| Forum |
| Mobiles and Tablets Topics related to mobile phones, tablets and various operating systems. News should also be posted here. Note: This NOT the place for BUYING ADVICE queries. |
#1 (permalink) |
CBZ is better than Pulsar
i have a Nokia 7250i. i want it to use a modem for browsing net in my PC. for that matter, i have bought a DKU-2 cable compatible for my fone, and also have NOKIA PC suite 6.81 downloaded from Nokia's site. but after installation, the proggy does not recognize my fone.it says 'my fone is not connected'....can anybody help??? much appreciated for the help!!! |
#3 (permalink) |
thanks pathiks for replying, but if i install the suite i got with the fone, it contains no provision for gettin connected to net>>>!!!! plz help!!
#4 (permalink) |
dont need pcsuite...
just download modem driver from nokia site and install.. now whenever you will attach your fon to pc you will see in modems new modem is ther .. create dial up connection using this modem and done
I AM REBEL |
#7 (permalink) |
hey somehow i am able to connect my fone using the pc suite.
i also installed the cable drivers for my nokia...my computer also recognized my fone as modem...but i m not able to make a connection...whenever i try to make a conn, the com says the port used by the modem is open n tells me close the port by shuting down any applications tht might be usin it.i tried this but the pc says the prt is still open...help |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
