Old 08-02-2007, 03:10 PM   #1 (permalink)
Alive Again...
satyamy's Avatar
Question Bluetooth from PC to Mobile........??
I went to my doctor for regulary check-up
their i saw
one man (doc. frnd) came & he on' his cell phones blue tooth
& doc double click on a button in his desktop (which says bluetooth)
after this that man say i found one (intel PIV) doc. said that mine
& than doc. also find one mobile in his PC network
& he transfered some songs & games from PC to Mobile using bluetooth
Doc. CPU was at the bottom of table, only he has his LCD monitor & mouse on top
& the distance of man's phone & doc. was around 3-4 feet
Can someone tell me how does he do that
Is their any software to tranfer files using bluetooth from PC to Cell
or is their any extra device attached to doc. PC
how does he do that
Pls help...................
satyamy is offline
Old 08-02-2007, 03:21 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: Bluetooth from PC to Mobile........??
lol u hv to hav a bluetooth dongle 4 that.. Install its drivers and u can send/receive files ..connect to gprs on pc,establish a bluetooth pan etc etc
Pathik is offline
Old 08-02-2007, 03:24 PM   #3 (permalink)
Alive Again...
satyamy's Avatar
Question Re: Bluetooth from PC to Mobile........??
can u pls explain that in simple language
what is Bluetooth Dongle......?
satyamy is offline
Old 08-02-2007, 03:30 PM   #4 (permalink)
Noobie Pro
alsiladka's Avatar
Get yourself a Bluetooth Dongle and install the software provided by it.
Enable the Bluetooth on your Mobile phone and pair it with yout computer.
You can now Dial Up using your Mobile phone as well as share files between the two.
www.twitter.com/alsiladka
alsiladka is offline
Old 08-02-2007, 03:32 PM   #5 (permalink)
Alive Again...
satyamy's Avatar
from where i can buy this Bluetooth Dongle
satyamy is offline
Old 08-02-2007, 03:33 PM   #6 (permalink)
Arsenal_Gunners's Avatar
BT Dongle is an instrument used to send and receive data on a pc via BT.
Arsenal_Gunners is offline
Old 08-02-2007, 03:37 PM   #7 (permalink)
Google Bot
Pathik's Avatar
u can get a bt dongle 4m any hardware shop.. It shd cost u arnd 200rs.. Get a bluesoliel one
Pathik is offline
Old 08-02-2007, 03:40 PM   #8 (permalink)
Alive Again...
satyamy's Avatar
oh thanks a lot friends
satyamy is offline
Old 08-02-2007, 03:47 PM   #9 (permalink)
Alive Again...
satyamy's Avatar
is this bluetooth Dongle
satyamy is offline
Old 08-02-2007, 04:03 PM   #10 (permalink)
Noobie Pro
alsiladka's Avatar
Yes, it is a bluetooth dongle.
Look over here if you want to use Nokia PC Suite with BlueSoleil Bluetooth Dongle, which is probably the one you are going to get.
http://www.thinkdigit.com/forum/showthread.php?t=48612
Old 08-02-2007, 05:54 PM   #11 (permalink)
Google Bot
Pathik's Avatar
yup it is
Pathik is offline
Old 09-02-2007, 04:12 PM   #12 (permalink)
nik_for_you's Avatar
man be upgraded with technology or you will be lost
I AM REBEL
nik_for_you is offline
Old 09-02-2007, 04:47 PM   #13 (permalink)
Google Bot
Pathik's Avatar
wat do u mean nik?????
Pathik is offline
