Old 05-01-2007, 10:13 AM   #1 (permalink)
Question Best Lithium-ion Batteries Charging Practices
Hi i use a SE W810i mobile, Though its talktime and standby are quite decent i want to know how can i improve its battery perfomance and life time any suggestions?
dareprasanna is offline
Old 05-01-2007, 10:20 AM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: Best Lithium-ion Batteries Charging Practices
1. Keep the display brightness low
Pathik is offline
Old 05-01-2007, 11:47 AM   #3 (permalink)
dinesh_mettur's Avatar
Try to keep the volume level ringinf sound to level 5
___________________________
~~ THINK DIFFERENT ~~
.. U'r Ultimate Place To Enjoy ..
www.funisland.co.nr
dinesh_mettur is offline
Old 05-01-2007, 11:58 AM   #4 (permalink)
Hells_Fury's Avatar
---Edited due to wrong info---
Q6600 G0 (TR Ultra-120), ASUS P5N32-E SLI, eVGA 8800GTX Superclocked (TR HR-03 Plus), Samsung 940BW, Corsair Dominator PC2-8500, CM Stacker 830, 700GB Storage, Corsair HX620W, APC Smart 750VA
Hells_Fury is offline
Old 05-01-2007, 12:44 PM   #5 (permalink)
Google Bot
Pathik's Avatar
yup let ur battery drain out fully.. Only then recharge it
Pathik is offline
Old 05-01-2007, 01:09 PM   #6 (permalink)
Sup' dude, Sup'
Most Important: Do not use the phone when it is charging. That's damn harmful.
ambandla is offline
Old 05-01-2007, 01:33 PM   #7 (permalink)
Google Bot
Pathik's Avatar
@amar y is it harmful??
Pathik is offline
Old 05-01-2007, 01:44 PM   #8 (permalink)
Sup' dude, Sup'
Li-Ion Battery get hot while charging or while talking. When you do both at the same time, the battery get's extremely hot and can explode (not everytime).
ambandla is offline
Old 05-01-2007, 02:20 PM   #9 (permalink)
gdatuk's Avatar
  • Avoid frequent full discharges because this puts additional strain on the battery. Several partial discharges with frequent recharges are better for lithium-ion than one deep one. Recharging a partially charged lithium-ion does not cause harm because there is no memory. (In this respect, lithium-ion differs from nickel-based batteries.) Short battery life in a laptop is mainly cause by heat rather than charge / discharge patterns.
  • Batteries with fuel gauge (laptops) should be calibrated by applying a deliberate full discharge once every 30 charges. Running the pack down in the equipment does this. If ignored, the fuel gauge will become increasingly less accurate and in some cases cut off the device prematurely.
  • Keep the lithium-ion battery cool. Avoid a hot car. For prolonged storage, keep the battery at a 40% charge level.
  • Consider removing the battery from a laptop when running on fixed power. (Some laptop manufacturers are concerned about dust and moisture accumulating inside the battery casing.)
  • Avoid purchasing spare lithium-ion batteries for later use. Observe manufacturing dates. Do not buy old stock, even if sold at clearance prices.
  • If you have a spare lithium-ion battery, use one to the fullest and keep the other cool by placing it in the refrigerator. Do not freeze the battery. For best results, store the battery at 40% state-of-charge.
Extracted from: My blog
Twitter @cgiridhar
Moto Milestone | Rooted | Froyo | CM 6.1.0
AMD Phenom2 720 x3 BE | Gigabyte MA78G | WD 500Gb+Seagate 1TB ext | PSU Corsair vx450 | Corsair 2x2gb RAM | Bose Companion 5
gdatuk is offline
Old 05-01-2007, 03:36 PM   #10 (permalink)
Google Bot
Pathik's Avatar
i must hav done tht atleast a 1000 times but no such hazardous result...
Pathik is offline
Old 05-01-2007, 04:02 PM   #11 (permalink)
The Devil's Advocate
iMav's Avatar
ya me too ..... heard of this for the first time ....
http://beingmanan.com
iMav is offline
Old 05-01-2007, 11:53 PM   #12 (permalink)
Wire muncher!
infra_red_dude's Avatar
Originally Posted by Hells_Fury
One major factor that affects Li-Ion batteries is when you charge it. For example, if you keep charging the battery when its just half empty, then over time the battery capacity will reduce to only that much. This is called "Memory Effect". The best thing to do would be to re-charge your battery only when its nearly empty and even then, you should re-charge to the full battery capacity. Hope this helped.
Note that this behaviour applies to only Li-Ion batteries and not NiMH ones.
u've completely messed it up pal! the memory effect is seen in NiCd batteries. NiMH batteries do suffer from memory effect to some extent. Li based batteries (ion/polymer) haf little or no memory effect. so if the battery is li-ion/polymer then do not let it drain completely! one more word of caution: do not overcharge!
infra_red_dude is offline
Old 06-01-2007, 02:04 AM   #13 (permalink)
El mooooo
eddie's Avatar
@gdatuk: Thanks a lot for that awesome post man
eddie is offline
Old 06-01-2007, 07:30 AM   #14 (permalink)
krazyfrog
Posts: n/a
I charge my cell as soon as it displays 'Battery Low' for the first time and charge it till it displays 'Battery Full'. I do not charge it when its half empty and always charge it till it gets fully charged. I also do not continue charging it after it displays Battery Full. I never put the charger on overnight. An important thing is to never remove the charger first from the phone and then from the power outlet. Always remove it first from the power outlet and then from the phone. Doing this the other way can damage the battery as well as the charger.
Old 06-01-2007, 11:17 AM   #15 (permalink)
Google Bot
Pathik's Avatar
my battery is on charging wenever i m home.... still no reduction in battery lifetime... if i use it it lasts arnd half a day... if my dad uses it it lasts abt 3 days...
@ krazy all the ppl i know pull the fone out of the charger but no1 has damaged their fone yet
Pathik is offline
Old 06-01-2007, 01:39 PM   #16 (permalink)
krazyfrog
Posts: n/a
^^ This from Digit Fast Track to Mobile Telephony (page 77).
"While charging the device, do not pull the adaptor cord out from the device until the main electricity supply is switched off, as doing this could cause a spike that could damage the device"
Old 06-01-2007, 04:07 PM   #17 (permalink)
Sup' dude, Sup'
@pathiks and mav3. Yes might have done that a 1000 times but 1 overheat is enough to blow it. Ask any mobile phone manufacturer or any electronics guy who is well aware of how Li-ion batteries work.
ambandla is offline
Old 07-01-2007, 10:47 AM   #18 (permalink)
sourav237's Avatar
i agree wth ambandla
sourav237 is offline
Old 07-01-2007, 11:46 AM   #19 (permalink)
Let the music play.....
djmykey's Avatar
Hmm me too pulls the plug off the mobile , however I had a bad exp with my 6600. I used to charge it every morning. So what happened over a period of time was that it used to discharge and get charged only the first specific amt. So if someday if I forget to charge it, it wud switch off automatically when that specific amount of charge was discharged. This happened around 2 months ago. Since then I'm not charging my phone unless it shows less charge. Now its working fine. But was scared as hell that I messed up the battery coz a new one costs 1200
djmykey is offline
Old 08-01-2007, 08:35 AM   #20 (permalink)
Hells_Fury's Avatar
Sorry bout that..Got confused. Edited original post.
Old 08-01-2007, 11:42 AM   #21 (permalink)
Are these tips same for lithium polymer type batteries also
Old 09-01-2007, 12:52 AM   #22 (permalink)
Tech.Masti's Avatar
heard that if "area info" is off, then it also saves battery.
Tech.Masti is offline
