Old 25-12-2006, 01:03 PM   #1 (permalink)
Default GOOD edge supporting nokia for mobile office
Well i m using o2 mini s xda formo ...but i wont to go for nokia one now..as nokia has good resale value...and i find o2 mini hard to carry.....and changing sim is boring stuff for me........
i waslooking for 6630 or within 11k range phone which doesnt heat much...with good talktime also...so plz giv suggestion...plus.......
also for prepaid mo is rs 7per day in mumbai......i may change to postpaid ...doe somone has idea how mouch they charge forpost paid...there cc doesnt help much..they sayin as i m prepaid customer they r frm prepaid dept so have no idea......
magnet is offline
Old 25-12-2006, 01:26 PM   #2 (permalink)
krazyfrog
Posts: n/a
Default Re: GOOD edge supporting nokia for mobile office
6630 is an excellent choice. You can also take a look at 6681 since they're similarly priced and i think 6681 looks better.
Dunno about MO cost in postpaid, but you can call 9892012345 from landline phone to check. This is the number for postpaid only. For prepaid it is 9892098920
Old 25-12-2006, 01:46 PM   #3 (permalink)
Google Bot
Pathik's Avatar
in postpaid its 199pm nd do u want to use net on phone only or pc also???
Pathik is offline
Old 25-12-2006, 02:32 PM   #4 (permalink)
assasin's Avatar
dont think dat u'll be able to get the nokia 6630 cuz nokia has stopped production.U can buy the Nokia 5500,it has EDGE Class 10 (D/L speed = 236.8kbps).I've a Nokia 5500,Airtel postpaid with MO activated and i get D/L speeds of 20-25KB/s.
assasin is offline
Old 25-12-2006, 06:14 PM   #5 (permalink)
ohh thks guys.......well i m using MO for pc........i o use sometime on phone..but i m a pc freak .......well right now i m on lifetime prepaid...but suddenly...my call making frequency has increased.......
so wasthinking to go for postpaid...299 celebration plan where call rates are 50paise.....so i guess ard 500 will go in this stuff only....plus mobile and othercharges will bring it to ard........700.....i guess.....
assasin i guess yup i m looking for same option as yours...whts your charges and all stuffs....in the mean time all of u njoy reps...since all post gave me information
i want to sell O2 as its not in warranty...andif any crazy stuff happens i guess it will hit my pocket hard
btw assasin where do u stay...does your mobile heats upa lot when used for 1 hour continuous download????
also i m more tilted towards 6280
magnet is offline
Old 25-12-2006, 07:16 PM   #6 (permalink)
Google Bot
Pathik's Avatar
hey 6280 is a s40 dont take it... U shd take a 6233 or more pref. A 5500... U ll get good net speeds in both.. Btw dont change to postpaid.. It doesnt hv unlimited data transfer.. Jus check it again
Pathik is offline
Old 25-12-2006, 07:42 PM   #7 (permalink)
Nokia 5500 sports is a very good option u get all 'sport' fetures such as 3D motion sensing,step counter+distance sounter etc + its rugged.
moreover it comes with 512MB Sd card and data cable
the other option might be 6233 but i recommend 5500S since it has symbian OS
Build started: Project: MyLife...Starting Main Compilation....Warning : Cigarette smoking is injurious to health
Build complete:0 errors, 1 warnings. 1 succeeded,0 failed,0 skipped
Output : Screw warnings !!! Live life Bindaas!!!
merawalaid is offline
Old 25-12-2006, 09:29 PM   #8 (permalink)
than i guess ill tak aseperate cdma stuff jus forcalls and use this only with cmp
btw 6233 looks good not fancy plus support 3g whts its cost????
magnet is offline
Old 26-12-2006, 09:36 AM   #9 (permalink)
Google Bot
Pathik's Avatar
its 12k.. And its s40v2.. With awesome gprs speeds on pc
Pathik is offline
Old 26-12-2006, 10:50 AM   #10 (permalink)
assasin's Avatar
@magnet I mainly use myfone to surf and D/L.and i hav D/L sessions of bout 3-5hrs.Deres only a small amout of heat buildup.Its negligible.Dont buy the Nokia 6280,it has lots of probs,jst visit the link to 2 see the probs:
http://en.wikipedia.org/wiki/Nokia_6280#Faults
@pathiks Airtel Postpaid has unlimited data transfer schemes cuz i'musing dat scheme myself.
assasin is offline
Old 26-12-2006, 09:55 PM   #11 (permalink)
fine i may go with 6233 stuff now....i have another person who earlier suggested me series 40 phones too for internet.....nyways......reason for supporting itover 5500 isonly it supports 3g and i m not a person wh change mobile often
ill take the detail out of MO for postpaid....by tomm
Btw assasin where r u based btw????
magnet is offline
Old 26-12-2006, 11:25 PM   #12 (permalink)
Google Bot
Pathik's Avatar
i suppose u hav made the rite choice.. In s40 u cant multitask neway and the gprs speed is awesome.. Also u wont find many apps 4 5500 as its os9.1
Pathik is offline
Old 27-12-2006, 12:42 AM   #13 (permalink)
assasin's Avatar
@magnet I live in Durgapur.
@pathiks As far as apps 4 s60v3 (i.e. Symbian OS 9.1) is concerned,u'll get bou bout 200.
assasin is offline
Old 27-12-2006, 12:26 PM   #14 (permalink)
Google Bot
Pathik's Avatar
but my friend 200 is very less as compared to abt 2000+ in os 6/7/8
Pathik is offline
