Re: coming to 022 .( mobile subscriber help please )
You can get the form at any outlet but MTNL people suggest you otherwise. You can just goto MTNL office (there is one in Nerul, not far from Kharghar) and fill up the form and submit it.
Taking the connection directly from MTNL have this advantage that you wont have to submit your documents twice (and in my frnd's case thrice and still his connection was suspended for 4 days) ..
On a personal note, I wont recommend you using MTNL .. MTNL has a great network coverage .. but its infrastructure isnt upto the mark .. On busy hours you'll have to call 5 - 6 times to get connected to an MTNL number .. If your callers can show this patience then MTNL is the best else try AirTel ..
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
