Old 10-02-2007, 06:57 PM   #1 (permalink)
Rockstar11's Avatar
Unhappy Nokia N73 ME Headset hissing noise..
Hello I am a new user of N73 ME..
MY N73 ME firmware Version:
3.0638.0.0.30
30-10-2006
RM-133
Nokia-N73(Z5.01)
i wanna know where can i download the latest firmware?
Version 3.0649.0.0.31 - MUSIC EDITION
30-11-2006
RM-133
Official Nokia changelog
Implemented Improvements between 3.0638.0.0.30 and 3.0649.0.0.31
Audio – call waiting: Very quiet call waiting tone.
Audio – headset: Headset hissing noise.
Audio – tuneplayer: Unhandled aborts.
Browser – Security: RSA signing vulnerability.
Browser – OSS browser: OSS browser will not release memory after browsing several pages even after History turned off.
Bluetooth – UI: BT UI stops responding after pressing right softkey twice fast.
Call – establishment: "Call Not Allowed" displayed when attempting to make a call.
Call – Video call: "App closed: Video call" is showing after the alerting video call is interrupted.
Camera – stability: Camera freezes after taking picture.
Camera – Video Recorder: Video does not shut down when slide closed.
Camera – Video Recorder: Recorded video suffers from visible mains flicker.
Camera – Video Recorder: Video recording saving sometimes fails.
Contacts – voice dialling: name is mirrored when the contact is in Hebrew.
Gallery – Icon List: Wrong toolbar icons in gallery when started with video as last taken item.
Gallery – Review: Review key does not open media gallery.
Gallery – Zoom: Cannot zoom more than 50% in Gallery.
Memory – free memory: Gallery crashes when exiting from free memory.
MMS – Images: First thumbnail not shown when inserting image into MMS.
OMA – Device Management: 405 is returned for REPLACE command. (CMCC)
Phone – Stability: ASIC causing reboot.
Profiles – Silent mode: N73 failed to power off when the profile was set to “Silent”.
Settings – Say Callers name: Reboot happening with combination of 3D Audio, MP3, Say callers name and 3D effects.
Settings – Settings wizard: wrong region info in setting wizard. (Taiwan)
UI – Active Idle: Bold text in active idle.
UI - General Settings: Cangjie input method is not available to choose in phone general setting option. (China)
Visual Radio -basic functionality: Volume cannot be muted with IHF.
Voice command – voice tags: Problem creating new voice tag.
can anyone help me out and direct me on how to download the new firmware?
Thanks in advance..
Rockstar11 is offline
Old 10-02-2007, 07:05 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: Nokia N73 ME Headset hissing noise..
u can update ur fone s firmware using NSU (nokia software updater)
http://nokia.com/softwareupdate
http://www.nokia.com/A4176110
http://www.nokia.com/A4176089
Pathik is offline
Old 11-02-2007, 03:55 AM   #3 (permalink)
Rockstar11's Avatar
Hello pathiks
Nokia N73 music edition (Version 3.0649.0.0.31) firmware not available..
my N73 music edition problem.
When I plug in my earphones (using the nokia AD-41 adaptor) I can hear some hissing noise even though nothing is running and playing.
When I start playing audio I can still hear this noise in the background and When a song starts or ends there is a loud tick noise...
Anyone else notice this?
i am using the original nokia ( HS-28 ) headset that was comming with the phone.
What can i do? Pleas help me..
Mobile - Nokia N73 music edition
Headset: HS-28
Audio adapter: AD-41
Old 11-02-2007, 09:24 AM   #4 (permalink)
krazyfrog
Posts: n/a
There is no problem with the headset. The problem lies within the phone. Future firmwares will definitely solve the problem.
Old 11-02-2007, 02:11 PM   #5 (permalink)
Noobie Pro
alsiladka's Avatar
Keep checking the NSU regularly for the Firmware update.
As pointed out int he Changelog, the problem is with the Firmware.
You can also go to the nearest Nokia Care center near you and ask which is the latest firmware available for your cell and if the newer version is available, then get your cell updated.
www.twitter.com/alsiladka
alsiladka is offline
Old 11-02-2007, 06:24 PM   #6 (permalink)
pra_2006's Avatar
hey i also buyied new N73ME yesterday and i have checked both Headset: HS-28
Audio adapter: AD-41 working fine i think u should go to nokia shop
pra_2006 is offline
Old 11-02-2007, 11:59 PM   #7 (permalink)
Crazy Kidd's Avatar
Have you checked your sources. I'm talking about the music files you are playing. I know I may sound silly but i've faced similar problem with one of my friend. His songs bitrate was too low and hissing noise was there. But when I used a freshly encoded song directly from original CD it was playing ok. So ensure that isn't the case.
And check your headphone on another phone if possible. Just to check that headphone is not faulty.
If that isn't the case then visit a Service Center to check your headset.
Else wait for the next firmware update and see if it solves your problem.
Crazy is what crazy does. So lets get crazy like hell.
Crazy Kidd is offline
Old 19-02-2007, 10:40 PM   #8 (permalink)
Rockstar11's Avatar
hello friends
i m back..
hm...
There is no problem with the headset. The problem within the phone.
yes u r rite @ krazyfrog
yes my mp3 songs encoded directly from original CD. 320 kbps mp3s
@ Crazy Kidd
so friends
problem Mobile mein hi hai...
