Old 19-01-2007, 05:40 PM   #1 (permalink)
Noobie Pro
alsiladka's Avatar
Thumbs up Must Have : Freewares for S60V3 (Latest Nokia Phones)
Supported SmartPhone Models -
Nokia -
3250, 5500 Sport, 5700, 6290, E50, E60, E61, E61i, E62, E65, E70, E71, E90, N73, N75, N76, N80, N91, N92, N93, N93i, N95
Lg JOY
Samsung SGH-i520
As most of the smartphone owners must have noticed, the New phones sport a new Operating System - Symbian OS 9.1/9.2/9.3 or S60V3
S60v3, for security purposes, has completely broken compatibility with the previous edition apps. and hence you must not have been able to install those apps on your system.
Here is a list of must have freeware applications which will enhance the use of your Smartphone.
1. Y-Browser
Y-Browser is a file manager for Symbian OS devices. It implements most standard features on files (such as copy, cut, paste, etc) & folders (create, remove, etc)
The addon pack which you can download from there site also lets you view text files, View your messaging folders and open ZIP file.
3. Auto Keylock
As simple as the name suggests.
The default Autolock in the nokia phones, locks the phone using the lock code, which means you have to enter the lock code to unlock the phone.
This application lock only the keypad, which otherwise we have to do with the 2- key combination of left menu button and star.This app will automatically lock the keypad after a time period which you can specify.
4. Calcium
Calcium is a fast, easy to use calculator for your S60 phone
Getting tired of the S60 calculator? We were, so we made our own. We removed the need to select on-screen buttons and moved all the operations to the joystick.
So how fast is it?
Try this simple example: start the standard calculator and do 2/3 x 7. It takes 13 clicks. Using Calcium it only takes 6!
5. Nokia Zip Manager
Zip Manager is a powerful and easy-to-use file compression program for the Nokia E61. ZIP Manager allows you to handle zip files in a convenient way. It offers a graphical interface to add, extract, and open files, as well as toperform other commands.
6. Dictionary 2.0
Websters English Dictionary.
  • Built-in indexes find words in a fraction of a second.
  • Includes parts of speech (noun, verb etc).
  • Uses 6Mb disk space for the program and data.
  • Installs to main memory or memory card (Memory card recommended)
7. WLAN Wizard (from Nokia)
Is there a WLAN network out there? The WLAN Wizard will tell you, store it and launch it for you! WLAN Wizard shows the available WLANs in the range of N80 Internet Edition directly on the idle screen and it is possible to start web browsing immediately. WLAN Wizard also automatically creates the needed WLAN settings making WLAN usage extremely easy.
8. Nokia Podcasting application
Podcasts are regular digital audio or video broadcasts that can be downloaded and played on mobile devices and personal computers. News agencies and other sources offer podcasts on a wide range of topics. Often podcasts are regularly updated in a series of new episodes, so users often subscribe to their favorite shows.
The Nokia Podcasting application allows you to find, subscribe to and download podcasts over the air with your Nokia phones. After downloading a podcast, you can listen to or watch it when you want.
9. Contacts Transfer
Have you ever tried to copy the contacts database from one S60 based phone to another? Perhaps using a PC suite or SyncML? Perhaps you have noticed that something was missing in the end? No problem, with the Contacts Transfer application you can copy the entire contents of the contacts database includig thumbnail images and caller groups from one phone to another via bluetooth, infra-red or a memory card. Click here for more detailed information.
10. S60SpotOn
S60SpotOn keeps your display backlight permanently on.
If your smartphone (e.g. Nokia N80, N90) supports a camera-flash, you will be able to turn it on/off too (since v0.04).
In short, here is a torch for your Darker needs!
11. Mobile Search
Looking for restaurants, taxis, or even local weather forecasts? How about mobile phone content like ring tones and wallpapers? Or maybe you want images, or even some new MP3s. Then look no further than the mobile search software for Nokia mobile phones. Learn more about mobile search »
12. DivX Player
The name says it all. A player to Play DivX, Xvid, Smartmovie videos on your phone.
13. Mobile Weather
Mobile Weather is a weather forecast client for S60 Smartphones that shows the current weather situation of hundreds of cities anywhere all around the world. It is available for Nokia S60 Second Edition (FP2 and FP3) and Third Edition devices.
14. NSysInfo
Software shows full information about your phone, such as firmware version, IMEI, signal strength, battery level, memory amount, processor and screen types. Also it lists all supported features. You can save all info in file. By defaults file will saved in c:\data\others or e:\others. Also you can refresh all data by pressing "*".
15. SymTorrent
[quote]SymTorrent is the first full-featured and complete BitTorrent client for Symbian OS. It supports downloading multiple torrent files at the same time, is capable of both downloading and uploading and can save the status of your unfinished torrents, so you can resume the downloads after restarting the application. You can also check the status of each file inside a torrent along with several other statistics and properties during download.[/QUOTE]
17. Flashlite 2.1
Its an advanced version of the flash player already on the phones. This version will ship in the newer phones. Although there is not much stuff available for flashlite, since it has turned freeware recently, you can expect things taking shape soon.
18. Adobe PDF Reader
PDF documents are at your fingertips on your device with the Adobe Reader. With the application you can read PDF documents on the display of your device. Documents can be accessed and opened in the following ways:
  • Opening an email attachment from received e-mail messages (network service)
  • Document sent using Bluetooth technology to your Inbox in Messgaing
  • Using the File manager to browse and open documents stored in the phone memory and on memory card
  • Browsing Web pages
Note that this application has been optimized for PDFcontent on handsets. Some functions, particularly those requiring significant computing power or memory, are not supported with this mobile version.
19. Opera Mini
Guys, if you are a GPRS user, this is a must have. It has already taken the world by a storm, now is your turn. It reduces your traffic usage by more than 50%!! Specially recommended for Hutch users as they are charged for use, unlike Airtel.
Opera Mini uses a remote server to pre-process Web pages before sending them to your phone. Web content is compressed to reduce the size of data transferred, enabling handling on simpler phones and creating fast browsing at low costs.
Opera Mini™ simply offers user-friendly access to all Web pages to nearly all mobile phones. It has all the features expected of a browser, and more, such as content download, bookmarks, skins, multi-search and smooth scrolling. In addition, Opera Mini recognizes your phone's capabilities and optimizes Web pages accordingly for fast and easy browsing.
To see Opera Mini in action or to check out how your Web page looks on a small screen, feel free to use our online Opera Mini live demo.
20. Mobizines
The Mobizines service is all about entertainment snacks for your phone. The latest news stories, film reviews, some juicy gossip or lifestyle tips - The Mobizines service is available to everyone as a way of taking their content mobile.
Lots of top print and online magazines as well as TV channels and record labels are now working with us to create mobile magazines and you can get them on almost any mobile, any time. And it’s not just the big boys, anyone from bands to shops can launch one.
Free Internations magzines for your mobiles. Titles include everything from Maxim, BBC News, Sports, Movies, Games, Health.
Check it out once.
21. Cricket Cast
Get real-time live cricket commentary on your mobile phone.
22. Mig33
Looking for a better way to stay in touch with friends? Get mig33 on your mobile today!
  • Great rates for making calls wherever you are in the world
  • Flexible, cheap international calls using SMS callback and throwback
  • Cheap international SMS
  • Chat using MSN and Yahoo!, or in any one of mig33's chat rooms
Right now there were the freewares which i garnered from the web and various listings. If you are aware of any other freeware which needs a mention in this list and i have missed it, please do give your suggestions.
www.twitter.com/alsiladka
alsiladka is offline
Old 19-01-2007, 06:20 PM   #2 (permalink)
krazyfrog
Posts: n/a
Default Re: Must Have : Freewares for S60V3 (Latest Nokia Phones)
^^ Good job.
Old 19-01-2007, 08:35 PM   #3 (permalink)
Google Bot
Pathik's Avatar
old apps
Pathik is offline
Old 19-01-2007, 09:28 PM   #4 (permalink)
Tech Geek's Avatar
thanks for the freewares
repped you
Tech Geek is offline
Old 19-01-2007, 10:58 PM   #5 (permalink)
Crazy Kidd's Avatar
Nice job. But you forgot to mention which are Java applications and which are Symbian applications. In that way you can include mobile from other brands also.
And try mXit. Its similar to mig33. And will be waiting for your next update.
Crazy is what crazy does. So lets get crazy like hell.
Crazy Kidd is offline
Old 19-01-2007, 11:27 PM   #6 (permalink)
Noobie Pro
alsiladka's Avatar
Originally Posted by pathiks
old apps
Only a few JAVA apps. are old. All others are not more than 5 - 6 month old. But the basic requirement for making the list was to help the people with the newer phones to find the applications which would work for them as i found a lot of my friends panicking when they found that the olders apps wont work on their N series phone.
Will add the Java and Symbian info during next update
Old 20-01-2007, 12:25 AM   #7 (permalink)
Crazy Kidd's Avatar
Thanks for considering my suggestion. And if you need any help with any apps contact me. Would love to help you.
Old 07-02-2007, 03:15 PM   #8 (permalink)
Very good job thanx alot
fadarico is offline
Old 07-02-2007, 11:54 PM   #9 (permalink)
Rockstar11's Avatar
good job
post more S60V3 apps
thanks....
keep it up
Rockstar11 is offline
Old 08-02-2007, 12:39 PM   #10 (permalink)
D PrankMaster
prankie's Avatar
nice list...
My Rig: AMD Phenom II 1090T | Gigabyte GA880GM-USB3| Sapphire HD6850 | 2x4GB Corsair Vengeance DDR3 1600Mhz | 2x500GB Seagate HDD | Silverstone Strider 500W | Alteclansing Octane 7 | Microsoft Natural Ergonomic 4000 | Logitech MX518 | Rantopad H1 | APC 0.6KVA
My Gadgets: Nikon D3100 | PSP1000 | XBOX360 20GB | Sansa Clip+ | Soundmagic PL50 | Meelectronics M9BK
prankie is offline
Old 08-02-2007, 02:50 PM   #11 (permalink)
kumarmohit's Avatar
Good job. Reputation points for u
kumarmohit is offline
Old 19-06-2007, 11:24 PM   #12 (permalink)
Sublimobi mobile software worked for me. Check www.sublimobi.com. It
is a free rss news reader. Must have freewares
karmaresh15 is offline
