Old 28-01-2007, 10:38 AM   #1 (permalink)
Mobile Freak
reddick's Avatar
Exclamation Unable to connect : Nokia PC Suite
Recently i updated my N70's firmware n now I'm getting this error Whn i plug cable to phone,d PC Suite shows 'no phone is connected' Rather i activate Airtel MO n i can surf net also because phone shows that it is conected as appears on phones's screen Anyone please tell me why is it so n how to fix it THANKS for ur wise suggestions
Hope 4 d best n Do d right :)
reddick is offline
Old 28-01-2007, 11:18 AM   #2 (permalink)
anarchist
Posts: n/a
Default Re: Unable to connect : Nokia PC Suite
try updating PC suit , now version 6.82 is available
Old 29-01-2007, 07:28 AM   #3 (permalink)
Mobile Freak
reddick's Avatar
Even if it's an older ver. than also it must recognize my phone,But it didn't And why only phone's screen shows that it's connected...Why not PC Suite shows same info
reddick is offline
Old 29-01-2007, 08:03 AM   #4 (permalink)
Google Bot
Pathik's Avatar
maybe n70me was released after this pc suite ver.
Pathik is offline
Old 29-01-2007, 08:07 AM   #5 (permalink)
Resident Fanatic
Manshahia's Avatar
No, it sud work.
Try reinstalling the PC-suite.
It gav me this type of problem many times in 6630.
I had to install Pc-suite again nd again.
Had u disconnected the USB cable??
Manshahia is offline
Old 29-01-2007, 08:33 AM   #6 (permalink)
Google Bot
Pathik's Avatar
@manshahia ur prob was diff 4m his
Pathik is offline
Old 29-01-2007, 09:59 AM   #7 (permalink)
Resident Fanatic
Manshahia's Avatar
Why ?? ?? ??
Old 29-01-2007, 05:02 PM   #8 (permalink)
Google Bot
Pathik's Avatar
because ur fone wasnt connecting to pc suite at all....
his connects but jus shows that it wasnt connected...
and his problem started after he upgraded his firmware/...
Pathik is offline
Old 30-01-2007, 03:02 PM   #9 (permalink)
hailgautam's Avatar
Could there not be a work around here: I mean, if Windows recognizes that there is a phone attached, still you can use the phone to browse the net. You can re-install the drivers for your phone (cable drivers for Nokia) and try.
With My SE K750 i do not run the PC Suite but still as the phone is recognized by Windows, I can connect to net though the packet switched connection.
Change is Nature, the part that we can influence; and it starts when we decide.
Where you going?
With Luck forward.
hailgautam is offline
Old 31-01-2007, 04:19 PM   #10 (permalink)
Mobile Freak
reddick's Avatar
Okay I'll uninstall d PC Suite n re-install it...Gona tell u the results soon
__________
Okay it's working...Thx 4 ur valuable suggestions
reddick is offline
Old 04-03-2007, 11:44 AM   #11 (permalink)
reinstall the driver for nokia
i have faced the same kind of problem earlier with my N70
and after reinstalling the driver problem is solved
sanju is offline
