Old 17-01-2007, 10:49 AM   #1 (permalink)
Default Nokia 6600 Connection via BT Prob.
I cant make my pc to connect with my n6600.I have BT blue soliel,6600 pc suite installed.But its not working.Pl.help.me .....
Thanxxxxxxx
vivekrm007 is offline
Old 17-01-2007, 11:10 AM   #2 (permalink)
!FREEWARES!
Akshay's Avatar
Default Re: Nokia 6600 Connection via BT Prob.
Hav u tried connecting to diff. devices - wit ur PC as wel as 6600? R u able to do so?
Also hav u tried connecting ur 6600 to ur pc without using PC Suite? If u stil cant connect, reinstall ur drivers n pc suite 4 PC.
MBP 13.3";
PC: Core i-5 2400, Intel H67, GSkill 4GB DDR3, Sapphire 6850 Toxic, 1TB HDD, Samsung P2370
Steam (Cod-MW2 only) - akshay81
Akshay is offline
Old 17-01-2007, 11:14 AM   #3 (permalink)
assasin's Avatar
If u Win XP SP2 den remove drivers and use XP SP2 built-in drivers.
assasin is offline
Old 19-01-2007, 10:46 AM   #4 (permalink)
Google Bot
Pathik's Avatar
does ur pcsuite detect ur fone thru BT???
Pathik is offline
Old 19-01-2007, 11:42 AM   #5 (permalink)
This method is for ngage, i hope it works for 6600 too.
In the blue soleil main window
right click on your phone and refresh services
next step, right click on your phone and connect to Bluetooth serial port service
you should be able to connect now unless there is any serial port coflict in your computer. Pc suite worked for me for the first time, but now the Blue soleil itself is unable to make the connection to the Bluetooth serial port service, it is giving a connection failed error. so naturally pc suite wont work.
casual_gamer is offline
Old 19-01-2007, 02:33 PM   #6 (permalink)
assasin's Avatar
If ur using MS bt drivers either connect using connection manager in Pc Suite or goto Control Panel->Bluetooth Devices->Add
assasin is offline
