Old 27-12-2006, 07:30 PM   #1 (permalink)
shyamno's Avatar
Exclamation Formatting Symbion Phones.
Is there any special strings through which we can format the whole symbion OS of Nokia ??
shyamno is offline
Old 27-12-2006, 08:04 PM   #2 (permalink)
Tech Geek's Avatar
Default Re: Formatting Symbion Phones.
This is a trial software.
Oxygen phone manager
http://www.bestsoftware4download.com...-uucavopu.html
Tech Geek is offline
Old 27-12-2006, 09:37 PM   #3 (permalink)
Google Bot
Pathik's Avatar
*#7370# and *#7780# .,..
or use the 3 key format... green,*,3 key together
Pathik is offline
Old 28-12-2006, 09:30 AM   #4 (permalink)
mayneu's Avatar
Talking Re: Formatting Symbion Phones.
just to add one more key, instead of holding 3 u can hold red button along with greeen & *..... then switch off. while switching it on, make sure that u have pressed all the three buttons at a time for roughly 1min....or till it shows up the startup screen or welcome screen like nokia.... then it will ask for date and select city etc.... hope that solved ur problem.....
mayneu is offline
Old 28-12-2006, 11:17 AM   #5 (permalink)
dissel's Avatar
Little bit offtopic :
Is there any way to clear the software log....I mean all software entry that I installed earlier in the phone listed in the application manager log.
After formatiing the mem card I can't delete those entries...It proably situated in the phone mem.
Any Idea ?
dissel is offline
Old 28-12-2006, 12:26 PM   #6 (permalink)
Google Bot
Pathik's Avatar
goto c/system/install/install.log... copy it and ad rename it to .txt...
edit the entries u want to delete.... also keep a backup copy of it.... if u delete the wrong things it ll get corrupted...
by trial n error u shd understand it...
Pathik is offline
Old 29-12-2006, 03:47 PM   #7 (permalink)
dissel's Avatar
Ok how i reach there....If I go via PC-Suite's phone browser there is nothing OR If through phone's Organizer>file manager>Phone memory>install there is nothing.
I can't get the install.log.
dissel is offline
Old 29-12-2006, 08:31 PM   #8 (permalink)
krazyfrog
Posts: n/a
^^ Typically this requires one to have either FExplorer or Smartfileman installed on their phone. But since you have a 3250, you can't install these. Try installing ProfiMail from www.lonelycatgames.com (install the correct version for your phone from the downloaded .exe file). Then use the ProfiExplorer that gets installed along with it and follow the steps given by @pathiks.
Old 29-12-2006, 10:29 PM   #9 (permalink)
Google Bot
Pathik's Avatar
u can also try sexplorer..
Pathik is offline
Old 30-12-2006, 03:53 PM   #10 (permalink)
Resident Fanatic
Manshahia's Avatar
We can also hide the files using FeExplorer..
Manshahia is offline
