Old 31-01-2007, 03:20 AM   #1 (permalink)
Generic Superhero's Avatar
Default Opera mini not working on Airtel+nokia
I have nokia 6030 and airtel NOP service - some people call it airtel wap service. i cant use any internet apps on my cell. these apps need an access point and there is no provision in my phone to specify proxy details while setting up access point, and airtel connection needs the proxy to work.
bsnl works without proxy so i hav no problem with bsnl.
i have found this problem in all series 40 phones.
is this a genuine problem or am i being dumb?
Nipon
Generic Superhero is offline
Old 31-01-2007, 07:47 AM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: Opera mini not working on Airtel+nokia
afaik operamini works in all s40 fones wit nop as well as mo..
Pathik is offline
Old 01-02-2007, 10:25 AM   #3 (permalink)
i have tested with Nokia 5200 it works. Since that was not my set i cant tell you the settings but it sure does work
Pakka Pakka
Freeze it
Experience Is not Counted in Years.. But in the Countless Effort
www.kolasib.com www.zoram.org
valtea is offline
Old 01-02-2007, 10:45 AM   #4 (permalink)
hailgautam's Avatar
Airtel wap will not work to access HTML sites. Only Mobile Office will work to access HTML sites. Therefore your Opera Mini will not work to access HTML sites.
Change is Nature, the part that we can influence; and it starts when we decide.
Where you going?
With Luck forward.
hailgautam is offline
Old 01-02-2007, 11:14 AM   #5 (permalink)
Google Bot
Pathik's Avatar
NOP works wit opera mini seamlessly in s40 fones be it to access wap/web sites...
Pathik is offline
Old 03-02-2007, 02:34 PM   #6 (permalink)
Crazy Kidd's Avatar
Opera mini won't work if the connection type is wap. It will work if the connection type is HTTP. And one more thing officially NOP doesn't support any applications. But like we care.
Crazy is what crazy does. So lets get crazy like hell.
Crazy Kidd is offline
Old 03-02-2007, 03:57 PM   #7 (permalink)
Google Bot
Pathik's Avatar
Officially..
Pathik is offline
Old 06-02-2007, 07:32 PM   #8 (permalink)
Not exactly, I have seen on my friend's nokia n91 using opera mini on airtel NOP service.
the main problem is that in my nokia 6030, when i set up an acess point there is no place where i can key in the ip or proxy. if i go for a better phone this problem ll be solved. with my phone i guess it isn't possible to use opera mini on airtel nop.
Nipon
Old 25-02-2007, 12:11 PM   #9 (permalink)
Smile Re: Opera mini not working on Airtel+nokia
I am also facing the same problem in my Nokia 6030.... Airtel GPRS team doesnt have any solution to this problem. Opear Mini, Gmal or even the Airtel's endrosed PVR Mobile ticketing application is not accesible.
I am having NOP activated on my AirTel number!!!!
Suggest ?????
Last edited by crosswordsguy; 25-02-2007 at 12:11 PM. Reason: Automerged Doublepost
crosswordsguy is offline
Old 26-02-2007, 01:11 AM   #10 (permalink)
Tech.Masti's Avatar
@Generic Superhero
i am using MO on my 3220....what is the current NOP price in kolkata circle...i am also from kolkata
Tech.Masti is offline
Old 27-02-2007, 12:19 PM   #11 (permalink)
the price in kolkata is 99 per month for NOP and 250 for MO.
Nipon
Old 01-09-2007, 12:33 PM   #12 (permalink)
Red face Re: Opera mini not working on Airtel5200+nokia
sir
i am currently using nokia 5200 with airtel connection.
i have also activated nop and airtel live.
but opera mini,berggi and other e-mail,IM ..........are not working with it.
you have used nokia 5200,so plz help me to use opera mini on n5200. as early as posssible
i shall be very thankful to u.
my email address is:
kr_pradeep2006@yahoo.com
kr_pradeep007@yahoo.com
kr_boss is offline
Old 03-09-2007, 10:47 PM   #13 (permalink)
Mobile Addict
Unhappy Re: Opera mini not working on Airtel+nokia
Hey guys, I am having the same problem but I had managed to get my Nokia 5300 to connect to net using Opera Mini and had surfed using it for some time. But from the next day, I am not being able to connect. Whenever I do the network setup, it shows failed to connect to the internet. I have both Opera Mini v3 & v4 installed.
Please visit my site: hotshot05.page.tl or my blog: mobimad.co.cc for anything related to mobile reviews, games , applications and news. Please review my site.
aritrap is offline
Old 03-09-2007, 11:15 PM   #14 (permalink)
Google Bot
Pathik's Avatar
Try opera mini 4 beta 2
Pathik is offline
Old 07-09-2007, 01:36 AM   #15 (permalink)
Toh Fir aao
Y u ppls ant be able to use java app. on celll??? even my frnd uses all of these on his baba ADAM time 6610.. !! bdw to put proxy in opera download oipera modded from here http://google.wap.in/browser.wml and in these u have all options but direct proxy of airtel will not going to work...
hac_king is offline
Old 08-09-2007, 11:44 AM   #16 (permalink)
Guy from Heaven
Tech$oft's Avatar
Wink Re: Opera mini not working on Airtel+nokia
Im also using NOP on my k750i and most internet applications gives me access and considering opera mini all versions work and they give access to html/wap both sites , it must be the setting that have been put incorrect
Tech$oft is offline
Old 08-09-2007, 12:22 PM   #17 (permalink)
Google Bot
Pathik's Avatar
opera mini can be used to access all sites as all incoming data gets parsed to OBML b4 it is sent to ur fone..
Pathik is offline
Old 17-09-2007, 02:45 PM   #18 (permalink)
I too have been facing this problem eversince I migrated from SE K508i to Nokia N70 ME. I also have Net On Phone(NOP)in Bangalore with airtelwap as the access point. It works sometimes but fails more often.Even the 4 beta version has the same problem. I have not been able to make MGTalk or YahooGo work on my N70 on NOP. GoTalkMobile worked a couple times and stopped thereafter.mig33 has worked,but unable to connect to Yahoo Messenger login.Any ideas anybody?Thanks
kayceesat is offline
Old 20-11-2008, 12:16 PM   #19 (permalink)
I had installed opera mini on my n70 but i could not save any page from it or any file to download it ask for "use signed copy" then it locate for folder where to locate user data ? pleease help me.. thanx
bbdamita is offline
Old 22-03-2009, 11:12 AM   #20 (permalink)
The problem is not with airtel but it's with nokia s40 phones.
Nokia does not allow creating proxies for access point..
There is a solution for the phones having Bluetooth.
Visit
Run Opera mini on Nokia s40(v2, v3, v5)
rushideshmukh is offline
Old 23-03-2009, 09:41 AM   1 links from elsewhere to this Post. Click to view. #21 (permalink)
hi ppl here is the NOP prov file for nokia s40 phones to run java app on NOP airtel.. download it and transfer to another phone.. thenn again push it to ur fone via bluetooth.. u will get settings.. set it as default.. use in all app..
here is the link
http://rapidshare.com/files/212257013/airtel8080.prov
Posted again:
or plz try downloading this file here
dont open it with notepad.. simply save. it and transfer via bluetooth
http://rapidshare.com/files/21242269...JAVAProxy2.rar
Last edited by pardeepkhurana; 23-03-2009 at 09:55 AM. Reason: Automerged Doublepost
pardeepkhurana is offline
Old 28-03-2009, 07:57 PM   #22 (permalink)
thanks pardeepkhurana
for that settings
wow atlast java applications are workign in my mobile :O
hope balance wont get deducted ..................
sweet fren is offline
LinkBack to this Thread: http://www.thinkdigit.com/forum/mobiles-tablets/47968-opera-mini-not-working-airtel-nokia.html
Source Post #0 Refback 21-02-2012 05:47 PM
