Old 08-12-2006, 09:01 PM   #1 (permalink)
Default nokia 6270
i have a nokia 6270. Accidentally my friend have set a MMC password (while playing with my mobile) and when i try to reset it i cant. When i asked him what password he gave he said he didnt give any password(maybe he dont know what he did). Now, i cant use my mmc. Is there any solution to this. i dont care if its formatting the MMC.
Regards
Experience Is not Counted in Years.. But in the Countless Effort
www.kolasib.com www.zoram.org
valtea is offline
Old 08-12-2006, 10:03 PM   #2 (permalink)
krazyfrog
Posts: n/a
Default Re: nokia 6270
Well there is hardly you can do in this case. You'll need to give it to Nokia Service Centre. They'll unlock it for you.
(You can always punch your friend on the head till he remembers the password. Or you can try entering random numbers in the hope of entering the correct password:-P)
Old 09-12-2006, 07:29 AM   #3 (permalink)
Mobile Freak
reddick's Avatar
I have an app. for ur phone which can easily restore ur lost password.
PM me with ur email add. n I will send it to u Cheers!
Hope 4 d best n Do d right :)
reddick is offline
Old 09-12-2006, 10:42 AM   #4 (permalink)
Thanks alot. Waiting for ur mail
valtea is offline
Old 10-12-2006, 12:15 PM   #5 (permalink)
reddics i got your mail, thanks for the mail. i tried installing te software but it seems my phone is a Series 40 phone so i cant install any sis file in it. Kindly help
__________
reddick i got your mail, thanks for the mail. i tried installing te software but it seems my phone is a Series 40 phone so i cant install any sis file in it. Kindly help
valtea is offline
