13-01-2007, 08:10 PM
I Always Prefer 1080p
Calling Owners of SE K750i or Nokia 5500 for Help
I am a Music Addict esp Soundtracks of Movies and Games
I am planning to buy any one of these phones
Suggest me a model
My personal preference is K750i, but I am afraid of Joystick Problems
Also will it support 1 GB Card without any hanging Problems
Nokia 5500 is cool as its Symbian Based
More Software like DivX Player, Mobile Office are available
But I don't know whether this supports 1 GB Card without any problems
Please help me in Decision Making
Thanks in advance
13-01-2007, 08:55 PM
Noobie Pro
Re: Calling Owners of SE K750i or Nokia 5500 for Help
k750i would be a better choice. I personally own Nokia 3250 and would definitely recommend that.
k750i -
Good Camera
Good Music
No 3rd party Softwares
Problematic Joystick
Nokia 5500 -
S60v3 OS
Excellent 3rd Party apps.
Poor Cam
Not as great music
sleek and small
Break resistant
13-01-2007, 08:57 PM
go 4 SE w810i
13-01-2007, 09:46 PM
Nokia 5500 supports 1GB mem card without any probs.Theres also news that it supports 2GB card.Personally i feel music of 5500 is better than K750i,but cam of K750i is better.
13-01-2007, 09:50 PM
I'll suggest you go for Nokia N72. It comes for 12.8k (in mumbai) now. It has everything you want. Great camera with flash, CIF resolution video recording, great sound quality, fm radio, EDGE, etc. It is also a Symbian smartphone, so you can find lots of apps for it (more than 5500). It comes with 128 mb card and 3.5mm audio adaptor.
Btw, both K750i and 5500 can support upto 2gb cards without any problems.
13-01-2007, 09:57 PM
But N72 sports a back dated os (OS8.1).Why buy it when u can get the lastest os (OS9.1).As far as apps r concerned u will get lots of it within a few months.
14-01-2007, 05:39 AM
Does Nokia 5500 have a bundled Memory of 512 MB Micro SD Card
I also have W710i in mind as it comes bundled with 512 MB M2 Card
Suggestions ?
__________
128 MB Memory Card is very less buddy when compared to
SE W810i or W710i
By the way,what is the cost of 1 GB Micro SD or 1 GB M2 Card in India ?
Reason: Automerged Doublepost
14-01-2007, 09:15 AM
^^Yes 5500 does come with a 512mb micro sd card.
Yes 128 mb is less in N72, but you can easily purchase a higher capacity card for it, as the prices of DV-RSMMC are very low (1gb card would cost much less than 512 mb of micro sd and equal to the price of 256mb ms micro M2!).
No idea about the exact prices of Micro SD or M2.
14-01-2007, 10:08 AM
512MB for Rs 1,400
1GB for Rs 2,400
Delhi price ( I'v seen it in other forum)
14-01-2007, 10:10 AM
Google Bot
get a w810i or n72.. Btw 8.1 is the best os currently... In terms of features n app availability..
14-01-2007, 10:16 AM
Currently it is,but it wont be in a few months.In terms of features OS9.1 is far better than OS8.1.
14-01-2007, 10:51 AM
@techtronic w.r.t your original question:
SE 750i does not have such a major problem with the joystick. I faced some problem only when browsing internet on the Opera Mini3, else there was no problem at all.
I use 1gb card and have absolutely no problem. My 1 gb card was bought for Rs.1200 at the foreign goods store, so i doubt if it is a original sony, but working very well for me.
Change is Nature, the part that we can influence; and it starts when we decide.
Where you going?
With Luck forward.
14-01-2007, 03:28 PM
i personally own se k750i there is no joystick problem. i also have installed some 3rd party applications. i suggest u to go foe se k750i
14-01-2007, 03:37 PM
Google Bot
lol os9.2 has already released... in a few months the best OS ll be 10.1....
14-01-2007, 05:06 PM
^^^ yeah i know its already been released as OS9.1 FP 1.And all the apps made for any OS from 9.1 will be intercompatible.
14-01-2007, 05:51 PM
i am using k750i for the last 3 months ...
if u want best 2 mp camera and very good music playback ..then k750i ..
also no joystick prob and using it with 1 gb card .. no prob at all ..
14-01-2007, 08:20 PM
Krazy,
I test N72 but didn't impressed with headphone Sound quality in compare to W800i (yes my friend have W800i) and 125gm is noticable weight when you put it into pocket.
Can we use other headset (prefer sony, it fit with my Ear like Made For Each Other)
14-01-2007, 08:49 PM
^^ Nokia is notorious for supplying sub-standard headphones with its phones, even on its range of music phones. So its no surprise that you weren't impressed with the headset of N72. But the phone does provide good sound quality. But to experience it you'll have to use the supplied audio adaptor and use higher quality headphones with it. The sound quality will be very good (comparable to but not better than Walkman phones).
Yes it is slightly bulky, but smartphone's tend to be so. Although Nokia's newer range of smartphones is changing this tendency.
14-01-2007, 09:06 PM
#19 (permalink)
So Now do you like to say N72=SE W810i?
14-01-2007, 10:10 PM
#20 (permalink)
Noobie Pro
@krazyfrog
The headphones that nokia supplies with 3250 are excellent and you can buy them separately if you want.
@pathiks
The os in N95 is 9.3.
And OS 10 is atleast minimum 6 months to an year off!!
14-01-2007, 10:11 PM
#21 (permalink)
^^ Well not exactly. W810i has a great camera and provides excellent music quality which is better than that of N72. It also has a higher capacity memory card bundled. But N72's is a smartphone having lots of great apps written for it. Music and cam are not at all bad. And its cheaper too. So it kind of becomes even. So it essentially depends on what your needs are and what you're looking for in a phone. One thing is for sure, both are great phones and even if you pick one blindfolded, you won't go wrong.
14-01-2007, 10:30 PM
#22 (permalink)
How about W710i ?
It comes bundled with 512 MB M2 Card
Is it good ?
15-01-2007, 03:45 AM
#24 (permalink)
I saw it in mobile-review and then only posted here
Anyway thanks for the help krazy
__________
Does 5500 or W710i or K750i Video Recording depend on Memory or is it like 10 or 15 Seconds only like Nokia 6600 ?
I have finally decided to buy either W710i or K750i or Nokia 5500
depending on your feedback Digitians
15-01-2007, 08:51 AM
#25 (permalink)
^^ None of the 3 phones have limit to record videos. If you have to choose between the three, i'll suggest you go for 5500.
15-01-2007, 09:48 AM
#26 (permalink)
Krazy,
Some users compalint about W810i HISSSSSSSs problem, read here
15-01-2007, 10:33 AM
#27 (permalink)
Yeah go 4 Nokia 5500,u wont regret it.
15-01-2007, 12:55 PM
#28 (permalink)
^^ Yeah looks like W810i has a chink in its armour. I hope it gets fixed in the future. Surprising though that none of the websites that reviewed W810i mentioned it.
15-01-2007, 01:34 PM
#29 (permalink)
No, Sony people didn't care to fixed it. Even they refuse to have such problem with W810i  , but as users complaining same it means problem is there with 810i  .
You have to fix your self by visiting here full package with up to date guide, nice move by some Really Nice people who cares about others.
Long Live!
16-01-2007, 07:32 AM
#30 (permalink)
Thanks for your valuable suggestions
I would buy W710i or 5500 at the end of the month
Will definitely post what phone I bought
Once again,thank you all for your help
I dropped plans of buying K750i as it lacks EDGE
__________
One More Query Digitians,Please bear with me
Most of the mp3s I have are either encoded with 320 kbits or
Variable Bit Rate
Will these mp3s play in the above mentioned phones ?
