Old 04-02-2007, 08:02 PM   #1 (permalink)
Wise Old Crow
blueshift's Avatar
Default Whts this icon on mob?
I have SE w300i mob. From last few hrs I am seeing this small little squared arrow on the up-left corner. What does it denote?
http://twitter.com/blueshift155
blueshift is offline
Old 04-02-2007, 08:13 PM   #2 (permalink)
Tech Geek's Avatar
Default Re: Whts this icon on mob?
Can you send a Picture of it?
Tech Geek is offline
Old 04-02-2007, 08:22 PM   #3 (permalink)
MysticDews's Avatar
wud be better if u post in a pic of it...
Coz this cud be something similar to wot i got on my Nokia 3230 once...
It is shown if there are some active call diverts...try turning em off...If it is goes then it is for it...
________________________________________________
In love with my Mac 
MysticDews is offline
Old 04-02-2007, 08:41 PM   #4 (permalink)
Google Bot
Pathik's Avatar
yea man give a pic... btw i think it shd mean msgs stuck in outbox...
Pathik is offline
Old 04-02-2007, 08:49 PM   #5 (permalink)
Wise Old Crow
blueshift's Avatar
sorry..i couldn't put in a better way. Thi is the image.
Old 04-02-2007, 08:58 PM   #6 (permalink)
Google Bot
Pathik's Avatar
check ur outbox man...
Pathik is offline
Old 04-02-2007, 09:04 PM   #7 (permalink)
Noobie Pro
alsiladka's Avatar
That icon is either for a missed call or an unsent message in your outbox. Check both these places once and report back to us.
www.twitter.com/alsiladka
alsiladka is offline
Old 04-02-2007, 09:50 PM   #8 (permalink)
krazyfrog
Posts: n/a
It is for a missed call. Go to your call log and then to missed call. Then the icon will go.
Old 04-02-2007, 10:06 PM   #9 (permalink)
Noobie Pro
alsiladka's Avatar
For missed call, the arrow on nokia is on the left hand side and not the right side.
Hence cant deduce for sure if its a missed call only.
Old 04-02-2007, 10:08 PM   #10 (permalink)
Still Shining!
Lucky_star's Avatar
Its simply a missed call alert symbol.
Download the W300 manual here. There you can find a detailed description of the symbols used in the phone
Nokia N86 8MP
Lucky_star is offline
Old 04-02-2007, 10:17 PM   #11 (permalink)
Wise Old Crow
blueshift's Avatar
Ya..its a missed call alert.
Thanks.
