Old 02-02-2007, 07:52 PM   #1 (permalink)
foreign return(0)
comrade's Avatar
Default lg kg200?
i have a year old nokia 6260 which am going to sell it for Rs.6000 & get myself a brand new LG KG200....
will it be a good replacement? how kg200 compares with old 6260
comrade is offline
Old 02-02-2007, 07:54 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: lg kg200?
rather take a w550i
Pathik is offline
Old 02-02-2007, 07:59 PM   #3 (permalink)
foreign return(0)
comrade's Avatar
but w550i costs more than 9000 rite? out of my budget
comrade is offline
Old 02-02-2007, 08:14 PM   #4 (permalink)
Google Bot
Pathik's Avatar
Afair it costs arnd 7.6k
Pathik is offline
Old 02-02-2007, 08:25 PM   #5 (permalink)
foreign return(0)
comrade's Avatar
that looks like a good deal but from the pictures i seen it looks like as if i have to use headfone all the time even if i got a make/receive calls...true?
comrade is offline
Old 02-02-2007, 11:26 PM   #6 (permalink)
Google Bot
Pathik's Avatar
no man.. U dont need a headfone to make/receive calls.. U can do that normally too..
Pathik is offline
Old 03-02-2007, 06:41 AM   #7 (permalink)
krazyfrog
Posts: n/a
W550i costs 9.8k. Instead you can go for Z550i.
Old 03-02-2007, 10:24 AM   #8 (permalink)
Stay away from LG
Stick is offline
Old 03-02-2007, 10:57 AM   #9 (permalink)
Still Shining!
Lucky_star's Avatar
As pathiks said, go for SE w550i. Its worth the price. And it costs Rs. 800 more than your budget only. But its features are above par with A LG KG200.
First off all, it doesn't feature MP3 ringtones. Moreover, it has only 60 MB shared memory compared to the 256 MB in w550i.
Read the complete comparison between the two phones here
Nokia N86 8MP
Lucky_star is offline
Old 05-02-2007, 05:00 PM   #10 (permalink)
Mr. S Nova
supernova's Avatar
one thing u'll hate about LG the most is the BATTERY BACKUP
rest.. LG could be value for money phone
Knock Knock. Who's there? Opportunity. Can't be, opportunity knocks only once...
supernova is offline
Old 05-02-2007, 05:36 PM   #11 (permalink)
dhan_shh's Avatar
Remember,in LG KG200 there is
NO Bluetooth
NO infrared
NO java support for games
if OK,proceed with it ,otherwise check Nokia 5200(7.8K)
or Samsung SGH-E250 (7.4K),these are cost-effective and with plenty of features!
dhan_shh is offline
Old 05-02-2007, 05:40 PM   #12 (permalink)
As per me it's Customer Service, keep all of us out from them.
Stick is offline
Old 06-02-2007, 08:09 PM   #13 (permalink)
LG C2600 seems to be a gud phone,will lg kg200 will be better than that?
ksundar is offline
Old 07-02-2007, 02:39 PM   #14 (permalink)
dhan_shh's Avatar
Sure,LG K200 has 1.3MP cam,FM Recording facility,Memory Slot for expansion which are lacking in LG C2600 even though it has 128MB internal memory.
Compare to lg c2600,k200 it a better choice!
dhan_shh is offline
Old 07-02-2007, 05:02 PM   #15 (permalink)
Cool G5's Avatar
Lightbulb Re: lg kg200?
Don't go for LG KG 200.Like the other said it does not have bluetooth.Also the signal of lg phones are weak.I suggest u go for a nokia(N6070).SE(z550i) is not bad but you have to shell out a bit for their memory card.
Cool G5 is offline
Old 07-02-2007, 10:35 PM   #16 (permalink)
foreign return(0)
comrade's Avatar
i got the phone today for Rs.6400...much satisfied with its look, sound & its functionalities.
but the only missing thing is bluetooth & support for java which am not going to seek for.
not worried abt the service too..as only today i learned a lesson from nokia care to get my old mobile repaired...thats another story.
batter backup lasting for 2 days for me...sifficient i think with the usb charging need not worry much abt it. mp3 quality is comparable to SE(bcoz of graphic equalizer)..although fm is not that much sounding..
i decided to keep my 6260 with me as it looks like now antique.
comrade is offline
