Old 28-01-2007, 12:15 AM   #1 (permalink)
Default Convert K750i to W800i
Convert ur K750i to W800i, check out this link :
http://forums.se-nse.net/index.php?showtopic=6389
I used the PhoneXS 2.10 Alpha3 instead of Phone-XS V2.01 as shown in the link. I couldn't get Phone-XS V2.01 to recognize my phone. U can get the same from the www.topsony.com site.
Advantages are U get the Walkman interface which is better than K750i media player. Also the music phone/airplane mode in which the phone can be used in mp3 player only mode, the battery lasts longer in this mode.
The sound volume is increased. Also if U get MegaBass, if it was not there earlier.
Only disadvantage I found was the activity button is now replaced with the Walkman button.
All the newer K750i phones should be CID 49. U can check if ur phone is
CID 49 using k750flasher_13.7 :
http://forums.se-nse.net/index.php?a...e=post&id=1805
Click the Read CID/Test Cable button in k750flasher_13.7
Also please follow the instructions at this link about important things u need to be aware of before flashing the firmware of ur phone:
http://forums.se-nse.net/index.php?showtopic=6118&st=0
It seems U could void ur warranty, if u do the above....
So at ur own risk !
All the best
tonyxs is offline
Old 28-01-2007, 01:23 AM   #2 (permalink)
mayneu's Avatar
Wink Re: Convert K750i to W800i
So at ur own risk !
All the best
Dude, similar topic is covered in this link. didnt understand whether u r asking
question here or giving a tutorial..... if its a tutorial, its a wrong section. it
looks like its a tutorial. here is the similar link
can i patch the driver for w850i?
mayneu is offline
Old 28-01-2007, 04:08 AM   #3 (permalink)
hailgautam's Avatar
Default Re: Convert K750i to W800i
man i tried a lot but could not do it, some how my FAR manager would not open any files or the file system. The flasher would not flash.
Change is Nature, the part that we can influence; and it starts when we decide.
Where you going?
With Luck forward.
hailgautam is offline
Old 28-01-2007, 09:37 AM   #4 (permalink)
mayneu's Avatar
Red face Re: Convert K750i to W800i
hey gautam, what phone r u using? did u check in this site http://forums.se-nse.net/index.php?act=home ??? & also in this site???
www.esato.com.
there u get all the information to ur problems... just ask ur questions there, they will help u definitely.
mayneu is offline
Old 30-01-2007, 04:10 PM   #5 (permalink)
hailgautam's Avatar
I am using K750i, that is why i was trying to convert. I checked all these sites. But did not work. At least I wanted to upgrede the number of SMS on the Phone with FAR Manager to more than the 100 (or is it 200 - forgot) to something more, as I send recive more than a hundred messages a day.But with FAR manager would not be able to see any files.
Where you going?
With Luck forward.
Old 30-01-2007, 09:00 PM   #6 (permalink)
Wire muncher!
infra_red_dude's Avatar
thats coz you probably haf a newer cid49 k750i. far manager only works wid older cid36 phones. you can try phone xs software. but its not 100% guaranteed!
infra_red_dude is offline
Old 30-01-2007, 10:12 PM   #7 (permalink)
Hi Gautam, Please check the link
First U need to make sure ur phone is CID 49.
Use this software to do the same.
I don't know why U are using FAR manager for converting ur phone.
The softwares I used were GSlide v1.5 and PhoneXS 2.10 Alpha3.
Also the files W800_R1BC002_MAIN_EU_EMEA.rar (main flash file), W800_R1BC002_FS_EMEA6.rar (File system flash) and w800_r1bc002_change_custom_folder.zip (custom file) are needed.
These files U need to use with GSlide v1.5 and u get 2 output files 'mainflash.bin' and 'filesystem.bin'
U need to create a custom folder in ur phones memory card and extract the contents of W800i_CDA102430_6_EMEA_6.zip into this folder.
Then U need to use the PhoneXS 2.10 Alpha3 software, connect ur
phone using the usb data cable and select the 'mainflash.bin' and 'file system.bin' which u got from GSlide v1.5 and complete the flash process.
tonyxs is offline
