Old 18-01-2007, 09:15 PM   #1 (permalink)
Default N-gage
Currently I Am Using Ngage-classic And I Have Original Ngage Headphones.though It Gives Good Sound Clarity I Like To Know Is There Any Other Company Headphone I Can Use For Ngage And It Should Give Good Sound Clarity.is Sony And Panasonic Headphones Compatible With Ngage And Does It Give Good Sound Clarity.please Suggest Me .
Nilesh.Ravindran is offline
Old 18-01-2007, 09:17 PM   #2 (permalink)
rahul_becks23's Avatar
Default Re: N-gage
it depends on the adapter interface.
if its the common headphone type, u can plug-in any company headphone u want .
rahul_becks23 is offline
Old 18-01-2007, 10:10 PM   #3 (permalink)
SE><IE
Posts: n/a
Default Re: N-gage
Its the typical Nokia interface. Maybe an adapter would be reqd
Old 18-01-2007, 10:12 PM   #4 (permalink)
Default Re: N-gage
yep , a nokia adapter is available .
Old 18-01-2007, 10:20 PM   #5 (permalink)
krazyfrog
Posts: n/a
Default Re: N-gage
The classic N-Gage used a unique type of two pin audio connector not found on any other phone. Hence there is no adaptor made for this particular type of connector. In short, you cannot use any other type of headphone and have to be content with the default one.
Old 18-01-2007, 10:27 PM   #6 (permalink)
SE><IE
Posts: n/a
Default Re: N-gage
Oh yeah! you make me remember. Its actually a short 2-3 inch adapter which I suppose you got with your N-GAGE. It will work only for speakers though.
