Old 12-01-2007, 03:15 PM   #1 (permalink)
Call me Sumit
esumitkumar's Avatar
Red face Battery prob in W700i
Hi All
I have a W700i but its battery lasts for one day only whether I play FM Radio/Songs or not .
Is there a problem in the battery or w700i battery lasts this much only ? Can I get it serviced under warranty ?
Thanx
esumitkumar is offline
Old 12-01-2007, 03:28 PM   #2 (permalink)
Living to Succeed
ajayashish's Avatar
Default Re: Battery prob in W700i
Sony has one of the finest betterys... try charging it overnight for 3-4 days... if it is still a problem go and get that replaced...
Q6600+Abit IX38QuadGT+Corsair 4gb 800mhz+ Ultra 120 Extreme+ tagan 600wts+CM690
Alienware M15 - with Gforce 460 1.5gb + 8gb DDR + i7 1.73ghz
ajayashish is offline
Old 12-01-2007, 03:51 PM   #3 (permalink)
Crazy Kidd's Avatar
Do you use or play(Not talking about games) with the phone too much. Try using it only for receiving and making calls and sending and receiving SMSs. Note the time of usage. And see what happens. The charge of my k800i used to last only one day also. I also thought of a possible battery problem but later realized that it is my fault. Try it. If doesn't work then replace it. And don't forget to charge it fully before doing this.
Crazy is what crazy does. So lets get crazy like hell.
Crazy Kidd is offline
Old 12-01-2007, 04:11 PM   #4 (permalink)
The Internationalist
Aberforth's Avatar
You have to tune the battery first time you use it, to put it in optimized performance mode. Charge the battery to 100%, then use it and discharge it to 0, charge again to 100% - repeat this cycle four times. This would increase the holding capacity. If it still doesn't help, take your piece to Sony Ericsson center.
Aberforth is offline
Old 12-01-2007, 04:23 PM   #5 (permalink)
Call me Sumit
thanx for suggestions..may be duplicate charger i bought @ 120 rs is causing the prob .. who knows
Old 12-01-2007, 04:49 PM   #6 (permalink)
Google Bot
Pathik's Avatar
i dont think a charger can cause the problem.... n aberfroth is rite.... fully charge the battery then fully discharge the battery the 1st few times... it shd work good then...
Pathik is offline
Old 12-01-2007, 09:31 PM   #7 (permalink)
gxsaurav
Posts: n/a
do these
1) Decrese the ringtone volume to 4 notch. Increse it if u find it low.
2) Go to Main menu->Settings->Display->Brightness, decrese it to 50%. Unless u r in direct sunlight outside somwhere, 50% is all u will need
Playing with the phone, does not drains the battery this fast.
Follow what aberforth said. It worked with my K750i. I don't even use the wall charger to charge it, I just connect it to the data cable->to the computer, & it charges.
If this all fails, take it to the authorised service centre. Where did u bought it from? I hope it's not counterfait battery, they are common in India
Old 12-01-2007, 10:14 PM   #8 (permalink)
Aberforth's Avatar
It could be. Duplicate chargers could hurt you and the phones too if a short circuit occurs.
Old 12-01-2007, 10:34 PM   #9 (permalink)
Wire muncher!
infra_red_dude's Avatar
do not charge overnight or for 3-4 dayz cont. it will ruin ur battery!
infra_red_dude is offline
