Old 04-01-2007, 10:44 AM   #1 (permalink)
nik_for_you's Avatar
Default how to open body cover of 6233 ?
HI,
can anybody tell me how to open and replace the body cover in 6233 ..
i havent find any way of doing this (i was afraid that accidently i shoundnt have broken up them..)
any body having 6233 here???
I AM REBEL
nik_for_you is offline
Old 05-01-2007, 11:57 AM   #2 (permalink)
dinesh_mettur's Avatar
Default Re: how to open body cover of 6233 ?
Very simple u try u r self or refer u r manual
___________________________
~~ THINK DIFFERENT ~~
.. U'r Ultimate Place To Enjoy ..
www.funisland.co.nr
dinesh_mettur is offline
Old 05-01-2007, 01:31 PM   #3 (permalink)
Google Bot
Pathik's Avatar
if he knew how to do it he wdnt hv asked..
Pathik is offline
Old 06-01-2007, 02:28 AM   #4 (permalink)
El mooooo
eddie's Avatar
What are you trying to open here? If you just mean the battery cover then have a look at the following two images. They will give you fairly good idea as to how to remove it
http://i.gsmarena.com/ii/reviewsimg/...marena_015.jpg
http://i.gsmarena.com/ii/reviewsimg/...marena_021.jpg
If you meant the covers that enclose the whole body then you will need a small screw driver to remove it. Beware...they are not express-on covers like what we get in some Nokia phones. Covers in this phone are like skin of the phone. If you try to replace it...you risk damaging your phone and let me assure you that if you damage your phone this way...you will void your warranty.
eddie is offline
Old 08-01-2007, 09:35 AM   #5 (permalink)
^^ thanx...
I have ordered new skin from ebay.. and with that i will get some kind of tool to open cover..
__________
and i dont want to remove only battery cover..
I AM REBEL
