Old 18-01-2007, 05:30 PM   #1 (permalink)
Default MObile having Bluetooth,infrared,FM without camera
I am searching for a mobile having Bluetooth,infrared,FM radio but it should not have camera ... Can anybody suggest which will be the best suitable.
It should not go beyond Rs.7000/-
__________
Anybody plz suggest? Any brand is ok for me..
Last edited by Mahesh_Bendale; 18-01-2007 at 05:31 PM. Reason: Automerged Doublepost
Mahesh_Bendale is offline
Old 18-01-2007, 05:34 PM   #2 (permalink)
Living to Succeed
ajayashish's Avatar
Default Re: MObile having Bluetooth,infrared,FM without camera
any brand preference...
Q6600+Abit IX38QuadGT+Corsair 4gb 800mhz+ Ultra 120 Extreme+ tagan 600wts+CM690
Alienware M15 - with Gforce 460 1.5gb + 8gb DDR + i7 1.73ghz
ajayashish is offline
Old 18-01-2007, 05:35 PM   #3 (permalink)
Any brand will do but it should have above mentioned features.
Old 18-01-2007, 05:37 PM   #4 (permalink)
Wise Old Crow
blueshift's Avatar
Actually mob comes with camera these days.
If you can increase ur budget, Nokia 5200 will be best option at around 8000/- approx.
Another option would be Samsung SGH-X630 at around 6800/-.
blueshift is offline
Old 18-01-2007, 05:40 PM   #5 (permalink)
Thanks !!! Actually in my company mobiles with cameras are banned.. that's why I am in search of such mobile.
Old 18-01-2007, 05:40 PM   #6 (permalink)
Wise Old Crow
blueshift's Avatar
oh..those mobs have cameras though
Old 18-01-2007, 05:45 PM   #7 (permalink)
I have just checked it specifications ...
It is having camera. See the specifications of Nokia 5200
GeneralDate AnnouncedThird Quarter 2006 Date ReleasedComming Soon ModeGSM Triband 900/ 1800 / 1900 Dimensions92.4 x 48.2 x 20.7 mm Battery TypeLithium-Ion (760 mAh) Battery Life190 mins talk time,263 hours standby time Weight104 grams Form FactorSlider Phone book Dynamic Memory
Display Type 256K colors,CSTN,(128 x 160 pixels) Expansion Slot Yes (TransFlash,microSD Card slot) Form Factor Slider GamesYes Polyphonic RingtonesYes (64 chords, [COLOR=#0033ff! important][COLOR=#0033ff! important]MP3[/COLOR][/COLOR] support) Vibrating AlertYes
Connectivity
BluetoothYes EDGEYes (Class 10, 236.8 kbps) E-Mail clientNo
BluetoothYes EDGEYes (Class 10, 236.8 kbps) E-Mail clientNo GPRSYes Instant MessagingYes Infrared (IR)Yes Java Apps (J2ME)Yes (MIDP 2.0) MMSYes SynchronizationYes SMSYes USBYes WAPYes
Organiser Functions
Internet BrowserYes Onboard Memory5 MB Picture IDYes
Special Functions
CameraYes (VGA, 640x480 pixels) FlashlightNo FM RadioYes GPSNo Mp3 PlayerYes Streaming MultimediaNo
Old 18-01-2007, 05:46 PM   #8 (permalink)
Wise Old Crow
blueshift's Avatar
Another one is Nokia7210. Doesn't have camera and bluetooth.
Old 18-01-2007, 05:51 PM   #9 (permalink)
thanks a lot blueshift! I want to thank you but there is no "Thank you" button here... How can I ?
Old 18-01-2007, 11:23 PM   #10 (permalink)
Google Bot
Pathik's Avatar
7210 has a vga camera...
Pathik is offline
Old 19-01-2007, 12:29 AM   #11 (permalink)
Noobie Pro
alsiladka's Avatar
You can go for N-Gage QD. Sad its such an old phone, but now a days every phone does have a cam. I think N-Gage would be perfect for you.
www.twitter.com/alsiladka
alsiladka is offline
Old 19-01-2007, 12:42 AM   #12 (permalink)
Still Shining!
Lucky_star's Avatar
N gage is a good one, but it doesn't feature an infrared port.
Nokia 6810 has all the features u want:
Bluetooth
Infrared
FM radio
and no Camera.
But the downside is it doesn't have a memory expansion slot.
Have a look at it here
It has a dual keypad which when opened will work as a full fledged keyboard.
there is another one SE W950. But it will overshoot your budget.
Nokia N86 8MP
Lucky_star is offline
Old 19-01-2007, 07:56 AM   #13 (permalink)
Wise Old Crow
blueshift's Avatar
Normal 7210's don't have cam. Everything that has i in the model no. has a camera.
btw Mahesh, you need to compensate for the bluetooth factor. You can get mobile within your range but don't expect to have bluetooth in it.
see this site:
http://www.gsmarena.com/search.php3
Old 19-01-2007, 10:07 AM   #14 (permalink)
Google Bot
Pathik's Avatar
Bluetooth
Infrared
FM radio
and no Camera.
6810 is a s40 fone.... and IR is a dead technology now.... go 4 a ngage or ngage QD...
n if u can go till the w950 then do consider the e61...
Pathik is offline
Old 19-01-2007, 10:21 AM   #15 (permalink)
Thanks a lot for your valuable response. Do you know the price of it ?
Old 19-01-2007, 10:29 AM   #16 (permalink)
Google Bot
Pathik's Avatar
wich one???
e61 is for 15.6k...
Pathik is offline
