Old 04-12-2006, 11:48 PM   #1 (permalink)
Default Nokia 6020 vs Nokia 6070 -Which is Best?
Hi,
I want some suggestion about both 6020 and 6070.I have confusion about the both mobiles.Can anyone suggest me a best one...
sasidhar is offline
Old 05-12-2006, 01:34 AM   #2 (permalink)
Default Re: Nokia 6020 vs Nokia 6070 -Which is Best?
u can go for 6070 cos its better the only thing bettre in 6020 is that is has tft display and 6070 has cstn otherwise 6070 is best deal cos its new and fine and as far as cstn screen is concern only it matter more if u use under sun else all same i means margainal and even u have option of FM in 6070
hunk_freak is offline
Old 05-12-2006, 11:21 AM   #3 (permalink)
Wandering in time...
Ankur Gupta's Avatar
yeah 6070 is better as it has EDGE....
the FM reception is gud....voice quality also gud....
bit slow in java applications...
low on memory...no bluetooth
but if you look at the cost...it is a great package!
Integrate Yourself With The Latest Happenings.....
www.ankur-gupta.com/blog
Ankur Gupta is offline
Old 06-12-2006, 01:57 AM   #4 (permalink)
Tech.Masti's Avatar
Dont take nokia, moto l6i is much better. Price is 6k, it's L6+ stereo FM radio. Have 10 mb memory, BT....... Just take a look
Tech.Masti is offline
