Old 30-01-2007, 11:11 AM   #1 (permalink)
Default Confused Plz Help....:(
i took a N73 a week back...
when i'm installing third party software on it it says that "unable to check for certificate validity"....and the app does not get installed please can u provide solution yo it??
rakhihere is offline
Old 30-01-2007, 11:32 AM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: Confused Plz Help....:(
r u sure they are os9.1 apps.. Btw i think u need to change the child installer certificate settings in it..
Pathik is offline
Old 30-01-2007, 12:25 PM   #3 (permalink)
ya i'm sure ...
i downloaded that from getjar.com
and it says it is for nokia series 60 v3 edition .....(English oxford dicionary)
and BTW wat are these child certificate settings
Old 30-01-2007, 01:03 PM   #4 (permalink)
Google Bot
Pathik's Avatar
oh do u mean java apps.. Goto app manager settings.. There ll b some option like check 4 certificates.. Set it to no.. I dunt remember much abt it..
__________
Pathik is offline
Old 30-01-2007, 02:46 PM   #5 (permalink)
thanq very much for ur help
the app (English oxford dicionary) got installed but how to launch it, i could not find out where to open it from......it might be silly question but plzzzz...
Old 30-01-2007, 06:17 PM   #6 (permalink)
Google Bot
Pathik's Avatar
i think in os9.1 the app auto creates a shortcut in the menu... if it doesnt then goto apps n open it...
Pathik is offline
Old 30-01-2007, 06:47 PM   #7 (permalink)
nops its not there []
Old 30-01-2007, 07:34 PM   #8 (permalink)
Google Bot
Pathik's Avatar
r u sure it got installed???? n its not here in wat?? menu or apps??
Pathik is offline
Old 31-01-2007, 10:40 AM   #9 (permalink)
i have checked in menu apps tools and all available folders in menu but ...could not find it.
i installed theme it can be seen in themes folder may b some instalation problem or setting problem cant figure it out...
Old 31-01-2007, 10:52 AM   #10 (permalink)
Google Bot
Pathik's Avatar
Can u c the app s folder in x/system/midp .. X=install drive
Pathik is offline
Old 31-01-2007, 12:15 PM   #11 (permalink)
when i'm opening the application manager it shows app is installed.
and therez no folder like system but therez folder /installed files and in that i cant see the files.....:S
Old 31-01-2007, 02:14 PM   #12 (permalink)
krazyfrog
Posts: n/a
In os 9 phones, the installed apps are automatically moved to My Own folder in Menu, whether they are java or symbian.
Also pathiks, in new symbian OS (after 6600), java apps are not installed in X:\System\midp but instead in X:\System\Apps just like Symbian apps.
Old 31-01-2007, 03:53 PM   #13 (permalink)
this is still weird :S
i cannot see any my own folder in the menu...???
