Old 18-12-2006, 07:47 PM   #1 (permalink)
dinesh_mettur's Avatar
Question Phone Lock on K750i???
hi dudes
Is it possible to lock the keypad with security code in SE k750i??
Any Application is there if so pls provide the link !!!!
___________________________
~~ THINK DIFFERENT ~~
.. U'r Ultimate Place To Enjoy ..
www.funisland.co.nr
dinesh_mettur is offline
Old 18-12-2006, 10:44 PM   #2 (permalink)
Wire muncher!
infra_red_dude's Avatar
Default Re: Phone Lock on K750i???
nope, its not possible.
infra_red_dude is offline
Old 18-12-2006, 10:56 PM   #3 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Yeah! You can't
And thats the worst thing in this phone
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 19-12-2006, 08:12 AM   #4 (permalink)
Kiran.dks's Avatar
You can't lock keypad with security code. You can give Security code for start-up of the phone.
Kiran Kumar R
Kiran.dks is offline
Old 21-12-2006, 12:19 AM   #5 (permalink)
Wire muncher!
^^ thats got more to do wid the SIM PIN.
Old 21-12-2006, 08:48 AM   #6 (permalink)
Kiran.dks's Avatar
Nope it has nothing to do with the SIM. It is a 'Phone Lock' code and not SIM lock that you are pointing to. 'Phone Lock' code is for start-up of the phone. It works with any SIM.
Kiran Kumar R
Old 21-12-2006, 11:27 PM   #7 (permalink)
Wire muncher!
but then apart from asking for startup pin, doesn't it bind the sim wid the phone?
Old 21-12-2006, 11:39 PM   #8 (permalink)
Microsoft MVP
Actually, the phone startup lock code is different from the startup PIN code
Old 22-12-2006, 06:30 AM   #9 (permalink)
Kiran.dks's Avatar
You need to understand that the code is stored in phone, not SIM. That is the reason it asks for the same code regardless of which SIM you put.
SIM lock code is stored in SIM. So in this case 'any' phone will ask for pin code. You need not have a K750i for that.
Kiran Kumar R
Old 23-12-2006, 09:49 PM   #10 (permalink)
Wire muncher!
i asked that the phone lock code binds a particular sim to that phone? i dun remember which SE set i'd seen but the phone was locked to a particular sim (not the network lock, it the particular sim). the phone wudn't allow any other sim (not even from the same operator) to be fit in. u will need to provide the code for other sims to work. i dun remember correctly if this feature was phone lock.
__________
of corz the sim pin is stored in the sim and phone lock code in the phone. thats obvious!
Last edited by infra_red_dude; 23-12-2006 at 09:49 PM. Reason: Automerged Doublepost
Old 23-12-2006, 10:27 PM   #11 (permalink)
Microsoft MVP
The SIM lock, which u r talking about is other thing, its not phone lock code!
If someone stole ur mobile, then u can ask the service provider to lock ur phone with the SIM so that other SIM will not work in that hone
But there r many ways/softwares available to remove that lock also
Old 24-12-2006, 12:49 AM   #12 (permalink)
Wire muncher!
not getting my point! therez a feature available which locks a particular sim card to a handset. for e.g if u haf a sim wid the number 9886012345 and u activate this feature. now u try to put a sim wid the number 9886054321 then the phone won't accept the sim unless u key in the code. however if u put back the 9886012345 sim in that handset, it will accept it widout any code. can't the remember the set and the locking technique.
