Old 04-01-2005, 09:48 AM   #1 (permalink)
Default Internet on your phone using bluetooth and ur pc connection
Internet on your phone using bluetooth and your pc connection!!
this will work on most s60 phone I guess! it has been tested on an NGAGE and on N3650!
step 1:
Creating an access point on your phone!
tools\settings\connection\access points\options\new access point>default settings...
these are the settings u need there..
Connection Name : Anything (sugestion ADLS or PCGPRS something u remember well cuz u'll need it later!)
Data Bearer: GPRS
Access Point Name: The name you gave to your bt connection when pairing up with the computer...
Username : None
Password : No
Authentication : Normal
Gateway IP Address : 0.0.0.0
and that's all on this on this part..
then go to:
tools/settings/connection, and select GPRS
set the GPRS connection to "when available", and the access point to "none".
The settings on your fone are done! now... the next step;
Create a serial port connection from ur pc to ur phone (u've done this before if u ever used Pcsuite from nokia), this serial connection must be on everytime you want to use your pc internet connection as a gprs connection for ur phone!!
Install the software u need to surf the web (opera, netfront, agile messenger for chat, etc..)
My advise to you is to use netfront, the options are pretty cool and it uses less memory meaning u can still run other program such as agile at the same time (it crashed my 3650 when I tried to do it with opera)..
Voilá ur ready to use ur phone to surf and chat for free!!
hope this helped you and that is simple and clear!! any question u know where to post, this will be updated if many doubts come up.
ps. works with ngage arena games!!!
Njoy!
techno_junkie is offline
Old 19-07-2005, 08:18 PM   #2 (permalink)
macaddict
gauravsuneja's Avatar
can i have done till thsi but stiil can't surf there is software called m router which does that
www.drgauravsuneja.blogspot.com
An Apple a day keeps virus away
gauravsuneja is offline
Old 19-07-2005, 10:51 PM   #3 (permalink)
Another Brick in the Wall
drgrudge's Avatar
Moved here
drgrudge is offline
Old 20-07-2005, 09:58 AM   #4 (permalink)
gdatuk's Avatar
am trying to connect via datacable..
is it possible
i tried the above steps...not working
Twitter @cgiridhar
Moto Milestone | Rooted | Froyo | CM 6.1.0
AMD Phenom2 720 x3 BE | Gigabyte MA78G | WD 500Gb+Seagate 1TB ext | PSU Corsair vx450 | Corsair 2x2gb RAM | Bose Companion 5
gdatuk is offline
Old 20-07-2005, 07:51 PM   #5 (permalink)
macaddict
its giving dns error sir net front
Old 19-09-2005, 03:58 PM   #6 (permalink)
Does it work only with blue tooth and not through USB data cable????
When the World speaks, it speaks in UNICODE
Aijaz Akhtar is offline
Old 29-07-2007, 08:46 AM   #7 (permalink)
Default Re: Internet on your phone using bluetooth and ur pc connection
Hey,
How can i do this on my motorola v3?
Thanks, Paul
mashy is offline
