View Poll Results: DO YOU LIKE THIS THREAD
YES 0 0%
NO 2 50.00%
WHAT THE F*** 1 25.00%
I TOLD U! I HATE POLLS 1 25.00%
Voters: 4. You may not vote on this poll
Old 27-01-2007, 04:36 PM   #1 (permalink)
::cyborg::'s Avatar
Arrow DEMO OF Far Manager(only for cid36 and cid29 phones)
iam giving this tut bcoz i saw that no far tut was there and guys this one is only for those who have sony ericssn cid 29, 36,49
First of all; I am in no way responsible for whatever you might do to your phone if you choose to follow this tutorial. You might render ur phone completely unsusable. But that is not my problem.YOU HAVE BEEN WARNED.
First of all you'll need the FAR Manager programhttp://www.farmanager.com/download.php?l=en. Download and install version 1.70.
Edit: Then you'll need the latest SE Flash Pluginhttp://sephone.nm.ru/tools/SEFP010044.zipfor FAR Manager. Unzip the content to the ..\Program Files\Far\Plugins\ folder.
When you start FAR you'll get this screen:
THeN
Pressing Alt+F1 gives you this screen:
Select "SEFP" from the list to enter the phone. Make sure the phone is turned off and the DCU-60 cable is connected to the computer but NOT the phone.
Hit Enter and you're presented with this screen:
Make sure the settings match for the DCU-60 cable and Tab to "Enter The Matrix" and hit Enter.
now this screen comes:
when phone gets detected :
now u can release the "c" key.
The program connects to the phone and shows this screen
Select FS (for filesystem) and hit Enter, and the program scrolls through some info and then you're in the root of the filesystem
And from here you can move to the different folders using Arrow Up/Down and hitting Enter. The .. at the top gives you the parent folder.
IMPORTANT!
When you've finished with the changes on the phone move up to the root of the filesystem, until you get this screen:
And answer "Yes" to SHUTDOWN the CSFSloader. Otherwise your changes will not be made on the phone. And the phone could become unusable
to exit press f10
If you're not completely sure about what you're doing in regards to editing the filesystem with FAR Manager, you probably shouldn't do it. There's a very real possibility that you'll end up with a very expensive paperweight. YOU HAVE BEEN WARNED
:)) - KEEP SMILING
::cyborg:: is offline
Old 28-01-2007, 04:34 AM   #2 (permalink)
hailgautam's Avatar
Default Re: DEMO OF Far Manager(only for cid36 and cid29 phones)
Somehow I am not able to use FAR Manager to access the files. It boots up all right and seems to access the phone but no files are visible. (From the sixth picture over there)
Change is Nature, the part that we can influence; and it starts when we decide.
Where you going?
With Luck forward.
hailgautam is offline
Old 28-01-2007, 01:09 PM   #3 (permalink)
::cyborg::'s Avatar
did u installed usb drivers of ur cable
:)) - KEEP SMILING
Old 06-03-2007, 04:11 PM   #4 (permalink)
rajasekharan's Avatar
ok....but how can i update the firmware using this mate????????
Make a day good , and another day good , and another ...a happy lad is "born" from you :)
rajasekharan is offline
Old 06-03-2007, 08:31 PM   #5 (permalink)
::cyborg::'s Avatar
tell me ur firmware
ur phone give me some info so that i can telll u something.
:)) - KEEP SMILING
Old 06-03-2007, 08:41 PM   #6 (permalink)
You gave been GXified
gxsaurav's Avatar
U can update the firmware using SE update service. This is for moding the phones
about.me/gxsaurav
gxsaurav is offline
