Old 21-12-2006, 09:47 PM   #1 (permalink)
Resident Fanatic
Manshahia's Avatar
Default Very Slow N70
Friends i m using N70 but its not upto my expectations.
If i press menu button it takes years to open.
R there any tips to speed it up
Plz friends help
I m dying
Manshahia is offline
Old 21-12-2006, 10:21 PM   #2 (permalink)
>>>>>Monkey Power<<<<<
shivkumar's Avatar
Default Re: Very Slow N70
Try changing the memory card. It worked for me in Nokia 6681.
If you want to be happy, be.
shivkumar is offline
Old 21-12-2006, 10:57 PM   #3 (permalink)
hailgautam's Avatar
look for the number of applications running, to do that keep the menu button pressed for few seconds. then close all the applications you don't want.
Change is Nature, the part that we can influence; and it starts when we decide.
Where you going?
With Luck forward.
hailgautam is offline
Old 22-12-2006, 10:34 AM   #4 (permalink)
krazyfrog
Posts: n/a
I've seen this problem in a 6630 and a 6681. Unfortunately the only way by which the problem was solved was to format the memory card in the phone itself. You can try this method if all other fails. Before formatting, backup the data to your pc (don't backup the folders directly, but just the files. Then copy back those files to the respective folders of the freshly formatted card)
Old 22-12-2006, 03:11 PM   #5 (permalink)
Google Bot
Pathik's Avatar
do u close apps or minimize them?????
try formatting ur mmc...
also post ur firmware version..
Pathik is offline
