Old 16-12-2006, 07:40 AM   #1 (permalink)
Talking ipod...
hey digitonz
can i view pdf files in my ipod?
pranavrahul is offline
Old 16-12-2006, 11:32 AM   #2 (permalink)
kumarmohit's Avatar
Default Re: ipod...
nope idont think so
kumarmohit is offline
Old 16-12-2006, 12:59 PM   #3 (permalink)
Default Re: ipod...
You cannot view Pdf files directly on your Ipod but can U can convert them into IPod notes here is the software for it http://www.ambience.sk/ipod-ebook-cr...conversion.php
And here are 2 tutorials
http://www.makezine.com/blog/archive...oks_for_1.html
http://www.makezine.com/blog/archive...pod_ebook.html
snake is offline
Old 23-12-2006, 01:15 AM   #4 (permalink)
sourav237's Avatar
Default Re: ipod...
Dear i-pod users?
Can u give some idea abt the batteries. i want to buy a nano(2gb).
what is the battery life i.e after how many hours i'v to buy new battery. can i change them or i'v to go to shop.
and... finally are the batteries changable .
sourav237 is offline
Old 23-12-2006, 01:29 AM   #5 (permalink)
sumeet singh's Avatar
Talking Re: ipod...
dude batteries are chargeable....
__________
sorry.. changeable...
Last edited by sumeet singh; 23-12-2006 at 01:29 AM. Reason: Automerged Doublepost
sumeet singh is offline
Old 23-12-2006, 01:30 AM   #6 (permalink)
sourav237's Avatar
Default Re: ipod...
ok thnx & wht abt the life
Old 23-12-2006, 01:34 AM   #7 (permalink)
The Devil's Advocate
iMav's Avatar
Default Re: ipod...
they are chargable and changable ... changable only by apple not by u .... abattery charge cycle of the new pods is estimated of abt 12hrs playback .... and i think they say around 2-3yrs the battery works
http://beingmanan.com
iMav is offline
Old 23-12-2006, 01:40 AM   #8 (permalink)
sourav237's Avatar
Default Re: ipod...
new pods abt 24hrs playback; older abt 12 hrs.
actually i'm planning to buy it 4m US through a friend. can i face any problem of servicing or repairing or changing batteries in india . i'm 4m kolkata
Old 23-12-2006, 02:07 AM   #9 (permalink)
iMav's Avatar
Default Re: ipod...
oops sorry my mistake typo error ... apple claims 24 hrs playback i wud say around 23 ...i guess u wont find any probs here coz some apple users on this forum hav said tht apple has a very good service systme in place in india
iMav is offline
Old 23-12-2006, 10:20 AM   #10 (permalink)
sourav237's Avatar
Default Re: ipod...
thnx.
Old 23-12-2006, 10:38 AM   #11 (permalink)
krazyfrog
Posts: n/a
Default Re: ipod...
The reviewers at cnet.com managed 24.5 hours of playback out of the new Nano. You can read the complete review here:http://reviews.cnet.com/Apple_iPod_N...?tag=pdtl-list
Old 23-12-2006, 04:17 PM   #12 (permalink)
sourav237's Avatar
Default Re: ipod...
ya i'v read that
Old 25-12-2006, 12:08 PM   #13 (permalink)
Default Re: ipod...
Battery life largely depends on ur MP3 or format ur using to play song.
If u play Higher Bitrates songs u will get less battery life.MP3 manufactures battery life test are 128 Kbps bitrates based which gives them all those fancy numbers.
AMD X2 3600+ @ 2.3Ghz | Biostar TF 550 | XFX 8800GTS XXX (320 mb) | SATA 250 GB | 2x1GB Kingston DDR2 PC-5300 | X-fi Extreme Music | Corsair 620 Watts |Antec
snake is offline
Old 25-12-2006, 02:57 PM   #14 (permalink)
sourav237's Avatar
Default Re: ipod...
thnx.
Old 11-02-2007, 10:30 AM   #15 (permalink)
sourav237's Avatar
Default Re: ipod...
i bought a nano . but the volume is much lower even in max. volume. any user plz help. what is vol limit.
Old 11-02-2007, 10:41 AM   #16 (permalink)
krazyfrog
Posts: n/a
Default Re: ipod...
Maybe there is some sort of volume limiter (like AVLS in Sony players), which prevents accidental increase in volume. See if you can find and deactivate it.
__________
Btw how much did you buy your Nano for?
Old 11-02-2007, 11:21 AM   #17 (permalink)
Google Bot
Pathik's Avatar
Default Re: ipod...
the volume in NANO is good enough dude...
Pathik is offline
Old 18-02-2007, 12:32 AM   #18 (permalink)
sourav237's Avatar
Default Re: ipod...
actually i can't hear it properly when i'm travelling in local train. i know in local train there is so much noise . but i can hear k750i sound throuh headset.
i mean to say is the max vol in nano is lower than max vol in k750i through headset?
but otherwise sound is good.
Old 18-02-2007, 10:09 AM   #19 (permalink)
aryayush's Avatar
Default Re: ipod...
Did you buy it in India? There is a volume limiter but I do not know how to de-activate it.
As for service, I would say it is pretty darn good.
aryayush is offline
Old 18-02-2007, 11:04 AM   #20 (permalink)
gmanog's Avatar
Default Re: ipod...
In settings there is an oprtion called volume limit, you increase the volume in it and set it at a higher level
__________
The link provided by you can convert only text files to ipod. Not pdf files
gmanog is offline
Old 25-02-2007, 01:43 AM   #21 (permalink)
sourav237's Avatar
Default Re: ipod...
i bought 4m USA through a frnd.
Old 25-02-2007, 01:48 AM   #22 (permalink)
iMav's Avatar
Default Re: ipod...
thts not possible under any case .... u cant hear in a local train ...
try this .... thr is an option under settings wich allows u to set the max volume .... change tht
iMav is offline
