Old 12-01-2007, 10:41 AM   #1 (permalink)
Default K 700i
I have a Sony Ericsson K700i with me.
I use a Bluetooth Dongle to Connect AIRTEL GPRS to my PC.
The dongle is of CLASS 1 Bluetooth. Can i use class 2 ??
Is there any speed difference?
ajeesh_online is offline
Old 12-01-2007, 10:48 AM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: K 700i
nope there wont be any difference in GPRS(Internet) speeds....
tho ther mite b some increase in data transfer speeds....
Pathik is offline
Old 12-01-2007, 10:53 AM   #3 (permalink)
Living to Succeed
ajayashish's Avatar
Default Re: K 700i
in v2 the transfer speed is very good.. so use that
Q6600+Abit IX38QuadGT+Corsair 4gb 800mhz+ Ultra 120 Extreme+ tagan 600wts+CM690
Alienware M15 - with Gforce 460 1.5gb + 8gb DDR + i7 1.73ghz
ajayashish is offline
Old 12-01-2007, 11:45 AM   #4 (permalink)
soham's Avatar
Default Re: K 700i
GPRS speeds will remain the same though not sure about EDGE.
"Imagination is more important than knowledge. For knowledge is limited, whereas imagination embraces the entire world, stimulating progress, giving birth to evolution." ~ Albert Einstein
soham is offline
Old 12-01-2007, 12:07 PM   #5 (permalink)
Google Bot
Pathik's Avatar
Default Re: K 700i
the GPRS speeds r way less than the max. data speeds of the BT dongle availble... so increasing the data transfer speeds isnt goin to increase ur GPRs speeds @ all....
tho it may increase in the case of EDGE...
Pathik is offline
Old 12-01-2007, 01:39 PM   #6 (permalink)
Crazy Kidd's Avatar
Cool Re: K 700i
Tough increase of speed in not possible theoretically but from my experience with my friend's K750i it increases a bit. If you are into downloading it helps a lot. So why not upgrade. A BT dongle doesn't cost much
Crazy is what crazy does. So lets get crazy like hell.
Crazy Kidd is offline
