| Forum |
| Mobiles and Tablets Topics related to mobile phones, tablets and various operating systems. News should also be posted here. Note: This NOT the place for BUYING ADVICE queries. |
#1 (permalink) |
guys i want to ask that whenever i download or if any body is tranfering a video or a heavy file to me or i iam downloading a video(mostly this happens to video) phone says that delete some data of ur choice .memory stick full when i see the phone status it says that i hve phone memory=33mb and memory stick =469mb free what is the problem;-( ??.. plz help!
#6 (permalink) |
Try the following solution.
Have you formatted your card recently? If not you may try to format it using the utility given in the phone. Don't try to format it using pc. Check if your card is working perfectly using a card reader. If this doesn't solve this then inform will try to help.... __________ Hey assasin. have you ever tried to fill 33 MB with SMS. And memory dedicated for SMS has no connection with main memory unless the memory is a shared memory. And again full SMS memory may prevent new incoming SMS but not file transfer. So................................................ ................
Crazy is what crazy does. So lets get crazy like hell. Last edited by Crazy Kidd; 02-01-2007 at 12:00 AM. Reason: Automerged Doublepost |
#8 (permalink) |
@Crazy Kidd Dude i've never used SE fones and i use Nokia.When u send a file thru BT or IR in nokia,it gets stored in the Inbox and if u dont have enough free fone mem den u wont receive the file.So i suggested that way.
#9 (permalink) |
I was asking if possible then use a card reader to test the card. Its not necessary. Format your card from phone menu without connecting it to pc. There is a option of formatting the card from phone menu, in the page where you can view card properties. If you still face the problem inform just inform......Never format your card from pc using data cable. You probably changed the file system. It should be formatted in FAT file system.
And assasin never mind. We all make mistakes.
Crazy is what crazy does. So lets get crazy like hell. |
#12 (permalink) |
reset ur phone thr master reset option
___________________________ ~~ THINK DIFFERENT ~~ .. U'r Ultimate Place To Enjoy .. www.funisland.co.nr ___________________________ |
#13 (permalink) |
Wow. Nothing Worked............
Try resetting the phone. But I don't think it will work either. Do you still have the 64MB card bundled with the phone. See if it works. If not then the fault is with your card slot. Else the card is faulty. Have you checked the file system of your card? Was the card working earlier. Can you remember the moment you faced this problem first? Keep posting. Will be with you till the end.
#15 (permalink) |
guys i have 512 mb card
and card and slot both work fine the file iam downloading is a 3gp file(85kb size) and iam downloading it from sonyericcson's wap site file system is fat __________ @crazy thanks for being with me till end
Last edited by ::cyborg::; 04-01-2007 at 04:09 PM. Reason: Automerged Doublepost |
#18 (permalink) |
Wire muncher!
dunno if this is the problem. but on a vague idea check if the filename has some unsupported characters.
"The true measure of a man is how he treats someone who can do him absolutely no good." http://phoenix-ani.blogspot.com |
#20 (permalink) |
Big problem. So you are facing this problem only in case of video files. Try downloading from other site. Or try transferring a video file from your friends mob using blue tooth.
#22 (permalink) |
the format iam downloading of videos is 3gp
and i tried with other phone but still the problem is there i think iam finished!!!!!!!!!!!!!!!!!!!
#23 (permalink) |
Well I think so. I think the card is faulty or your firmware is not supporting it or malfuntioning. If it is still within warrenty cover then visit a Sony service center to get it updated. Else change the card.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
