Old 21-12-2006, 09:03 PM   #1 (permalink)
Default Help regarding HandyCam....
Hello everyone,,, i want to buy a handycam... but i am not sure which is good one... can u plz suggest one.. no limit on budget(better be nid ranged).. Sony or Panasonic?? which is good.. also i heard that some of them come with provision to insert cd & record directly on it.. which is better? with cd or without cd....plz reply..
mubed_007 is offline
Old 21-12-2006, 10:20 PM   #2 (permalink)
Default Re: Help regarding HandyCam....
Sony is generally preferred but for almost the same price or a little more, you may be able to buy a 3 CCD Panasonic one. For a general idea of the pricing in INR and for specifications a visit to www.jjmehta.com will be helpful.
V.Prem Kumar
janitha is offline
Old 21-12-2006, 11:07 PM   #3 (permalink)
hailgautam's Avatar
to be specific i would suggest sony dhc 46.
it is the up-dated version of dhc 42. and it is good model. if at all price could be the criteria dhc 36 is a very good value for money model.
Change is Nature, the part that we can influence; and it starts when we decide.
Where you going?
With Luck forward.
hailgautam is offline
Old 21-12-2006, 11:46 PM   #4 (permalink)
harikatt's Avatar
i prefer to say.. is sony is very good , but even panasonic doesnt lags behind, prefer the pricing and comparison. for features and try for an dv type.. which can be good than direct to CD or DVD if its for professional, if all this is for home personal than u can go for direct recording to cd or DVD ones..
3d Graphics Animator, //\\ Senior level team Leader
Life is so deep,, that if we try to see in it, we may fall ourselves
harikatt is offline
Old 22-12-2006, 01:55 AM   #5 (permalink)
Rebooting
Choto Cheeta's Avatar
well if there is no bar on budget then for sure go for Panasonic 3CCD based ones... now 3CCD systems are very very costly because they are the ulitmate camera when it comes to broadcast quality... or making movies...
now if thats too costly for u, then and also if u want slick portable camera, then think of Sony hard disk based High Defination cams...
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 22-12-2006, 07:56 AM   #6 (permalink)
3 CCD cameras were very costly but no more. Search Ebay and you will be able to find latest Panasonic 3 CCD camcorders with Leica lens with cost starting from 25K. Naturally, in the local market it should be even less.
V.Prem Kumar
janitha is offline
Old 22-12-2006, 08:13 AM   #7 (permalink)
Kiran.dks's Avatar
I suggest you Sony DCR-HC46E. Infact I am also purchasing it soon. Shoot and save directly any number of times on Memory stick. No need to purchase expensive tapes.
Features:
Professional quality Carl Zeiss lens
Zoom (12x Optical, 800x Digital)
2.7" Wide Hybrid LCD Monitor
Touch Panel Function
Super Night Shot Plus
Super Steady Shot
Memory Stick Duo Slot-1000K Pixels Digital Still Camera Function
Price: Rs.26,990 /-
Kiran Kumar R
Kiran.dks is offline
Old 23-12-2006, 01:35 AM   #8 (permalink)
sourav237's Avatar
don't spend much bcoz technology is changing vry fast
go for the mini dv models.
buy a 512 memorystick 4m grey mrkt.
sourav237 is offline
