Old 01-02-2007, 07:55 PM   #1 (permalink)
9437077259
go4saket's Avatar
Default Nokia 5300 Or Nokia 3250???
Hi guys!
Please help me to decide weather should I go for Nokia 5300 or Nokia 3250. Apart from looks, features, camera quality and music quality is what matters to me the most.
Nokia 5300 is a S40 series phone while Nokia 3250 is a S60 series phone. What exactly is the difference between both and which is better?
Please suggets.
Chao.
Win 7 Ultimate
Abit IP35-E Mobo,C2Q 6600,4GB DDR2 RAM,XFX 8600GT 256MB DDR3 Gfx ,Seagate 1TB HDD,Sony DVD RW,500w SMPS,19" Viewsonic VX922 TFT,Logtech G5 Mouse,Altec Lancing 2:1 Speakers.
go4saket is offline
Old 01-02-2007, 08:26 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: Nokia 5300 Or Nokia 3250???
there is a great price diff btw them man.... 3250 is better neday...
3250 beter cam n sound n os9.1...
Pathik is offline
Old 01-02-2007, 08:53 PM   #3 (permalink)
Tech Geek's Avatar
5300
Tech Geek is offline
Old 01-02-2007, 09:06 PM   #4 (permalink)
ANGEL OF DEATH
NIGHTMARE's Avatar
Post Re: Nokia 5300 Or Nokia 3250???
3250+1
Dell 15z + WD 2TB
Dell Studio 1555 + WD 1TB
iPhone 4 32 GB
Samsung Galaxy S2 White
Good Desktop Power Of C2D + 4850
NIGHTMARE is offline
Old 01-02-2007, 09:35 PM   #5 (permalink)
krazyfrog
Posts: n/a
Go for 3250 ME at 13.6k
Old 01-02-2007, 10:35 PM   #6 (permalink)
Resident Fanatic
Manshahia's Avatar
in 3250 u will b able to install new softwares like yahoogo, fexplorer etc..
U will b having great sound,looks,camera etc with 3250
and nothing with 5300
Manshahia is offline
Old 01-02-2007, 11:47 PM   #7 (permalink)
Noobie Pro
alsiladka's Avatar
S60 is a Multi Tasking and Customizable Operating System.
S40 -
- Not Customizable
- A very very miniscule Java App support
- Does not support the Symbian applications.
- Can run only one app at a time
S60
+ Very User friendly and customizable
+ An extremely wide range of Heavy Duty Java Apps, Flashlite Content, Symbina Applications
+ Can run many applications at a time
Apart from the OS, 3250 wins hands down in every field. 5300 looks very cheap and boyish, 3250 has a better look and feel to it. If you can afford 3250, dont even think about 5300 compared to 3250.
If people warn you that 3250 has a bad camera and is very slow, just ask them to upgrade to firmware version 4.14 and see the speed. I use a 3250 , and definitely recommend it.
www.twitter.com/alsiladka
alsiladka is offline
Old 02-02-2007, 01:21 AM   #8 (permalink)
assasin's Avatar
3250
assasin is offline
Old 06-02-2007, 11:04 PM   #9 (permalink)
S40 -
- Not Customizable
S60
T Q sir,
is it easy to upgrade firmware for 3250 and how?
gcbeldar is offline
Old 06-02-2007, 11:32 PM   #10 (permalink)
Noobie Pro
alsiladka's Avatar
Originally Posted by gcbeldar
T Q sir,
It is extremely easy, no user intervention is required.
1. Just go to nokia.com/softwareupdate and download the Software Updater.
2. Install it and connect yout phone to the computer using the Data Cable.
3. Make sure your phone is fully charged as any mistake or error in this process could leave your phone dead.
4. Look for an update, select update and sit back and relax.
PS- Be ready to download something round about 60+ MB.
Old 06-02-2007, 11:39 PM   #11 (permalink)
Google Bot
Pathik's Avatar
@gcbeldar u can update almost ny fones firmware using nokia software updater.. Its too easy nw
Pathik is offline
Old 07-02-2007, 02:39 PM   #12 (permalink)
D PrankMaster
prankie's Avatar
between N5300 and N3250, i wud recommend N3250.. coz its a smart phone... as far as my experience with this phone goes, except the camera, every thing in this fone are great... but if u wanna look for other options then u can go for N70 too... it has a better camera, flash, 3G and great sound too...
My Rig: AMD Phenom II 550BE | Gigabyte GA880GM-USB3| Sapphire HD6850 | 2x4GB Corsair Vengeance DDR3 1600Mhz | 2x500GB Seagate HDD | Silverstone Strider 500W | Alteclansing Octane 7 | Microsoft Natural Ergonomic 4000 | Logitech MX518 | Rantopad H1 | APC 0.6KVA
My Gadgets: Nikon D3100 | PSP1000 | XBOX360 20GB | Sansa Clip+ | Soundmagic PL50 | Meelectronics M9BK
prankie is offline
