Old 11-02-2007, 08:03 AM   #1 (permalink)
Default SE Z550i Low Ringtone-Help
I have purchased SE550i-3 weeks, wonderful featured phone for Rs. 7500/-.
Can any one suggest me for the following;
-My Ringtone volume is very low, suggest any higher volume ringtone.
-Tips to increase Battary Life, Now I am getting only 8 Hours.
gcbeldar is offline
Old 11-02-2007, 09:19 AM   #2 (permalink)
krazyfrog
Posts: n/a
Default Re: SE Z550i Low Ringtone-Help
1. For higher volume use mp3 format ringtones.
2. To increase battery life, go to settings>display settings and decrease the brightness level down to min. (50 %)
Old 11-02-2007, 06:53 PM   #3 (permalink)
Google Bot
Pathik's Avatar
use ur fones powersaving mode... if idle the display ll shut off... also lower the display brightness
Pathik is offline
Old 11-02-2007, 11:52 PM   #4 (permalink)
Crazy Kidd's Avatar
Problem with MIDI tunes are that they don't sound same on all handset(of different make). So MP3 tunes should do the trick to some extent, but don't expect miracle. Try MI2 or Mortal Combat tunes. Usually they are loud.
And about battery 8 hours is too short. What do you do with your phone? If you talk on it too much use GPRS continuously then none can help you. But if battery drains without any reason then something is wrong with it. Check it at a Service Center. And also follow the solution given by Pathik to see if it works for you.
Crazy is what crazy does. So lets get crazy like hell.
Crazy Kidd is offline
Old 12-02-2007, 02:12 AM   #5 (permalink)
mekalodu
iinfi's Avatar
i v the same fone .. n i m using mp3 as a ringtone n it seems pretty fine..
the only problem is the flap is shaking a lot inspite of me taking very good care of it.
i think the flap will come off in another 1-2 months time ... i m dead sure ..
mekalodu
iinfi is offline
Old 12-02-2007, 06:35 AM   #6 (permalink)
rajasekharan's Avatar
switch off the vibration mode . that helps a lot .switch off clock when in idle state .
Make a day good , and another day good , and another ...a happy lad is "born" from you :)
rajasekharan is offline
Old 14-02-2007, 02:42 PM   #7 (permalink)
Crazy Kidd's Avatar
Allmost all flap phones have the same problem. But you have gone a extra yard forward. The hinge is the weakest point in the phone.
Old 08-04-2007, 11:42 PM   #8 (permalink)
Sridhar_Rao's Avatar
I am an unfortunate user of that damn SE z550i. I have the same problem too, I shall try the mp3 ringtones and check, by the way see the post in this thread http://www.thinkdigit.com/forum/mobiles-tablets/54310-opinion-solicited-sony-erricson.html#post468173
Want to study M.Sc in any medical subjects? Read this www.microrao.com/msc.htm
Microx, a diagnostic microbiology laboratory software application www.labmicrox.com
Sridhar_Rao is offline
Old 08-04-2007, 11:54 PM   #9 (permalink)
mekalodu
iinfi's Avatar
damn SE z550i ????
why yaar ??
its a pretty gud fone ...
i think even the default ringtones are loud enough to hear in busy sunday market .... i can hear it ring !!
mekalodu
iinfi is offline
