Old 06-02-2007, 02:43 AM   #1 (permalink)
Anindya's Avatar
Question Is Nokia6030 EDGE enabled?
I would like to know whether Nokia6030 EDGE enabled or not? Also plz tell me which phones are EDGE enabled within Rs.5000-5500?
www.techani.com
Latest post ->Take Ur Applications & Personal Settings With You
->Umpires Are Vampires
The Most Unknolegeble Parson. Plese Tech Me.
Anindya is offline
Old 06-02-2007, 08:38 AM   #2 (permalink)
Wise Old Crow
blueshift's Avatar
Default Re: Is Nokia6030 EDGE enabled?
Nokia 6030 does not have EDGE.
You can search for your requirements here.
http://www.univercell.in/search.asp
But in that range you will get only Class 6 EDGE phones that means your download speed will be same as for GPRS.
http://twitter.com/blueshift155
blueshift is offline
Old 06-02-2007, 09:03 AM   #3 (permalink)
Google Bot
Pathik's Avatar
yea man 6030 is not a EDGE fone... I dont think u ll get any edge fones in that budget
Pathik is offline
Old 06-02-2007, 09:23 AM   #4 (permalink)
ponzi
Posts: n/a
nope
my mom hs a 6030 and it definatly aint egde enabled!
Old 06-02-2007, 09:41 AM   #5 (permalink)
krazyfrog
Posts: n/a
If you increase your budget slightly you can get SE Z530i which has EDGE Class 10
Old 06-02-2007, 06:30 PM   #6 (permalink)
Wise Old Crow
blueshift's Avatar
&krazyfrog, Z530i does not have EDGE.
Old 06-02-2007, 06:36 PM   #7 (permalink)
Hey here is the aks
arunks's Avatar
not at all
yours truly
arun
The aks!!
have a nice day
arunks is offline
Old 06-02-2007, 06:38 PM   #8 (permalink)
krazyfrog
Posts: n/a
^^ Yes you're right. I'm sorry. In that case he should go for Nokia 6070 or Nokia 3220 both of which have EDGE Class 6
Old 06-02-2007, 11:16 PM   #9 (permalink)
Anindya's Avatar
Question Re: Is Nokia6030 EDGE enabled?
Then friends can u tell me which set has Edge 10 through which can give better download speeds? My only requirement is Edge enabled set through which i can surf. I am looking for that requirement at the minimum budget. please help. Since i came to know just now that Edge6 is equal to GPRS then fine I will go for Edge10 but recommend me a set with min. price.
www.techani.com
Anindya is offline
Old 06-02-2007, 11:24 PM   #10 (permalink)
Wire muncher!
infra_red_dude's Avatar
surely 6070... the 3220 and 3200 are old but do haf edge....
infra_red_dude is offline
Old 06-02-2007, 11:30 PM   #11 (permalink)
Wise Old Crow
blueshift's Avatar
w300i (Rs 8500/-)
Old 06-02-2007, 11:32 PM   #12 (permalink)
Google Bot
Pathik's Avatar
@anindya give ur maxxx budget
Pathik is offline
Old 06-02-2007, 11:55 PM   #13 (permalink)
Anindya's Avatar
Exclamation Re: Is Nokia6030 EDGE enabled?
@PATHIK I am looking for the lowest price but the requirement is EDGE10.
www.techani.com
Anindya is offline
Old 07-02-2007, 12:02 AM   #14 (permalink)
Google Bot
Pathik's Avatar
U can get a 2nd hand 6630 4 5k easily.. its the cheapest 3g fone.. And is s60 too
Pathik is offline
