - HKLM\..\Run: [RemoteControl] "C:\Program Files\CyberLink\PowerDVD\PDVDServ.exe"
O4 - HKLM\..\Run: [Zone Labs Client] "C:\Program Files\Zone Labs\ZoneAlarm\zlclient.exe"
O4 - HKLM\..\Run: [DU Meter] C:\Program Files\DU Meter\DUMeter.exe
O4 - HKLM\..\Run: [Sony Ericsson PC Suite] "C:\Program Files\Sony Ericsson\Mobile2\Application Launcher\Application Launcher.exe" /startoptions
O4 - HKLM\..\Run: [TkBellExe] "C:\Program Files\Common Files\Real\Update_OB\realsched.exe" -osboot
O4 - HKLM\..\Run: [TPPOLL] C:\Program Files\TOPRO\TPPOLL.EXE
O4 - HKCU\..\Run: [ctfmon.exe] C:\WINDOWS\system32\ctfmon.exe
O4 - HKCU\..\Run: [SpybotSD TeaTimer] C:\Program Files\Spybot - Search & Destroy\TeaTimer.exe
O4 - HKCU\..\Run: [WeatherWatcher] C:\Program Files\Weather Watcher\ww.exe
O4 - Startup: YPOPs.lnk = ?
O4 - Startup: qlock.lnk = C:\Program Files\Qlock\qlock.exe
O4 - Global Startup: WordWeb.lnk = C:\Program Files\WordWeb\wweb32.exe
O4 - Global Startup: Adobe Reader Speed Launch.lnk = C:\Program Files\Adobe\Acrobat 7.0\Reader\reader_sl.exe
O4 - Global Startup: Microsoft Office.lnk = C:\Program Files\Microsoft Office\Office10\OSA.EXE
O4 - Global Startup: Adobe Gamma Loader.exe.lnk = C:\Program Files\Common Files\Adobe\Calibration\Adobe Gamma Loader.exe
O8 - Extra context menu item: &Clean Traces - C:\Program Files\DAP\Privacy Package\dapcleanerie.htm
O8 - Extra context menu item: &Download with &DAP - C:\Program Files\DAP\dapextie.htm
O8 - Extra context menu item: Download &all with DAP - C:\Program Files\DAP\dapextie2.htm
O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~2\OFFICE11\EXCEL.EXE/3000
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.5.0_06\bin\ssv.dll
O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.5.0_06\bin\ssv.dll
O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~2\OFFICE11\REFIEBAR.DLL
O9 - Extra button: Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O9 - Extra 'Tools' menuitem: Windows Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O16 - DPF: {30528230-99f7-4bb4-88d8-fa1d4f56a2ab} (YInstStarter Class) - C:\Program Files\Yahoo!\Common\yinsthelper.dll
O17 - HKLM\System\CCS\Services\Tcpip\..\{C7F7AB61-0FE3-4CAF-A2A7-DFC71044E4E2}: NameServer = 202.138.97.193 202.138.96.2
O18 - Protocol: livecall - {828030A1-22C1-4009-854F-8E305202313F} - C:\PROGRA~1\MSNMES~1\MSGRAP~1.DLL
O18 - Protocol: ms-help - {314111C7-A502-11D2-BBCA-00C04F8EC294} - C:\Program Files\Common Files\Microsoft Shared\Help\hxds.dll
O18 - Protocol: msnim - {828030A1-22C1-4009-854F-8E305202313F} - C:\PROGRA~1\MSNMES~1\MSGRAP~1.DLL
O23 - Service: avast! iAVS4 Control Service (aswUpdSv) - Unknown owner - C:\Program Files\Alwil Software\Avast4\aswUpdSv.exe
O23 - Service: Ati HotKey Poller - ATI Technologies Inc. - C:\WINDOWS\system32\Ati2evxx.exe
O23 - Service: ATI Smart - Unknown owner - C:\WINDOWS\system32\ati2sgag.exe
O23 - Service: avast! Antivirus - Unknown owner - C:\Program Files\Alwil Software\Avast4\ashServ.exe
O23 - Service: avast! Mail Scanner - Unknown owner - C:\Program Files\Alwil Software\Avast4\ashMaiSv.exe" /service (file missing)
O23 - Service: avast! Web Scanner - Unknown owner - C:\Program Files\Alwil Software\Avast4\ashWebSv.exe" /service (file missing)
O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files\Common Files\InstallShield\Driver\11\Intel 32\IDriverT.exe
O23 - Service: OracleOraHome92TNSListener - Unknown owner - D:\oracle\ora92\BIN\TNSLSNR.exe
O23 - Service: OracleServiceARVIND - Unknown owner - d:\oracle\ora92\bin\ORACLE.EXE (file missing)
O23 - Service: TrueVector Internet Monitor (vsmon) - Zone Labs, LLC - C:\WINDOWS\system32\ZONELABS\vsmon.exe
C:\Program Files\DAEMON Tools\daemon.exe this is some game crack which my bro has installed ... this has been in my system for almost 2 years now.
C:\Program Files\TOPRO\TPPOLL.EXE this seems to be my webcam software
i dont understand what R1 O2 O4 are for .. now guruji ur turn ...
mekalodu
iinfi is offline
Old 13-02-2007, 02:38 PM   #13 (permalink)
Microsoft MVP
I didnt find any suspected entry. But u can fix following entries, may be it help?
Old 14-02-2007, 08:20 AM   #14 (permalink)
mekalodu
iinfi's Avatar
thanks .. i will chk it n let u know ...
mekalodu
iinfi is offline
Old 14-02-2007, 01:43 PM   #15 (permalink)
Crazy Kidd's Avatar
Reliance net are reliable (Finally something from Reliance that is reliable).
Have you checked by changing the version of messenger. Try using a stable version instead of a new beta version.
Crazy is what crazy does. So lets get crazy like hell.
Crazy Kidd is offline
Old 16-02-2007, 07:45 AM   #16 (permalink)
mekalodu
iinfi's Avatar
@Vishal Gupta:
issue persists
@Crazy Kidd
8.1.0.239 is the version of my yahoo messenger
__________
koi madath karo...plz plz ..
mekalodu
iinfi is offline
Old 16-02-2007, 07:51 AM   #17 (permalink)
Still Shining!
Lucky_star's Avatar
1.) ....
Only 10 KBps for a person like you
Nokia N86 8MP
Lucky_star is offline
Old 16-02-2007, 01:49 PM   #18 (permalink)
Microsoft MVP
^^ Yeah! Its true and now-a-days I can't download anything in daytime.
Old 20-02-2007, 12:51 AM   #19 (permalink)
mekalodu
iinfi's Avatar
i installed 8.0.0.682 .. the previous version which i had after removing all previous traces of yahoo messenger and it still does the same....
mekalodu
iinfi is offline
